Question about Maytag Dryers
Maytag naptunedryer heating but not staying on teil it dries
    Problem Solver:
  • 9 Answers
Check if it's overheating causing it to turn off.
Posted on Apr 26, 2017
Maytag naptunedryer dryer heating goes off before they get dry
One of your gas valve coil solenoids is defective. There are two of them. One has two contacts and the other has three contacts. They are easily replaced and you can get them fairly cheap on eBay. What is happening is the one good solenoid allows the burner to ignite but after a few seconds the burner is shut down because the second solenoid is faulty. Its a safety feature in most gas dryers. Replacing them should take care of your problem.
Apr 25, 2017 | Maytag Dryers
My maytag dryer is not staying hot to dry clothes
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
May 19, 2010 | Maytag Neptune MDG9700A Gas Dryer
Drying cycle doen't seem to turn off ....just seems to cook. Had to turn unplug the unit.
if this is electric dryer your heating element had short to ground cause element to stay on even if the dry turn off
Apr 25, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
My maytag dryer is not heating up or drying. The timer stays in one place, open the door and it does not!
the reason is more than likely you have lost one leg of your 240 volts and only have 120 volts now.....chk your fuses
Nov 03, 2009 | Maytag Performa PAV2200
Dryer element stays warm
If it heats w/ the timer in off position whenever plugged in the the element is shorting to ground, its most likely due to either a broken coil or a cracked insulator. If heating w/ timer set for drying but motor is not running, the heat circuit thru the centrifugal/start switch on the motor is stuck closed.
May 16, 2009 | Maytag MDE2600 Electric Dryer
Maytag Quiet Series 300 Legacy Series Dishwasher
Mine was doing the same thing and I just pressed and held down the heated dry button until the light went off. Then I was able to start my machine as usual. Hope this works for you.
Mar 12, 2009 | Dishwashers
Dyer LSG7804ABE Gas Stackable very little heat
self help is right .first i would try a load with out the ducting.if you have good air flow and still didn't dry[because now youv'e elimanated the house venting as a possiable.replace your coils
Jan 02, 2009 | Maytag LSE7806A Top Load Stacked...
Have you checked it for fluff. Also if the vent is blocked it wont dry properly.
Mar 22, 2008 | Maytag HYE3657A Electric Dryer
Dishwasher won't unlock
Jan 23, 2008 | Dishwashers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
