Question about Sewing Machines
My machine isn't making a tight sew. It's very loose and seems to be from the needle tread being loose.. how do I fix this? I didn't adjust any settings prior to this happening, it just started.
  • Sewing Machines Master
  • 11,524 Answers
Be sure to install a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the top tension to the midway point (may need to tweak this later for your particular machine). If the top thread is still loose, then tighten it up.
Posted on Apr 25, 2017
  • 37 Answers
SOURCE: tread keeps coming out of the needle.
Make sure you sink the needle into the fabric before starting to sew. If that isn't it...remove the thread and rethread the machine. Make sure the thread isn't wrapped around the spool holder.
Posted on Apr 16, 2009
  • 240 Answers
SOURCE: sewing machines
Firstly-check the needle is in correctly.If the needle is slightly bent it will not pick up the bottom thread. When top and bottom are threaded, pull the threads towards you. Hold the top thread between finger and thumb and hold but do not pull tight. Turn the flywheel towards you while holding the thread at a 45 degree andgle in front of you, upwards. You should feel it loop and give it a very gentle lift and pull as you feel it. There are some good videos of this on youtube Ive found which may help you-just search for "threading a sewing machine".If no manual supplied-contact either the seller or the manufacturer to get one.
Posted on Jun 13, 2009
SOURCE: Treading sewing machine
these are the best setting i have found for sewing through thick materials, specifically leather and vinyl:
top tension- between 8 and 9 bottom tension- between 4 and 5 stitch length between 3 and 4 stitch type: 2
that is just what works best for me, i have a brother xl-2600i
Posted on Oct 07, 2009
SOURCE: sears Kenmore sewing machine model number 15358 tension issues
#14 needle is way big for cotton napkin scrap. a #10 is good for most lightweight fabric. #14 is for sewing denim or levis, like that.
the tension problems on almost all machines regardless of price usually fall on the upper tension. the lower bobbin tension is factory set and it's rare you should ever need to mess with it.
if you have a drop in bobbin (top loading), tighten the adjustment screw all the way and then back it off 1/4 turn. if your machine uses a shuttle bobbin, tighten the adjustment screw all the way and then back it off in 1/4-turn increments until you can hold it in the air like a yo-yo and cause to bobbin case to fall slightly dipping your hand.
A dull needle and stitch length will also mess up your stitch. The idea is to narrow the problem down to one thing and one thing only -- UPPER THREAD TENSION.
So, if you have the right size needle for the job, with the right thread, and if your stitch length selection is correct (usually between 2 and 3 or 8-to-10 stitches per inch, the problem should be with your upper thread tension.
An easy way to fix this then is to remember: Loops on top, upper tension drop. Loops below, upper tension grow. If you get loops on top of your work, lower (drop) your upper thread tension to a lower number. If you get loops on the bottom, raise the upper thread tension.
Different stitches on the same machine will require different upper thread tension settings. Don't be afraid of it. Just remember the pneumonic: loops on top, tension drop, loops below, tension grow -- referring to upper thread tension.
have fun :)
Posted on Apr 02, 2010
  • 2510 Answers
SOURCE: I have a Kenmore sewing
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
Posted on Mar 20, 2011
Stitch too tight on top, too loose on bottom
This is a problem with thread tension. The needle thread is too tight and the bobbin thread is too loose. I don't have one of these machines, but there should be either screws or knobs to adjust. Look at your manual. Here's a page I found on bobbin tension.
Aug 06, 2017 | Toyota Sewing Machines
My Bernette 65 sewing machine isn't pulling my main thread through. Bobbin tread is being pulled fine. What could the problem be?
Make sure you have a new needle in first and the correct way round, failing that the machine may need retiming
Sep 19, 2011 | Bernina BERNETTE 65 Mechanical Sewing...
Evey time I start to sew, my tread keeps breaking at the needle
i would change the needle
check the top thread tension it may be to tight usually 3 or 4
check the needle plate to make sure there are no burrs on it
rethread the machine to make sure the thread is not caught anywhere
try a different spool of thread
Aug 13, 2011 | Singer Sewing Machines
I change the presser, for a walking foot, and the nedlee started to stucked, and then I change for the presser again and now doesn't sew at all, now only sew a few stitches and then the tread loses both...
This sounds like you have one of two things going on:
1. the tension, probably upper, is too tight or the thread is looping or catching along the way threading isn't right
2. the needle is bent.
Try rethreading and check the tensions and then also make sure and try a different new needle. Make sure the stitch type is set right for the presser foot too! :)
May 04, 2011 | Brother Sewing Machines
The bobbin thread is showing through on top a lot
when bobbin thread shows on top, it means that there's too much tension on top thread.
1. Check if top thread unwinds and feeds up well. Make sure that the spool doesn't slide off horizontal spool pin. If it falls – it creates too high tread tension by not giving the thread to unwind properly.
2. Check that the needle is good, not sticky, and allows the thread to come through it easily. It should have a large enough eye.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 04, 2010 | Brother SE-270D Computerized Sewing...
Bobbin tread is loose when sewing on cotton material Have adjusted tension, it is on 9. It is fine when I sew denim, which I sew a lot but I am trying to sew cotton now. I have cleanned machine, changed...
Have you checked not only the top tension but also the bottom (bobbin) tension? Top tension is usually a lever wheel etc on the machine (depending on model). To tighten the bobbin tension you need to tighten the small screw on your bobbin casing.
I don't suppose it could be as simple as this?
Jul 07, 2010 | Kenmore Sewing Machines
My kenmore sewing machine model 385.18221 is not really sewing. It seems like it is for a couple of stitches then the fabric goes down into the machine, threads r hung up in the bottom and when u get the...
Here are several solutions to try.
- Re-thread your machine. It may be threaded incorrectly (backwards).
- Raise your feed dogs if your machine has this feature.
- When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
- Reinsert your needle and make sure it goes all the way into the holder and that it’s positioned correctly – usually with the flat side away from the bobbin, but consult your machine’s manual to be sure.
- Change your needle, it may be blunt, bent, or otherwise damaged.
- Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). Make sure your needle is appropriate for the type of thread you’re using.
- Adjust the pressure of your pressure foot. It may be too light for your fabric.
- Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
- Adjust your thread tension, It may be too tight or too loose.
- Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: After changing your needle plate, check to make sure your needle aligns perfectly with the smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope these solutions help you.
Sep 24, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Tread keeps coming out of the needle.
Apr 06, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bernina 66 troulbe with tension
the Berlina uses a reverse hook; from say, singer; over time your hook has slipped and is barely looping the thread: adjust your hook to enter the thread loop about 1/4" before the needle raises to make the stich then readjust the tension on both the bobbin and, the needle
Apr 03, 2009 | Singer 3343 Mechanical Sewing Machine
Several things to try, I have this set up and after six months I'm still trying to get some issues resolved.  First make sure the machine is treaded correctly, the Juki doesn't thread like most machines, make sure you have the bobbin going the correct way.  After the machine then it has to be in the frame which means that the fabric is most likely to tight, this is a common problem, if you are bending the bars then it is too tight.  Also, look at how the quilt is in relationship to the frame, is it level?  As you quilt and roll, you will need to adjust the frame up, the quilted part should not drag on the machine and the to be quilted part should not be below the machine.  It is a critical that the frame and the machine be even with each other, if not the machine will try to pull and won't sew correctly.  Also, another tip, after each quilt change your needle, the reason is that free motion is technically bending the needle.  Hope all this helps.
Sep 09, 2008 | Juki TL-98Q
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
