Question about Lands Phones
My handset for Model-KX-TG5633 Keeps disconnecting and says too far from base. Am right next to base
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
  • 15 Answers
SOURCE: kx-tg1100
On your handset go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
This will discard the registration of the handset to any base.
Then go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
After you finish all the above, hold down the "PAGE" button for about 5 secs.
You are now done!!!
Good luck
Posted on Nov 23, 2008
SOURCE: Phone says I am too far away from the base--panasonic kx-tg2356s
unplug the base unit and when you plug it
back in the handset should work
Posted on Feb 07, 2009
SOURCE: i have problems the no link to base with Panasonic
  • Press and hold the LOCATOR/INTERCOM button for the extension that is displaying "No Link To Base" on the Base until a beep sounds.
  • Press and hold the FLASH/CALL WAIT button on the Handset that is displaying "No Link To Base" until a beep is heard.
  • When registration is complete, a beep sounds from the handset.
  • Wait for 20 seconds after registration is complete to allow the handset to establish communications with the base.
If this doesn't work or it keeps happening, replace the battery in the handset.
Posted on Jul 08, 2009
  • 5297 Answers
SOURCE: I want the user's manual
The handset manual is here: (you'll need to rate the product or enter security code to download).
I hope this helps.
Posted on Jul 28, 2010
Testimonial: "It really was useful, as now I can set the settings on my phone and get the ful out of my phone."
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
My phone display's No link to base. Reconnect main bas AC adapter. It is plugged in what now?
I had this problem, and I fixed it by re-registering the phone to the base. Here are the directions for how to do that from the manual:
Registering a handset to the
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
handset is not registered to the base
unit, re-register the handset.
1 Handset:
2 {V}/{^}: "Initial setting"
3 {V}/{^}: "Registration"
4 {V}/{^}: "HS registration"
5 Base unit:
- KX-TG4011 series:
Press and hold {LOCATOR} for
about 5 seconds. (No registration
- KX-TG4021/KX-TG4071 series:
about 5 seconds until the
registration tone sounds.
If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
The next step must be completed
within 90 seconds.
6 Handset:
Press {OK}, then wait until a long
beep sounds.
While registering, "Base in
registering mode" is displayed on
all registered handsets.
When you purchase an additional
handset, refer to the additional
handset's installation manual for
See (page 22)
Dec 06, 2011 | Panasonic KX-TG1033S Cordless Phone
Panasonic kx-tg2730 my extra cordless phone (2) tells me i'm too far away from base (1) when i'm right nexr to it. how can i connect it to the base?
One of the functions of your handset is REGISTRATION or RE-REGISTRATION. It involves stepping to that command, pressing enter, then pressing the handset locator button on the base and the two units can link up.
Apr 09, 2011 | Panasonic KX TG2730 Cordless Phone...
I have a Panasonic KX-TG5633. It has worked fine for several years. suddenly one of the handsets no longer syncs to the base. I've followed the instructions to register it to the base, but it refuses to...
I am so tired of all the answers that don't help by repeating standard answers that you already know won't work or giving directions for a totally different product. The fix here is simple but not easy. It's either a bad charging/battery connection, a bad battery or both. Low power will cause the exact problem asked here.
As the phones get older, and I'm specifically talking about Panasonic cordless KX-TG563x but this may be true of other rechargeable devices, the metal contacts for charging and battery do not make a good connection like they used to. They may look perfectly fine and free of corrosion but are not actually making a good connection.
Symptoms include the phone getting hot while charging and not holding a good charge. The phone may show 3 bars of charge but still blank out like the battery is dying. With these Panasonic phones, weak battery will cause the phone to unregister and will give false charge level readings in the display. If your phone gets hot when charging, this is most likely your problem.
I had this problem with several handsets and used contact cleaner on the charge base, the phone contacts, the battery contacts inside the phone and on the battery itself. It fixed all the registration, heating and charging problems. I had one stubborn handset I had to clean multiple times but it's now working like new as well. I used DeoxIt contact cleaner from Caig, bought it on eBay. Great stuff. If repeated cleaning of the contacts with a good contact cleaner does not fix the phone, replace your battery. Use contact cleaner on your new battery for best connection. Ebay is a good source for replacement batteries as
well. Good luck!
Feb 11, 2011 | Panasonic KX-TG5633B Trio Cordless Phone
I have a panasonic cordless phone, model kx-tga820. for some reason both handsets now say that it is busy when i push the talk button. Our other phones are ok. Why?
If you get busy tone in your Panasonic KX-TGA820 cordless phone, it may be due to any one of the following reasons:
1)The called handset is in use.
2)The handset you are calling is too far from the base unit.
Check whether the base unit is not so far from the handset
3)There is no handset registered to the base unit matching the extension number you entered.
Try to re-register the handset to the base unit again, To know details regarding registering and re-registering, please refer page 38 of the manual, which you can download from the link given below
4)Other units are in use and the system is busy. Try again later.
Try to check whether the other units are not using your base unit
You can download manual for your phone from the following link for reference
Please rate this solution
Nov 10, 2009 | Panasonic Lands Phones
Hi! This may cure your problem!
Re-registering the handset
If “No link to base. Move closer
to base, try again.
” is displayed
even when the handset is near the base
unit, you may need to re-register the
handset to the base unit.
LMake sure the base unit is not being
LHave the handset and base unit near
each other when re-registering the
LKX-TG5422 and KX-TG5423 only:
Confirm the extension number of the
handset which has lost its link to the
base by placing the handset on the base
unit or charger.
If you accidentally assign another
handset’s extension number to it, the
other extension will stop functioning.
1 Handset:
Press {MENU}.
2 Scroll to “Initial setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Registration” by pressing
4 KX-TG5421 base unit:
Press and hold {HANDSET
} until the CHARGE
indicator flashes.
KX-TG5422 base unit:
Press and hold the handset locator
button that corresponds to the handset
you want to re-register ({HANDSET
1} or {HANDSET
2}) until the CHARGE
indicator flashes.
Below is a link that will take you to the instruction manual for your phone.
Hope this helps! Hal
Feb 27, 2009 | Panasonic KX-TG5422M Cordless Phone
Jan 24, 2009 | Panasonic KX-TG2356 Cordless Phone
Phone issues.
1st) you must identify the ranking order of your handsets. Put all your handsets in the main base cradle and it will tell you which phone is your handset ie: (1) (2) (3) (4). (if you are reseting a handset, chose a number that is missing to reset your phone to) Now, with NO handsets in the main base cradle. Hold your phone and press "menu", then key in the numbers 00. Now, don't do anything with your handset. Go to the main base cradle. On the bottom, where it says "locator" press the "select" button until you get the desired phone rank needed. H1,H2,H3 etc... Then, press and hold the "call" button, under "intercom". (The charging light should start flashing) Now, go to your handset and press the "OK" button on the top upper right corner. At this point, your phone should be working!
If you are still having problems, call Panasonic Customer Service at 1-800-211-7262 for tech support. PS: your handset may show model KX-560B, but your main cradle base will show the actual phone model listed as KX-TG5633
Mar 14, 2008 | Panasonic KX-TG5633B Phone
No link to base Panasonic KX-TG2357
Astoundingly, the KXTG2357 works only with the original handsets it came with! You cannot replace a handset by buying another one (same model, of course) and register it with the base. How ridiculous is that? It's like buying a lamp that works only with the bulb that came with it. Replacement bulbs won't work. Well, Panasonic is one company I won't be dealing with anymore!
So, the solution is to get along with one less handset, or buy a new phone unit!
Jan 05, 2008 | Panasonic KX-TG2357 Cordless Phone
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
