My practically new propane patio heater fell over this winter and now it appears there is no gas coming up to the ignitor and burners. Could the tilt switch be stuck in place? Could tank be damaged?
  • 41 Answers
SOURCE: Endless Summer Patio Heaters won't stay lit
Hi ColdinSF,
You need to remove the covers from the unit and blow out the gas lines with compressed air. If you can remove the gas lines blow out the lines and what they connect to like the pilot light and main feed line to the burner. Usually they gunk up with use and just need to be blown out with compressed air to clear the lines again. Maybe you have some dirt or foreign object from your gas tank which has clogged the line. Also check the igniter electric lines as well and make sure everything is connected properly. Especially make sure you tighten the gas lines you remove. Hope this helps.
Regards
Bryan
Posted on Dec 22, 2007
  • 148 Answers
SOURCE: pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
Posted on May 12, 2009
SOURCE: Patio heater won't stay lit
I had this same problem - here's how I fixed it...
First: Never modify the safety features of your heater as has been suggested elsewhere on this forum. Modification of these features may allow the heater to work, but greatly compromises the safety of anyone near the heater.
The problem with the heater shutting off is most likely due to not enough gas flowing through the pilot orifice (this orifice is almost as small as the diameter of a human hair). When this happens, the pilot flame does not burn vigorously enough to activate the thermocouple. Hence, the thermocouple shuts off the gas and the burner goes out - usually you'll hear one "click" when this happens.
This is a maintence thing - meaning you may have to do this as a seasonal activity.
Here we go....
(1) Shut off the gas at the tank - or remove the tank entirely.
(2) Remove the screws that hold the burner shield and top shroud from the unit - set it aside.
(3) Remove the control knob - it just pulls straight off.
(4) Remove the panel immediately behind the knob you just took off. This will expose the gas valve assembly.
(5) Remove the cover that encloses the bottom of the pilot light/igniter (assembly). This will expose the bottom of the pilot assembly.
(6) Remove the screw holding the pilot assembly - there is a small hex nut on top, but under the burner that you'll have to hold to prevent it from turning. This will free the pilot assembly allowing you to gently pull it out of the pilot assembly housing. DON"T pull hard or you may break the gas line or thermocouple.
(7) Remove the hex nut that attaches the gas line to the pilot assembly and gently pull the gas line out. At this point, to ensure you have gas flowing through the pilot gas line, you may want to re-attach the gas tank, turn it on, gently move the gas line as far away from the spark ignitor as possible, temporarily replace the control knob, and turn the knob to the "Pilot" position & push it in. DO NOT DO THIS ANYWHERE NEAR AN OPEN FLAME OR A LIGHTED CIGARETTE! You should be able to hear a hissing sound as the gas flows. If you do not hear it, the problem may be with your gas valve, and if that's the case, I'm sorry this procedure likely won't solve the problem.
(8) Remove the pilot light tube (orifice) from the mounting bracket. There's a hex nut on the back side that holds it in. Be careful not to damage the hex nut or the threads. You'll need a pair of pliers (to hold the bracket) and an adjustable wrench for the hex nut. Make note of the orientation of the pilot burner diverter so you can put it back together the same way it came apart.
(9) Using a blast of compressed air, blow air through the pilot orifice. You should be able to see just a very (and I mean very) small pin-point of light through the pilot burner. If not, use a single strand of very fine wire - like one strand from a 18 gauge braided electrical wire - and run it through the pilot orifice. Carbon build-up can clog this orifice - which can prevent the pilot from burning vigorously enough to heat up the thermocouple. Cleaning it out periodically will likely solve the problem.
Put everything back together in reverse order as noted above - making sure your gas fittings are tight and don't leak. Once it's all back together, light the pilot flame as normal and once the thermocouple heats up, the heater should work like a charm.
Posted on May 25, 2009
  • 10865 Answers
SOURCE: Propane patio heater ignition problem
I would change the thermocouple and here is why:
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to sustain burning the gas fuel from the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
How the Thermocouple Works
So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close. Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners
Posted on May 27, 2009
  • 141 Answers
SOURCE: fire sense patio heater won't light...
you prob need a new theromocuple on your pilot or just cleen it with sandpaper this may help
Posted on Apr 14, 2010
Gas doesn't seem to be flowing
I purchased this heater second hand - I have fitted a brand new regulator and gas hose - gas is flowing as far as the burner assembly but I cant hear or smell gas flowing to the pilot or the main burner. Is there a section of pipe between the gas hose and the burner that could be missing? Does anyone have a diagram of all the parts - exploded view?
May 30, 2014 | Stainless Garden Sun Steel Propane Patio...
