Question about Vacuums
My rumba will not recharge even when sitting on the docking station.
I have roomba 880 stationed in open w/nothing blocking view (virtual walls, lighthouse, doors, etc) but it will not go back to docking station even when I press docking and its only 6 feet away.
it seems as if the robotic cleaner is having a problem sensing where it is or failing to notice where its charging station is try cleaning any optical/IR sensors and it maybe able to see once again where its charging dock is
Jan 06, 2017 | Roomba Vacuums
How do you know when the battery is charge
Hi there, it's Jack at Dyson.
If your machine's charge has been completely depleted, it will take a maximum of 3.5 hours to recharge again completely. When it's fully charged, the light on the charger will go out. You can either plug the charger cord directly into the machine, or store and recharge the machine in its docking station.
I hope this helps, but if you'd like any further information you're welcome to contact us directly. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 29, 2014 | Dyson DC35 Handheld Vacuum
Green light on DC44 but nothing is happening
Hi Emma, it's Jack at Dyson.
I'm sorry to hear your DC44 Animal doesn't seem to be working correctly. If the green LED indicator on the machine lights up, but the machine itself doesn't run, this suggests the battery is flat. It could mean that it's not recharging correctly when connected to the docking station.
It would be worth temporarily disconnecting and removing the charger cord from the docking station and plugging it directly into the machine - the machine should recharge fully within 3.5 hours. If the machine then works as normal the charger cord may not have been corrected fitted to the docking station.
If you'd like further advice from our experts after you've given this a try, please call the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jan 01, 2014 | Dyson DC16 Root 6 Bagless Handheld...
Rumba making Clicking noises - stops It has been cleaned.
even if the 2 brush rollers are clean you need to pull the small yellow ends of the roller off [the funny lookin ones].hair ect. get jamed in there .use a knife or small screw driver to pull the build up out.hope this helps
Jul 13, 2010 | iRobot 53501 Roomba 500 Series Vacuum...
I unplugged the docking station and now does not work
I actually had the same issue with mine.. it was 6 years old and just stopped finding the docking station. Also wouldnt take a charge. So I just eliminated the docking station. The stations power cord will charge the unit. Hope this helps.
Sep 12, 2009 | Roomba Robotic Floor Bagless Vacuum
Roomba Docking Station
Probably not, unless you just have to have the docking station. My roomba always had trouble mating with my docking station so I never used it. I just plugged it directly in to will using the AC adapter.
Oct 29, 2008 | Roomba Robotic Floor Bagless Vacuum
The PCB controlling the battery charger is overheating and the led dosen't illuminate when charging, could the led be shorted internally causing the problem. The vacuum in question is a Hoover Freejet...
The problem was caused by the failure of 7 of the 1.2volt cells in the battery pack, the other problems were symptoms of the battery pack failure. Replaced the thermal cutout a 131 degree C component on the PCB in the docking station for the vacuum when recharging, I also had to change the LED which had also failed this is a Red 12 volt 5 mm dia component observe the correct polarity when replacing. Also make sure when replacing the thermal cutout that it is secured tightly to the resistor it sits along side, otherwise it will not respond quick enough if there is another failure.
Jun 22, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
