Question about 3Dlabs Wildcat VP880 Pro (256 MB) AGP Graphic Card
I'm running the Wildcat VP880 Pro on an MSI K8N Neo 2 motherboard, with an Athlon 64 3500+ processor. I'm seeing system instability with random crashes especially, but not exclusively, when running SolidWorks 2006. System also rnadomly fails too boot. When this happens, and sometimes after a crash, my screen is filled with bands of multi-colored horizontal dashes. (More attractive than the Blue Screen of Death, but functionally equivalent.) Note: This is the second motherboard I've tried with this card. Thanks in advance; Ed Clow Wheeling, IL
    Genius:
  • 1,043 Answers
Unfortunately there has been a long history of issues with the Wildcat VP880 Pro cards, especially with their driver software. I worked on a network that included workstations running those cards and working with Solidworks. We struggled a long time with trying to make the systems stable as they exhibited some of the same issues you describe. We dialed back a lot of the details in the objects that people worked with. This went a long way towards better stability. We made sure to try out all updates to the drivers and patches, although we made sure to be able to roll the machines back if the new software caused more problems than they resolved. In the end the company rid themselves of the VP880 Pro cards as they felt that they had to dial back the resolution and other aspects of the Solidworks program so much to get any stability they felt it was too much of a trade off. You're already running AMD rather than Intel which is one of the other items that helped with the stability issue. We also found that boards that had the AMD Nforce chipset seemed to achieve more stability than a lot of the other boards we tested. Unfortunately all of my research as well as the research completed by the users themselves, never found a definitive fix/patch/trick/swap etc, that solved all of the problems. Hopefully at least some of this information will aid you in your quest.
Posted on Jul 24, 2009
  • bvanjoff Jul 25, 2009
    As far as the cards go, whether or not they come with a fan is more of a manufacturing choice than anything else. There are many after market cooling kits available, with everything from better fans with pure copper heat-sinks and fins to water cooling, and even coolers that use the same pelletier junctions that the small fridge units use. Since you are planning on using your card to do some serious graphics work, I would definitely go with the best, which usually means the more expensive, card that you can afford. The more power you have, the more options you will be able to use with your Solidworks projects. When we were researching different cards to use on the workstations, we found that we could increase the productivity of the cards by as much as 80% by using the better cooling solutions. Both EVGA and BFG have good reputations when it comes to the quality of their products. Unless you are restricted by the abilities of your version of Solidworks, I would advise purchasing the newest card out of the group you have mentioned. As version numbers progressed, more and more pipelines, data bandwidth, pure speed, and memory access were added to the card. With the Geforce line of cards, sometimes the specially designated older model numbers actually did a better job than the newer model numbers. This is not the case with the 7300 GT and the 7600 GS. The 7300 GT was aimed more at the overclocking market allowing users to tweak the speed in a broader range. However the reality is that a card running at, for example, a true speed of clock/memory of 600/1400 is better than a 500/100 machine that has been overclocked to reach that speed.
    Overall I would recommend you go with the 7600 GS. If you do make that choice, try it out for awhile and then take a look at the aftermarket cooling items available. I believe you'll find the small investment pays off quickly. I hope this information will assist you in choosing your card.
K8n neon 4 platinum 1 audio drivers
Hello you can download the drivers here:
http://www.msi.com/product/mb/K8N-Neo4-Platinum--PCB-1-0-.html#/?div=Driver&os=XP%2032
By selecting your windows system.
Click on the sound link for download.
The file needs to be unziped, before you install the driver.
Reboot after the install is done.
Here is no drivers for windows 7.
Here are the other models:
http://www.msi.com/service/search/?kw=K8N%20Neo4%20Platinum&type=product
Good luck
Feb 16, 2013 | MSI K8N Neo Platinum Motherboard
What is the specification for my GA-K8N Pro motherboard?
CPU
  • Socket 939 AMD Athlon™ 64 X2 / Athlon™ 64 FX / Athlon™ 64
Chipset
  • NVIDIA nForce4 SLI MCPs (media and communication processors)
  • Super I/O: ITE IT8712
  • CICADA VSC 8201 Gigabit LAN PHY
  • T.I. IEEE1394b
  • AC'97 Realtek ALC850
Memory
  • Dual channel DDR 400 / 333 / 266 184pin
  • 4 x DIMM slots up to 4GB
Expansion Slots
  • 2 x PCI Express x1
  • 2 x PCI Express x16, supports two PCI Express interface Graphics cards with SLI mode
  • 2 x PCI slot (PCI 2.3 compliant)
Internal I/O Connectors
  • 1 x CD in
  • 1 x FDD
  • 2 x IEEE 1394b (supports 3 ports)
  • 2 x UDMA ATA 133/100/66 Bus Master IDE
  • 3 x cooling fan pin headers
  • 3 x USB 2.0/1.1 (support 6 ports)
  • 4 x SATA II 3Gb/s
Back Panel Connectors
  • 1 x COM
  • 1 x LPT
  • 1 x RJ45 LAN
  • 2 x USB 2.0/1.1
  • 6 x audio ports (Line In / Line Out / MIC In / Surround Speaker Out(Rear Speaker Out) / Center/Subwoofer Speaker Out / Side Speaker Out)
  • Coaxial SPDIF input/output function
  • PS/2 (Keyboard/Mouse)
H/W Monitoring
  • H/W detecting and reporting for case open, CPU voltage and fan speed
  • System health status auto-detect and report by BIOS
BIOS
  • 2 x 4 Mbit flash ROM
  • Award BIOS
CPU/AGP/DIMM setting
  • CPU HT / Multiplier / Vcore Voltage adjustable via BIOS
  • DIMM Voltage / Clock adjustable via BIOS
  • PCI-ExpessX16 Voltage / Clock adjustable via BIOS
Unique Features
  • @BIOS™
  • Download Center
  • NVIDIA Firewall
  • NVIDIA SLI multi-GPU support
  • Q-Flash™
  • Xpress™ Install
  • Xpress™ Recovery
Bundle Software
  • Norton Internet Security™
Power
  • ATX power connector and ATX 12V connector
  • Power-off by Windows 98/Me/2000/XP shut down and switch
Form Factor
  • ATX
  • 305mm x 244mm
Remark
  • Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website
  • This product does not support Win9X/ME, due to most hardware/software vendors no longer offer support for Win9X/ME. However we still offer available related drivers to serve our customers.