Hear sound after few minutes and then shuts down
Check the gas cylinder is full and using propane (butane is not good in very cold weather). Make sure there are no leaks, to do a leakage test see patio heater problem solving. If all OK the most likely cause will be a worn thermocouple, this can cause the burner to turn off.
Oct 26, 2011 | Stainless Garden Sun Steel Propane Patio...
Not getting any propain to my patio heater
First check the gas, connect the regulator to the cylinder but unclip the hose and do not light the heater. Turn the gas on for a second to see if the regulator is working OK. Next make sure there are no blockages in the pipes up to the burner. If all clear then vent the pipes to clear all air. If still not getting any gas the problem could be a faulty tilt switch cutting the gas supply or a worn thermocouple. Short out the tilt switch to test and if not fixed then change the thermocouple. Found this site very useful with tips patio heater problem solving.
Sep 01, 2011 | Rta International Patio Heater
I have a giordano heater that won't light. There is a narrow pipe that diverts gas to the igniter spark. The pipe is capped by a small metal regulator with what looks like a very small hole in it to...
Never drill or try to make the pilot hole larger, this will cause a large flame that cannot be controlled. Check the main parts, first see if you have a spark, next check for leaks, to see how to do a leakage test see patio heater problem solving page. If no leak try changing the thermocouple, these will wear out and can last up to 6 years. Also check the electromagnetic valve that sits inside the gas control valve and if fitted check the tilt switch works. The tilt switch can be shorted out to see if it works.
Aug 03, 2011 | Stainless Garden Sun Steel Propane Patio...
We have a hss-a-sh patio heater and we are having problems lighting. i know it could be the termocouple,but is the switch with 2 wires on it a tip over switch to cut off the gas. can we jump it out to...
Simple answer is yes, by shorting out the tilt switch it will let you know if the tilt switch is working. Before getting a new thermcouple check the thread size, the main ones out of China are 8mm but some are 10mm. On average a thermocouple will last between 2 years up to 6 years.
May 20, 2011 | Stainless Garden Sun Steel Propane Patio...
Portable patio heater is a DCS Phoenix Professional Patio Heater Model PHF8-DWBZ-L. Burner ignites and operates for a few minutes. Then teh flame is reduced to a short yellow flame. Regulator is covered...
The regulator covered with frost is the problem. It freezes the gas and the gas line up. But, usually this only occurs when it has been exposed to subfreezing (in the teens) temperature for a long period of time. The quick fix, is to soak a bath towel in hot water, ring it out and quickly wrap it around the regulator. Once it thaws, the gas will start flowing again and you can light the burner. Generally, once it's flowing and being used, it won't freeze up again, right a way. Most propane companies add ethanol to the propane in the winter, to help keep it from freezing in the lines and the regulator.
Hope this helped answer you question and provided, at least a quick fix solution.
Apr 21, 2011 | DCS PHFS Phoenix III Outdoor Patio Heater
I have a sterling forge propane patio heater and the burner screen is rusted out. The screen is 10 3/4 inches in diameter and I don't find any that size. Also the dome is 36" with a center hole for...
Doug - Patio heater parts are pretty universal from one manufacturer to another. Especially so, for the parts you need. AZ Patio Heaters carries a large selection of universal fit parts, as well OEM parts.
Here's a link to their website http://azpatioheaters.com/home.php?cat=2&gclid=CLOGyd-DnKgCFQl_5Qod_29hHg
Hope this helps you find what you need.
Apr 14, 2011 | Sterling Forge SFP40PT Gas Patio Heater
I need to convert a Endless Summer Blue Rhino patio heater Mod. No. 233010 from naturalm gas to propane , what do i need
You would need new pilot and main burner orifices. You would also have to ask the dealer/manufacturer if the valve on the propane heater will work with propane. It may not because the propane tank will have to be connected to the heater using an LP hose and regulator. You would then need to take apart the heater to install the new orifices. Considering the cost of a new heater that is set up for LP, I do not believe the conversion to be practical.
Feb 24, 2011 | Blue Rhino Uniflame - 233010 - Endless...
Coleman 5040 Patio Heater w/ Light - Light works, Heater does not
BE VERY CAREFUL sticking matches in any propane appliance! With the gas OFF see if you can physically see the spark when you push the ignitor, if yes, the problem may be the regulator or bottle pressure the only test i am aware of for the regulator is replacement.
Jul 13, 2009 | Coleman (5040B750) Patio Heater
Hi ColdinSF,
Regards
Bryan
Oct 19, 2007 | Endless Summer gwt501a Open Flame Patio...
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
