Question about Hotpoint Washing Machines
I have a Hotpoint Aqualtis 9kg Condenser Dryer displaying an f10 error code, meaning I have to power it off then back on for it to work again until the f10 code appears.
SOURCE: ctd80 hotpoint dryer error code f10
If you remove the back cover of the drier with the appliance un pluged, you will see the heater bracket.
un screw this from the back panel, and at the top you will see three thermostats. There is a brown one with a small hole in the middle, if you use a pin and press in, you should hear a click. This resets the thermostat and you should be able to use the drier again.
Apparently a common fault on these indicit based driers.
it worked on mine
Posted on Oct 28, 2007
  • 1257 Answers
SOURCE: E1 error code
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 05, 2008
  • 4 Answers
SOURCE: hotpoint ultima tumble dryer error code f-03
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Posted on Jan 14, 2009
SOURCE: F10 error code on Hotpoint ctd80. How do I fix ? Thanks
remove 2nd largest panel on back of dryer then remove the heater unit (two small screws) from inside panel,on the top of this you will see two small units with wires going in and out both sides looking closer one of these units has a small hole using a pin push it down into hole this resets thermal cut out,you should hear a small click.
Posted on Aug 22, 2009
MsMithra
  • 79 Answers
SOURCE: Hotpoint Aqualtis AQGF 149 Error F-05 what does this mean?
F-05 means service switch jammed.
Hope this helps. =)
Posted on Oct 10, 2009
My hotpoint Aqualtis has an f6 code displaying.. Any ideas on what the problem is and how to fix please?
Hi!
F6 means:
- Broken buttons;
- A faulty electrician between the control board and the controller;
- Faulty electronic module
Mar 05, 2017 | Hotpoint Washing Machines
Aqualtis washing machine has error code F01 what does this mean?
F01 Electronic circuit board fault
Issue: Washing machine is not operating - some or all functions are not selectable.
Advice: We recommend you disconnect (unplug) the appliance from the mains supply for a minimum of 2 minutes. Reconnect supply and wait 30 seconds and try starting the machine again.
Jan 14, 2016 | Hotpoint Aqualtis AQXXL129PM Washer Front...
Hotpoint aqualtis aqgd169s no power wont turn on not even had an error code come up
If the machine is dead, I would check the cable from the main boad leading to the front display on the door. Often the cableharness breaks at the hinge. (one of cables). If that is not the case, eather the main board or display board is dead.
May 26, 2014 | Hotpoint Ariston AW125 Front Load Washer
Pressed reset button on left hand therm0stat dryer runs but still error code f10 elements not getting warm
I found this, an answer already posted on Fixya.....
Dec 12, 2013 | Hotpoint Dryers
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
Feb 02, 2009 | Hotpoint TDL15 Electric Dryer
Hotpoint Aqualtis LCD display language
Follow this link and read where to find your model # and insert it in the box. I hope this helps. http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
Nov 30, 2008 | Hotpoint Ultima WD72 Front Load...
On a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
F8 means that heater relay cannot be activated, you need to call an engineer.
Could be expensive, possibly a new control board needed
Nov 19, 2008 | Hotpoint WMA35 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
