Question about The Computers & Internet
My ADP3203 doesnt function after change the battery. Its just show TURN BEZEL. I try turn it but a 899 and 002 and 0011 and followed by R2. And it show TURN BEZEL again.
4 Suggested Answers
  • 349 Answers
SOURCE: after changing the batteries, mouse
you need to sync the mouse with the receiver unit by holding in the small button on the mouse and the receiving unit
good luck
Terry
Posted on Apr 10, 2008
tparsenault
  • 170 Answers
SOURCE: computer not functioning well at start
Have the same problem, went to live chat on hp web site, they are going to do a one time fix at no charge. Seems there are a lot of issues with this model.
Posted on Dec 28, 2008
  • 1739 Answers
SOURCE: 1.I believe my 3H mbm
Try looking at the available manuals listed here:
http://www.luminox.com/service/service-centers/
I don't see one specific to your model; however the manual for Standard / All Models might provide sufficient direction.
If this is not helpful try contacting Luminox directly for assitance as per the following:
http://www.luminox.com/service/contact-us/
Posted on Jun 11, 2011
No LCD Display on Dell Vostro 1700 - 17"
It sounds like you have been pretty thorough trying to resolve the lcd problem
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 13, 2012 | Dell Vostro 1700 Notebook
Want to turn off Auto-restart function of haier split ac
I do not know anything about this but from a manual I have seen its tied in with Timer and Sleep functions there are a lot of instruction manuals ou on the web but you description is to generic you need a model number of which there are a lot.
HSU-09LEK13/R2(DB)
HSU-12LEK13/R2(DB)
HSU-18LEK13/R2(DB)
HSU-24LEK13/R2(DB)
HSU-09LEK03/R2(DB)
HSU-12LEK03/R2(DB)
HSU-12CKAS(R2DB)
HSU-18CKAS(R2DB)
HSU-12HKAG(R2DB)
HSU-18HKAG(R2DB)
Just a sample look for a number on the device which may be under a cover.
As its software controlled they do need to reset themselves as to how long this takes varies from machine to machine.
Hope this helps
Apr 05, 2012 | Heating & Cooling
The back light is out, how to turn it on?
1.Check your monitor brightness setting. Occasionally, the monitor brightness can get accidentally turned all the way down. This will result in a completely dark laptop screen that appears to lack a backlight. Adjust the monitor brightness via the dedicated brightness keys at the very top of your laptop's keyboard.
2.Toggle the backlight back on via the keyboard. This is accomplished by using the "Function" key, which lies near the bottom left of your laptop keyboard and is marked "Fn." When pressed in conjunction with one of the "Fx" keys on the top row of your keyboard, you can toggle the backlight on and off automatically. There is an "F1" key, an "F2", and so on. The exact key to press simultaneously with your "Fn" key will vary by laptop model, so consult your computer's user manual. You may have accidentally toggled the backlight off and simply need to toggle it back on via this key function.
3.Prepare to operate on your laptop if you cannot toggle the backlight back on. Shut down the laptop. Disconnect the AC adapter cord from the back of the computer, then close the display and turn over the computer.
4.Remove the battery. The battery on most computers is at the top of the laptop's underside, although some computers may feature the battery in a bottom corner. The horizontal outline of the battery will be clearly visible all the same. Beside or just beneath the battery will be a battery-release latch. Slide this to disengage the battery.
5.Turn the laptop back over. Open the display.
6.Observe the bezel, which is the perimeter that runs around the display. There will be a number of rubber caps that exist on the bezel. The exact number will vary by laptop model. Use the tip of a flat-head screwdriver to pry under the caps and pop them off.
7.Remove the screws under the laptop bezel's caps with your Phillips screwdriver.
8.Work around the bezel's perimeter with your fingers and pry the bezel completely off.
9.Look at the bottom of the monitor assembly. A thin inverter board will span horizontally across the screen's bottom. There is a connector on either end of the inverter board. If the right cable is loose from the right connector, lift up on the connector and slide the cable back in. This will restore the laptop's backlight.
10.Replace the bezel and the bezel's screws. Reinsert the battery and power on the laptop.
Sep 12, 2011 | Computers & Internet
My Ir2800 canon photocopier is not functioning, if I switch the main power button on, I get an error message on the screen wit the code E000003-0000
these is temperature related error, fixing fault.
First you need to try cancel it, follow these steps:
turn on the copier
press *
press 2
press 8
press *
select COPIER
select FUNCTION
select CLEAR
select ERR
OK
turn off and on
If these doesnt helps change fixing film assy ( heater )
Hope that helps
Aug 16, 2010 | Canon Office Equipment & Supplies
How to reset tissot t-touch after battery replace? I could not find the AC point,there is many points under the battery but not accsessible when the battery is inserted.
AC point is not located under the battery. It is at the edge of movement. Get an eyeglass with good magnification and you will find it.
Rate me, please.
Aug 06, 2009 | Tissot T-Touch T33159851 Wrist Watch
My dell laptop doesnt turn on
Remove the bezel avove the keyboard with a small flat head screwdriver. Press the power button with your finger and see if it powers up. If it does, just replace the bezel. If not, then you could have a bad system board.
Does the battery show a charge when you press the button located on it? Does the power adapter show a green light when it's plugged into an A/C outlet?
Dec 31, 2008 | Dell Latitude D600 Notebook
Can't get my GPS to turn on with the Garmin 405
I too was frustrated because of this. I played with the watch until I found the solution. Hope this helps!
For some reason I needed to be in the training mode to do this.
From the Time/Date mode, do the following:
1.) Press the start/stop button (upper metal button) to get out of Time/Date mode
2.) Press the Training side of the bezzle. You will see a workout display.
3.) Touch the GPS side of the bezzle until "to location" shows up
4.) Press the lap/reset button (lower metal button) to display a menu (may have to do this a couple of times, eventually when you release the button the menu does show up)
5.) Slide downward through the menu options until you find GPS
6.) Click the start/stop button (upper metal button) to toggle the gps on or off
7.) Press the lap/reset button (lower metal button) to exit the menu (goes to the "to a location" screen)
8.) Press and hold the Training side of the bezzle to return to your training screen
Nov 16, 2008 | Garmin Forerunner 405 Handheld GPS...
Screen turned black !
try taking off the batteries and the sim card and let it rest for an hour or so in a nice and cool place. then try again. :)
i had the same problems too ^^
Aug 09, 2008 | AT&T Sony Ericsson W580i Cell Phone -...
Computers & Internet Logo
63 people viewed this question
Top The Computers & Internet Experts
Ed Watson
Level 1 Expert
Alex Krenvalk
Alex Krenvalk
mukhtar21 shaikh
mukhtar21 shaikh
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
