Question about Lands Phones
How to cancel mute on hand set - Lands Phones
Tv on mute no remote how can I turn mute off
If you have no volume control on the main TV, unplug the TV and then turn it back on. The mute should be cancelled. If you have a volume control, turning it up should cancel the Mute function. It does on mine.
Nov 02, 2015 | Televison & Video
I have a sharp aquos tv model lc32d6u, we have lost the audio, we have tryed turning the set on and off, nothing. we are serviced by Comcast and it is not the box. I can hear a small click when we turn the...
Try this
1. Power off both the TV and the DVR.
2. Plug in the HDMI cable to both units.
3. With the DVR off, press and hold the power button on the unit until the word BOOT appears on the display.
4. Wait until the unit reboots and shows the clock again, then power the TV and the DVR up.
5. Choose the appropriate input on the TV for HDMI.
6. Use the SETTINGS button on the DVR remote to get into the "more settings" option.
7. Find audio settings and choose HDMI output, press select.
Hope that helps.........
Jun 28, 2008 | Sharp Audio Players & Recorders
Unmute handset
Mute Microphone
With the handset
You can temporarily turn Off the microphone so that the person you are talking with cannot hear you.
1)Press menu/del during talk mode (while phone is in use).
2)Press ring/vol/? or ring/vol/? to move the pointer to Mute and then select/
Mute On and appear in the display. To cancel muting, repeat above step again when Mute
is set to on, Mute Off appears.
With the base
While using the base speakerphone, press mute on the base to turn Off the microphone.
Press mute again or press (speaker) to cancel muting.
Jan 01, 2015 | Uniden Lands Phones
How can I fix my Dynex Microphone
Plug the USB connector into another available USB port.
• Check your computer's volume level.
• Check if your computer's volume is muted.
• Check your operating system's audio input and output settings.
• Check the headset's volume and mute settings.
• Restart computer.
If these don't resolve your issue, I would recommend pursuing replacement options.
Feb 27, 2013 | Dynex Mono USB Headset with...
Dynex headset does not shut off sound from desktop when plugged in usb port
Plug the USB connector into an available USB port.
• Restart computer.
Otherwise, I would recommend pursuing replacement options
Sep 13, 2012 | Dynex Mono USB Headset with...
When calling,i can hear the person i called but they cant hear me
Looks like problem is on your side. This is may due to a faulty microphone on your phone or Mic is set to be on mute.
1. Please check that nothing is clotted on Microphone. This is a small hole on bottom side of your phone.
2. Please check that other party can hear you when you're using a Hands-free / Bluetooth ear phones with mic on it. If they can hear you, when you use a hands-free, problem is with your phone's on-board microphone.
3. You can also check that, while on a call, your mic is not set on Mute. This can be done as on call, select Options , look for Mute / Unmute. If Unmute is present, select it unmute the mic.
4. You can use Mute button Provided on the top side of the phone. While on the call, press this button to Mute / Unmute the mic. If the mic is set to Mute mode, other party won't hear any sound from you.
Hope this will solve the issue.
Mar 13, 2011 | RIM BlackBerry Bold 9700 Smartphone
My hand set is on mute but mute is not selected
there might be some settings made or the mute key by mistake is being pressed be carfeul.
Jun 13, 2009 | Lands Phones
Phone stuck on mute
per the book press the Redial/Mute button during a call
Nov 21, 2008 | Philips CD4452S/05 Digital Telephone and...
Muted on Cerain Channels on Zenith SE2795W TV
Somewhere in it's lifetime, a user has set the 'user preference' to 'mute' while this channel was active. I don't know your specific set, but most TV's need a remote to work 'mute'.
Second hand set?
[A] check all buttons on TV for a crossed-out speaker symbol, or
[B] buy a universal remote and select pin for your set. Then,
Try these:
ZENITH - 000,001,004,023,038,058,059,064,073,121,135,136,153
Oct 11, 2017 | Panasonic DMR-EH60 DVD Recorder/HDD...
How to mute my Uniden phone
You have to use the menu on the handset. Press Menu/Clear, then Mute, then push the Select button. Repeat the same to turn mute off.
Mar 31, 2008 | Lands Phones
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
