Question about Power Computers & Internet
My phone has been rebooted but I can't remove the power failure message from the message window.
Bbot keyboard failure error message
plug in a usb keyboard and see if that works, then reset bios to default, reboot. if that doesn't work then possible hardware damage eg liquid damage, droped etc
Feb 01, 2014 | Dell Latitude E6530 Laptop Computer- 3rd...
LG Keybo2 Will not stay turned off, have removed battery to try and reset but when I put battery in, just reboots, hold down the OFF button, turns off but then immediatly reboots and turns back on
F keys don't work on reboot. Work on Power on boot.
When powering on the F2 key will get me to Bios Setup, F8 key will get me to Safe Mode, and F12 key will let me change Boot Device. Everything is normal when up on XP operating system. If I reboot, None of the mentioned function keys work. Instead I get a message of a "Keyboard Failure", but system will come up OK. But, on the reboot, I want to use one of those function keys.
I have a DELL 2400 Dimension running Windows Home XP. I am using a Logitech EX-110 (Combo keyboard & mouse)
This seems very similar to another write up on this site.
Any ideas? Don't tell me to toggle the keyboard. I tried it with no positive results
Dec 02, 2012 | LG 10X DVD IDE 452000078
Media test failure message. Reboot and Select proper boot device
A hard disk failure can be catastrophic if it jeopardizes the data stored on your computer.
In addition to rendering a laptop inoperable, a failed hard disk can damage other files stored on the drive as well.
It is critical to determine whether an actual drive failure has taken place, and there are several steps to troubleshoot a drive before hard disk failure can be declared.
Unplug any devices such as printers, speakers, cameras and other external peripherals. Boot the laptop by pressing the power key.
If this does not result in a successful boot, try booting Windows in "Safe Mode."
Reboot the computer, and hold down the F8 key this will vary depending on your computer and operating system
From the menu choices, choose "Boot Windows in Safe Mode".
If the boot up progresses, then the computer is likely experiencing a software issue, not a hard drive failure.
Reset the hard drive.
This will involve turning off laptop (removing the battery is a good move, too) opening the laptop unit, and unplugging all connections and cables from the hard drive.
If possible, replace the hard drive with another drive.
This will help determine if the hard drive is causing the problem.
Plug all connections back in to the hard drive, and reboot the computer.
Repeat Step 2 if necessary.
If the computer does not reboot, the laptop is more than likely experiencing a hard drive failure and will probably have to be repaired by vendor.
hope this helps
Oct 09, 2012 | mpc X3000 Laptop Transport 14.1" Barebone
Phone freezed what can i do
Cell phones freeze for a number of reasons:
a) OS (operating system) bug/failure
b) excessive temperature
c) hardware malfunction
d) keyboard key malfunction
Unfreezing a cell phone frozen b one of the above causes follows just one procedure, however:
1) reboot with a power cycle, using the power on/off key
if that fails,
2) reboot by removing cell phone battery and holding down the power button with the battery out for 5-10 seconds (this drains the remaining battery power stored in PC board capacitors).
Replace battery into phone and power it on.
3) If that fails to unfreeze your phone, seek a Samsumg electronics technician for the phone's hardware fault. Also,
check your phone's warranty - warranty service may be an option.
Mar 16, 2011 | Samsung Lands Phones
What will happen to the hard drive in power failure?
Power failure as in whole house power failure? Or the computer's power supply failure?
Whole house failure, nothing, the computer will shut off and require rebooting, at which time you may receive a message the computer was not properly shut down, just continue as normal.
Computer power supply failure, same thing, nothing, except the computer will not reboot as the power supply has failed.
Jun 15, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
IT SAY SIM LOCK AND ASKING THE CODE
This may not work on all Samsung phones!
THIS IS THE TEMP UNLOCK CODE FOR A SAMSUNG PHONE
Do this at your own risk:
Instructions
Press *#06# and write down your IMEI
Unlock Codes
Code 1: *2767*688 then your IMEI and then press #
For example *2767*688352708000828246# (Everything before the / for C225)
Code 2: *0141#
Code 3: 00000000 (8 zero's)
Entering the Codes
1. Switch your phone off. Remove the original SIM card 2. Insert another SIM card from an alternative network. Power up your phone. You should now see the "Wrong Card" message. 3. Type Code 1 into your phone, if this is entered correctly your
phone screen should now turn black and reboot itself. (C225 doesn't go
black but does reboot) 4. After the phone reboots the SIM card will be recognized and your
SIM will work. Be patient while your phone reboots and DO NOT press
any keys. At this point the phone is "Temporarily" unlocked.
5. Now at your idle screen type in Code 2 (*0141#) and hit the call button.
This should give you a message saying the phone is "Personalized". 6. Power off the phone and insert the original SIM, then power up. 7. At the SIM code prompt, it will ask you to enter a password. At
this stage enter Code 3. 8. After entering hit "OK" and your phone should complete initialization.
[/b]Instructions[/b]
Unlock Codes
Code 2: *0141#
Entering the Codes
any keys. At this point the phone is "Temporarily" unlocked. 5. Now at your idle screen type in Code 2 (*0141#) and hit the call button.
Your phone is now Permanently unlocked.
Another easy way is you put in a foreign sim put in the code *2767*2878# much easier and works just the same.
*2767*688 <your IMEI number>
Jan 09, 2010 | Samsung SGH-X820 Phone
Won't reboot....Dell screen comes up, brief
I'm pretty sure that you are having a boot failure, not all to figure out is whether the HDD is bad or just the operating system having a problem.
Hold the Fn Key and press the power button to start diagnostics on the system and see if you get a hard drive failure message. If you do replace it. If diags pass, then try booting to the Windows XP CD, and run CHKDSK /R at the recovery console (Press R at 1st prompt to enter RC)
Dec 10, 2009 | Dell Latitude D800 Notebook
Problems installingMotorola Phone Tools v 4
Try removing with (windows add/remove programs) reboot the computer and then reinstall the software and phone device.
Mar 25, 2009 | Motorola Mobility Mobile PhoneTools 3.0...
Power failure message.
Power Failure Recovery
If the system is disconnected from the AC power it will not operate. Your announcemen and messages are retained in memory during a power failure but you will need to reset the clock. See the instructions on the bottom of the unit. If the message window displays CL, you need to reset the clock. See the instruction on the bottom of the unit.
Mar 11, 2008 | AT&T 1726 Digital Answering Machine
Computer will not turn on
The only things that can do this are: A card failure, a hard drive failure, Motherboard faiulre, A Power Supply failure, Faulty RAM. To toubleshoot.. disconnect Hard Dive, CD/DVD remove any & all cards, see if it boots,if it does, add the Hard Drive, reboot, then add the CD/DVD, reboot, then replace A card, reboot & so on... until ya find the faulty component, that stops it. If it doesn't remove ram & see if it powers up, it will NOT boot. If it doesn't ya PSU is most probably faulty. If it does ya RAM/motherboard is faulty. So basically strip it down see if it powers up. than add things one at a time to find the culprit.. then replace the ofending item.
Aug 06, 2007 | HP Compaq Ethernet Switch
Computers & Internet Logo
22 people viewed this question
Top Power Computers & Internet Experts
waruna
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
