Question about Video Game Consoles & Games
Cant find my coins - Video Game Consoles & Games
I have Been playing this game for a while and for the Past couple of weeks i have Lost so many coins and have to but more to finished the game! If you Cant replenish my coins i Will not play
fixya cannot / will not replenish your coins as we have nothing to do with any games, money, coins.
If you bother to read the page you will see that it is an answer questions site and not a game site
Dec 11, 2015 | Video Game Consoles & Games
HOW cant i get star coins on star stable?
Star Coins are an in-game currency for Star Stable. You have to purchase those. If you're a member, you will get some each month but, can purchase more from them.
Any other hack / trick / etc is not legal and can not be assisted. Thanks.!
Jun 10, 2014 | Computers & Internet
Speed queen commercial dryer model sdg109wf, the coin compartment is stuck because of compartment was full, after emptying the coin slider doesn't come out so we cant use the dryer. what is the...
Oh your bringing me back to the early days of my appliance repair career when i only serviced coin operated washers and dryers. Not in the coin box but the cover on top where you would get access to the timer is a bolt that holds the coin slide to the coin box asm. remove that bolt(if i remeber from 25 years ago its a 5/16th inch hex head and brass colored) and the coin slide will come out and then gotta kinda genlty presuade it in with a hammer so the coin will drop through or pull on the handle ya would push, to free it up and remove stuck coin
Aug 20, 2011 | Dryers
Please help me 4 problems concerning super mario bros star coins world 5-4 the last coin cant get world 6-5 cant find last coin world 7-6 cant...
Here try this one.
WORLD 5-4
You can find the Star Coin at this stage of this world. Look at the photo. heifentrixx_22.jpg
  • At this stage, you should pick up a Bob-Bomb and then quickly jump to the ledge.
  • Drop the Bob-Bomb in the white blocks to get rid of some of it and then drop down to the raft.
  • The Star Coin should now appear.
  • pick it up and then enter the pipe above.
WORLD 6-5
You can find the last Star Coin in a Secret Area with a Secret Goal.
  • Look for the four item box in the water. like in this photo. heifentrixx_23.jpg
  • You will need to jump or swim in the middle of the four boxes to reveal a hidden box that contains a beanstalk.
  • Climb up the beanstalk to reach the other area.
  • In the Other Area, you will need to pick up a propeller block.
  • Get the coins and the go right to the second floating box.
  • From this box, you will need to spin to reach the Star Coin and the Secret Goal.
WORLD 7-6
  • After you came across some small parabeetles,then you should come to a line of big parabeetles.like in this photo. heifentrixx_24.jpg
  • Look down low and you should see the Star Coin poking above the low clouds.
  • Ride down to the Star Coin using the Last Big Parabeetle.
  • Then wait for the small parabeetles. and then Jump down to get the coin and step on the small parabeetle. (Be careful in this part, you should jump at the right timing so that you wont fall off the clouds.)
WORLD 8-7
  • You should ride the next platform down as you jump a geyser like in the photo. heifentrixx_25.jpg
  • Stay near the front of the the platform so that you can grab the Star Coin before hitting the geyser.
  • After getting the Star Coin, quickly jump to the platform above you to avoid the geyser.
Thats it. Goodluck, Hope my solution helped. Please give some feedback regarding my solution.
Thank you for using Fixya! Have a Great Day!
Jul 13, 2011 | Nintendo New Super Mario Bros for Wii
How do i solve my negative coins problem in farmville? i have 2 billion coins and now they have a negative symbol i cant buy anything and if i sell some of the things i have in my farm my negative coins...
Hi! I did a little research on your problem.
What happened was that when you exceeded 2,147,483,647 coins in Farmville, your coins will become negative. I believe that this is used by the developer to stop cheaters. The only way to come out of this is keep making money until your negative coins even out and then you can start building up money again!
Good Luck!
Jun 12, 2011 | Zynga FarmVille by Zynga
Pls help me... my dvd rom have coins inside.i didnt know.i put cd and then it cant open and i cant take out the cd aswell. my laptop is dell studio 1435... pls help me...
Look at the cover near the cd slot - it should still have the hole. You mention coins inside - kids? It seems probable that the cd was installed with power on, but you will still have the hole - it's small so that a paper clip will just fit into it. Since you have the coins probably still in there, I would disconnect power, remove the cover and pull the cd driver from the tower case. More than likely the cd and cdrom drive will be damaged beyond repair, but if you remove the drive from the computer you'd be able to shake the coins out of it and also to be sure the coins aren't going to short out *********** board. If you can do that then you might as well reinstall everything and put it back together, then power it up to check it. Who knows you might get lucky...
Sep 23, 2010 | Dell (JP-03G005-26401-16R-H324)...
There is an equilateral triangle. in it there are three coins of equal radius is placed. find the radius of the coin.
how big is the triangle? if the coins are a mile in diameter doesnt mean you cant have an equilateral triangle with legs of 32 miles long.
or are you asking for the equation?
i will send you on the path to the equation.
if you draw a circle on a piece of paper then draw a triangle around it where is the center? if the triangle were a perfect equilateral then the circle would be a perfect circle touching the sides of the triangle.
its important to know where the center is because the center of the circle to the edge of the circle is the radius.
so the center of a triangle is the center of the circle. therfeore the radius of the circle will equal hieght/2...
thinking that way you can say that if there were three coins then the center of the triangle cant be occupied by a coin but is very close to an edge. where is the center of the coin?
Jun 10, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
Cant find the middle coin on level 7-a! please help!
From " Star Coin Location Guide" by RX7InfinitiIII in www.gamesfaqs.com:
Stage 7.A
Coin 2: In the second "area", there is a cannon on the right sidethat will shoot you straight up. As you begin to fall back down, slide down the right wall. Walljump to the left when you see an opening in the pipe on the left, then enter the pipe from below. You will be deposited next to the coin.
Aug 24, 2009 | Nintendo New Super Mario Bros. for DS
Cant find W6-A secound coin
This one took me ages to figure out as well. Just below the first coin
and a bit to the right, about a quarter of the way into the level,
there is a sand waterfall. It is very skinny; about 2 blocks wide. Let
yourself be sucked into this. Slide down the left wall of this new area
and simply walljump up to the coin.
May 24, 2009 | Nintendo New Super Mario Bros. for DS
A coin inside it
take it all apart u will ne small torx screw drivers from sears ok to get to it take it apart then lid off u can get coin out ok
Feb 01, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
22 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