Jan 08, 2011 | Gigabyte GA-K8N Pro-SLI Motherboard
MSI K8N Neo V2.0 beep code problem is continous beeps.
That's usually a bad ram stick. Shut down the pc & remove one stick at a time starting with the one furthest from the cpu & work your way down to the first one. When it boots without the constant "beep", you found the bad one! You can also check www.msi.com & look in the support area for a solution if mine is wrong.(I'm never wrong though,lol)
May 16, 2010 | MSI K8N Neo Platinum, 601-7030-010,...
My msi k8n neo platinum is not starting no power in mother so please tell me what should i do and whats the problem in motherboard it has no power when press start it and no beep no power tell me
Bad Power On switch, or bad power supply.
My money's on the bad power supply.
There is a way to bypass the Power On switch. Should you wish to know the procedure, state so in a comment.
(Believe upper right of page)
After you have made sure it isn't a bad Power On switch, check to make sure the 20-pin ATX motherboard power cable, is seated in the motherboard. TIGHT.
(Whitish see-through, long connector on motherboard.
Has 20 socket holes. 10 on each side.
Make sure the power cable is plugged in all the way, to this connector.
Make sure the lock on the side of the connector, is snapped in place.
(This one,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
REMEMBER, computer unplugged from power! TOUCH the metal frame of the computer case, BEFORE you reach inside the computer.
Relieves your body of Static electricity)
Next, Power Supply.
When you press the Power On button, you are pressing a Momentary Contact switch.
The Power On switch that is behind the Power On button.
The switch is spring loaded inside, so that when you let go of the button, the switch opens up.
No contact.
When the switch makes contact for a brief second, a circuit is created. 5 Volts is sent through the motherboard, to the Power Supply.
The Power Supply turns on.
Power is sent to the motherboard. BIOS is the first program to be turned on.
BIOS 'see's what devices are installed, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System.
(Windows XP is an example of an O/S)
Not enough power to turn the Processor on.
Your power supply has a weak voltage power rail, or a failed voltage power rail.
The power supply you have for your MSI K8N Neo Platinum, has three main voltage power rails.
1) The 3.3 Volt rail
2) The 5 Volt rail
3) The 12 Volt rail
Inside the Power Supply.
There are many components used inside a SMPS power supply, (Switched Mode Power Supply)
The main component that fails is an Electrolytic Capacitor, (Or more than one)
(Information about SMPS,
http://en.wikipedia.org/wiki/Switched-mode_power_supply
You can click on the photo to the top right of this page, to enlarge it.
Main thing I'm pointing out here, are the Electrolytic Capacitors.
The large one's on the left side, are used in the Input Stage.
The smaller one's on the right are in the Output Stage.
This IS NOT, an invite to open your Power Supply!! Read the info at the end of this solution)
Electrolytic Capacitors can fail. When they do, you have a failed voltage power rail, or more than one.
ALL the lights used in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A typical Processor uses 55 to 125 watts.
Depends on what Processor it is.
[The MSI K8N Neo Platinum motherboard has a Socket 754 processor socket. Uses AMD Athlon 64 processors.
An AMD Athlon 64 processor that fits a Socket 754, can use 51 to 89 Watts.
Again, it depends on which Athlon 64 processor it is)
Solution?
Use another Compatible, Known to be Good, power supply for a test.
When you have conclusive proof that it is a bad power supply, replace it.
NOTE*
As stated, Do Not open your power supply to try to fix the problem.
The Electrolytic Capacitors inside, can hold a charge for Weeks, sometimes Months!
Should your fingers touch the terminals on the bottom of a capacitor, OR, touch a circuit that one or more capacitors are in,
the Charge could be released to YOU!
Shock ranges from BAD to FATAL!
Best method is to use a substitute power supply for a test.
Be Safe.
Jan 10, 2010 | Computers & Internet
4 red led's
This sounds like a corrupt BIOS, or another issue with the northbridge. It's possible the motherboard was cooked by your power supply, I've had it happen. You will probably be able to use all of your parts in your computer, but you'll more then likely have to replace your motherboard, and maybe processor. The harddrive, video card, and other parts should be fine.
Feb 05, 2009 | MSI K8N Neo4-F Motherboard
This card, I own one, is obsolete. Unless you find soneone who is planning to change from AGP to PCIe graphics, I don't think you will find one anywhere. 3dLabs sold the Wildcat line to Creative. Perhaps that route will profit you. I assume the usual searches have come a cropper. I would sell mine to you should I build my HTPC. It is a mite noisy for that purpose.
Sep 11, 2007 | 3Dlabs Wildcat VP880 Pro (256 MB) AGP...
3Dlabs Wildcat VP880 Pro (256 MB) AGP Graphic Card Logo
51 people viewed this question
Top 3Dlabs Computers & Internet Experts
David Payne
David Payne
Are you a 3Dlabs Computer and Internet Expert? Answer questions, earn points and help others
