Question about Tablets & eReaders
How to move app internal storage to phone storage?
Root your device. Then use System app remover. Transfer everything to SD card.
Jan 08, 2017 | Tablets & eReaders
How do I transfer apps and stuff to SD card on my trio stealth g5
If the tablet is running Android, in app manager click on the app you want to move and there should be a button 'move to sd card'. If it's 'greyed out', you can't move it.
May 28, 2016 | Tablets & eReaders
How do i move apps to my sd card
      Move Apps to SD Card Using Application Manager
      1. Navigate to settings on your phone.You can find the settings menu in the app drawer.
      2. Tap Application Manager.
      3. Select an app you want to move to the microSD card.
      4. Tap the Move to SD Card button. If you don't see a Move to SD Card button, the app cannot be moved.
      How to Move Android Apps to an SD Card - Tom's Guide,news-21279.html
    How to Move Android Apps to an SD Card - Tom's Guide > Android Apps > How-To
Jan 24, 2016 | Tablets & eReaders
How move downloaded apps to sd card
call your cust service for the manufacturer of your device
Dec 26, 2015 | Tablets & eReaders
How do i move apps to sd
Depends a little on the make/model and version of Android, but in general,
  1. Tap on "Settings" either on the home screen, or on the apps page
  2. When the "Settings" page opens, scroll down and tap on "Apps"
  3. Slide the Apps screen that opens to the left, until "ALL" is highlighted.
  4. slide down to the first App you wish to move. Tap on it
  5. in the detail screen for that App which opens, Tap on "Move to SD Card" and it will be relocated to the SD card!
Note that some Apps, and all system apps, cannot be moved to the SD card, and the "Move to SD Card" button for them will be greyed out and unavailable. Note also that a few Apps will not run properly from the SD and will have to be moved back - simply done as when selecting any App that's been moved to the SD, instead of "Move to SD Card", the same button will now say "Move to Tablet"
Dec 31, 2014 | Tablets & eReaders
I have an irulu tablet. I inserted a 32gb sd card. It says it is mounted and when i try to install an app from the google play store i get the message there is insuficient space available. how do i get it...
Most apps do not natively install to an SD card when downloaded from the play store. You have to have an app like AppManager, that has a function to 'move' apps from internal storage to an SD card, or use a manual option in the Android Settings section to move each app individually.. If you are that tight on space that you cannot load any new app, you may have to delete or move something from your internal storage so you can download AppManager or some similar app, and then move as many apps as you can to your SD card. If you have a lot of photos and music you can try moving that to the SD card if your player/viewer software will allow you to find it there. Best way to move bulk items (music/photos, not apps) is to connect to a PC through USB, which brings up your internal storage and the SD card as external USB storage items. Then copy from internal storage to SD card through your PC. Best to establish folders on the SD card to hold these items and then tell your app where they are.
Dec 03, 2014 | Tablets & eReaders
How do I get app to download to sd card on my kocaso tablet m760p
from "manage space" send it to sd card. Many apps are not permitted to be moved to sd card if you still want to remove then "root" your android device and get whatever you want. But first know everything about "root" then go for it. If you know what is rooting then you can do anything with the android device even making a app a system app, controlling frequency of your processor and many more!!
Jun 20, 2014 | Tablets & eReaders
Im using a tablet and I cant move apps and games to SD card
Hi if you want move apps to sd card go to settings, application and there press on the app which you want move. On the next screen you will see details about the app and a button move to sd card, just press it and the app gonna be moved to sd card. Bear in mind that some of the application can't be moved you will see then grey button.
Apr 01, 2014 | Tablets & eReaders
Move apps from sd to ext sd card
the applicatioin have to have the ability to be moved to an SD card
example: the app "fruit ninja" scroll or look near the bottom of the application page or whatever you call it it should say somthing along the lines of "modify to SD" or somthing then the app has the ablitiy to be transfer over an SD card and so on. if the app page does not say "modify to SD" chances are your not able to tranfer it over SD card unless you use your usb mini cord or whatever cord you used.
Mar 18, 2013 | Archos 101 Internet Tablet 16GB 10.1"...
Tablets & eReaders Logo
53 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
