The washer door is clicking and the door lock light still is on and won't unlock to open the door
  • rep1974 Jul 25, 2009
    Thank you very much I will try these things.
  • Washing Mach... Master
  • 2,200 Answers
Hi
The clicking sound you are hearing is the solenoid attempting to operate the latch mechanism which has somehow jammed or is misaligned. First thing to try is to diconnect the machine from the mains supply for 30 minutes - if the problem is in the PCB this sometimes allows a reset.
Secondly you can try pushing inward pressure on the latch to see if this realeases the mechanism.
Some washing machines have a cord fixed behind the filter flap door that will open the door if pulled.
If the machine is full of water this will also prevent the door from opening - if so pull the machine out from the wall - disconnect the waste pipe and drain the water into a bucket as this may allow the door to open when switched back on. You should also check that the pump filter is not blocked up and preventing the water from draining from the machine properly.
Last resort use a thin flat bladed screwdriver, a blunt ended one of possible to get round the seal by the lock and you may be able to release the door.
Hope this helps. Please remember to rate my answer. many Thanks.
Posted on Jul 24, 2009
Wfw9150 door won't unlock
Try pressing the "end of cycle" button on the right side of the panel for 3 to five seconds. Wait for 3 minutes to open the door, do not force it. And you start all over again. Please reply as to the outcome. And if it is good you give me a 4 thumbs up rating.
Mar 14, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Door won't unlock and the washer will not start to fill.
Check and see if the door is jammed or there is fault in the lock.
Click this link for tips to reset the lock: Door lock
Check the continuity of the door switch and see if the harness connects to the control board to trigger the start cycle when the door is closed.
Jan 21, 2013 | Maytag MHWE200XW Washer
LG WM3431 door won't unlock
did you unplug it,leave it unplugged for 5 minutes and plug it back in,if it's to hard to get to plug flip the breaker and leave the power off for 5 minutes or longer when you power it up again the door should unlock.here's a link to check hope it helps
https://www.google.com/search?q=lg+front+load+washer+how+to+manually+open+a+locked+door&oq=lg+front+load+washer+how+to+manually+open+a+locked+door&aqs=chrome..69i57.21935j0j8&sourceid=chrome&ie=UTF-8#kpvalbx=1
Dec 29, 2017 | LG WM3431 Front Load Washer / Dryer
2003 Monte Carlo SS, FOBS won't unlock doors (new batterries), use key and open the door with the door open FOB will lock and unlock the door, shut the door and the FOB won't lock the doors. After...
If the passkey is messed up, there will be a light on the dash that says security, or have a picture of a car with a lock thru it. If there is no light when the key is turned forward, then its NOT a passkey problem.
Aug 17, 2011 | 2003 Chevrolet Monte Carlo
I pushed the 'pause' button during the wash cycle of my LG WD-3274HD and now the door won't open.
Hi!
The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
Aug 08, 2011 | LG WD-3274RHD Front Load Washer / Dryer
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
Kenmore elite he washer lock light. cannot open
You can manually Unlock the door Lock System
1. Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard.
6. The door may be opened.
Thank you !!
May 31, 2010 | Kenmore Elite 45986 Front Load Washer
I want to unlock my door
Manually Unlocking the Door Lock System
1. Unplug washer or disconnect power. 2. Remove the lower kick panel. 3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit. 4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab. 5. Gently pull the tab down about a ¼" or until a click is heard. 6. The door may be opened.
Apr 12, 2010 | Kenmore HE2 Plus Front Load Washer
It won;t power up at all, clothes... Solve It won;t power up at all, clothes are locked inside, no lights on the panel. Plug in is working, I... (More) It won;t power up at all, clothes are locked inside,...
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
