Question about HP Measuring Tools & Sensors
14 Hp Briggs And Stratton engine wiring - HP Measuring Tools & Sensors
  • 83 Answers
SOURCE: removal of flywheel from briggs and stratton 4 cycle engine 3 hp
Without the $100 flywheel remover that briggs will happily sell you you can do the following.
First you will need another body to help, two if available
2 pry bars or large screwdrivers
A air hammer if you have it or a large hammer if not
Loosen the flywheel nut until it backed off til the nut is just barely one thread or even with the shaft. Now put your pry bars behind the flywheel on opposite sides. Have someone provide constant pressure (don't be too forceful the block is made of aluminum and can be damaged). Now hit the end of the shaft with a hammer or air hammer (the nut is protecting the shaft threads) with medium power. With a few careful hits the flywheel should pop right off.
If you run into trouble or are unsure of something in this proceedure please ask.
Posted on Mar 30, 2009
  • 35 Answers
SOURCE: briggs & stratton 3 hp engine will not start
likely needs a carb kit
Posted on Apr 19, 2009
  • 110 Answers
SOURCE: want a repair manual for a 17 hp briggs &
A range of strip-down manuals for all Briggs & Stratton engines is avalable - I got mine from Amazon, but you can get them directly from Briggs & Stratton via their web site. They have a look-up system by model series, which ensures you end up with the manual that covers your engine.
Posted on Oct 03, 2009
SOURCE: need point gap setting for 8 hp Briggs and
need coil gap setting for 2-8 hp briggs stratton
Posted on Dec 02, 2009
SOURCE: briggs & Stratton 18 hp v-twin engine surges
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Posted on Nov 06, 2010
I need a carb for 3.5 hp brigs on a weedeater vip 14'' crt tiller
See the link. Spares go by the Briggs and Stratton engine not the weedeater.
briggs and stratton 3 5 hp carburetor Google Search
Feb 18, 2018 | HP Garden
Briggs & Stratton 16.5 Motor workshop manual
go google and type in-- workshop manual for briggs and stratton 16.5 hp motor -- if there is a pdf version , down load it
remember that the manual will cover a range of hp motors so a manual may be 14-20 hp
Nov 03, 2016 | Briggs & Stratton Measuring Tools &...
Put new battery on 14 hp v-twin Briggs, started and ran for a while. Shut motor off then came back and tried to start, acts like the battery is dead. Where is the generator/altenator located on these?
The generator is under the flywheel with or part of the ignition coil.
Check all the battery wiring and grounds. A bad or weak connection will act the same way.
May 22, 2011 | Briggs & Stratton Briggs Stratton Intek V...
How to change electric starter on vanguard 14 hp v twin vertical shaft.
Please, help me to regulate valves on Vanguard B&S 14HP OHV model:294446 tip:1141-a1. I don't know how. Thenks. My adress
Mar 31, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Measuring Tools & Sensors Logo
516 people viewed this question
Top HP Measuring Tools & Sensors Experts
Richard Lindsey ...
Are you a HP Measuring Tool and Sensor Expert? Answer questions, earn points and help others
