I want to do my matric - Office Equipment & Supplies
I need a matric level 7 matric certificate for my daughter
sorry but FIXYA does not have it ,nor do we know who does .
Mar 05, 2018 | Office Equipment & Supplies
Where do i go to restore my lost matric certificate
Certification Services - Department of Basic Education
www.education.gov.za/Informationfor/CertificationServices.aspx
  1. Cached
A change to an original certificate will not be considered unless the original certificate (not replacement) is returned. To change your name on your matric ...
Replace matric certificate ' South African Government
www.gov.za/node/727532
  1. Cached
  2. Similar
Apply for replacement of your matric certificate at the Department of Basic Education if you have lost or damaged your original matric certificate. You can request ...
Career Planet ยป Where can I get a replacement matric certificate?
www.careerplanet.co.za/where-can-i-get-a-replacement-matric-certificate
  1. Cached
  2. Similar
I lost my matric certificate. I damaged my matric ... Replacement (re-issue) matric certificate? I need a new ... (2) I damaged my matric certificate! What must I do?
Youth Village How To Recover A Lost Or Damaged Matric Certificate ...
www.youthvillage.co.za/.../heres-how-to-recover-your-matric-certificate-after-losing-i...
  1. Cached
Nov 26, 2015 - Please note: Applying for your lost or damaged matric certificate might differ from one province to another. Below is a guide to applying for ... restore my lost matric certificate Google Search
Jan 04, 2017 | Office Equipment & Supplies
I can't remember my matric examination number, can you help me please?
sadly we have no way of getting that information here on FIXYA
Jan 03, 2017 | Office Equipment & Supplies
How do i multiply to 4x4 matrices using fx-991 es ?
The enclosed screen capture shows all the possible dimensions for matrices on the Casio FX-991ES. As you can see the maximum dimension of any matrix is 3. You can only create matrices with dimensions less than or equal to 3.
Dec 01, 2010 | Casio FX-115ES Scientific Calculator
How to solve 7*3 matrices on casio scientific calculator
The enclosed screen capture shows all the possible dimensions for matrices on the Casio FX-119ES/991ES. As you can see the maximum dimension of any matrix is 3. You can only create matrices with dimensions less than or equal to 3.
Nov 30, 2010 | Casio FX-115ES Scientific Calculator
On which calculator can i solve 6*6 matrix
If you want to manipulate 6x6 matrices, you can use one of the CASIO Graphing calculators, such as theCFX-9850GPlus, or the FX-9750G plus.
Graphing calculators from other manufacturers can also handle such matrices. The FX-115ES can handle matrices with dimensions up to 3x3.
Nov 25, 2010 | Casio FX-115ES Scientific Calculator
I have a Casio fx-115ES; I have followed the manual for creating and multiplying matrices. The matrices have been simple, 2x2 for each, but it returns with "Dimension Error". Any suggestions? Thank you for...
Calculator should be in [MATRIX] MODE
Try the matrices 2X2 matrices matA [1,2,3,4] matB [5,6,7,8], Add them, subtract them, multiply them, take the square of each. If that works for these matrices, then it must be your data. Be careful with negative numbers. To enter those, you must use the change sign (-).
There is also the possibility that the instructions were misread.
Dec 14, 2009 | Casio FX-115ES Scientific Calculator
How do i solve a matric problem with a TI- 83+
You should try to use the correct heading.
Press [2nd][Matrix] right arrow to [EDIT][ENTER] to create the [A]
matrix. Exemple of a 3x3 Matrix [A].
Once the matrix [A] is created you press [2nd][MATRIX] -->[MATH]
You can add similar matrices, you can multiply matrices, subbtract them, raise a matrix to a power, extract the square root, etc...
Here are the other operations you can pefrorm on matrices. Sorry I cannot go into the detail of things;A minimun of theory is needed to be able to use the commands.
Oct 14, 2009 | Casio FX-115ES Scientific Calculator
24 people viewed this question
k24674
jasbo
jasbo
