Where is off button will not turn off - Televison & Video
  • Dennis White Apr 25, 2017
    Hi Sandy Kessler, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
How do i program my remote
Things You'll Need:
  • RCA Universal Remote Control
  1. 1 Turn on the component you want to program.
  2. 2 Press and release the component button on your remote that corresponds to the component you want the remote to operate (TV, VCR, etc.). The illuminated ON-OFF button will turn on and remain on.
  3. 3 Press both the component and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on.
  4. 4 Release both buttons after the ON-OFF button turns back on. The button should remain illuminated.
  5. 5 Press and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until the component turns off.
  6. 6 Press and release the REVERSE button when the component turns off, then wait to see if the component turns on again.
  7. 7 Press and release the STOP button to save the new code.
Tips & Warnings
  • Each time you press the PLAY button in Step 5, the ON-OFF button blinks ten times and a list of 10 codes is sent to your component. This process continues until all of the code lists have been searched. If the component has not turned off after all codes have been searched, the ON-OFF button blinks four times, turns off, and the Auto Code Search is exited.
  • If you do not press the STOP button at the end, the new code will not be saved.
Read more: How to Program an RCA Universal Remote Control ' eHow.com http://www.ehow.com/how_9191_program-rca-universal.html#ixzz1CzcjxWJw
Feb 04, 2011 | RCA Universal Remote Control
I need a code for my universal remote so it can connect with my magnavox dp100mw8
Instructions Things You'll Need:
  • Universal Remote Control
  1. Turn on the component you want to program.
  2. Press and release the component button on your remote that corresponds to the component you want the remote to operate (TV, VCR, etc.). The illuminated ON-OFF button will turn on and remain on.
  3. Press both the component and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on.
  4. Release both buttons after the ON-OFF button turns back on. The button should remain illuminated.
  5. Press and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until the component turns off.
  6. Press and release the REVERSE button when the component turns off, then wait to see if the component turns on again.
  7. Press and release the STOP button to save the new code.
Feb 02, 2011 | Televison & Video
Look i turn on my tv and its on audio and i dont have the remote to it to change it and i had and old universal control that i have never used but i dont have the code
  • Turn on the component you want to program.
  • Press and release the component button on your remote that corresponds to the component you want the remote to operate (TV, VCR, etc.). The illuminated ON-OFF button will turn on and remain on.
  • Press both the component and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on.
  • Release both buttons after the ON-OFF button turns back on. The button should remain illuminated.
  • Press and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until the component turns off.
  • Press and release the REVERSE button when the component turns off, then wait to see if the component turns on again.
  • Press and release the STOP button to save the new code.
  • Jan 01, 2011 | RCA Universal Remote Control
    Need to know how to connect a universal remote
    Hello
    1. First Turn on the component you want to program.
    5 .Press and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until .the component turns off.
    BEST OF LUCK
    Dec 13, 2010 | Apex Digital AD-500 DVD Player
    How do I reset the oil life indicator on 2006 Saab 9-3
    Switch ignition ON. Press brake pedal. Press button [A]. RHD - 100248. LHD - 100254. Turn button [B], until the message "System Settings" is displayed. Press button [B]. Turn button [B] until the message "Service Info" is displayed. Press button [B]. The message "% left of oil quality/days to service" is displayed. Turn button [B] until the message "Reset Service Ind." is displayed. Press button [B]. The message "Are you sure? Yes or No" is displayed. Turn button [B] to select "Yes". Press button [B]. The message "service parameters updated" is displayed. Switch ignition OFF.
    BUTTON B IS ROUND PUSH/TURN BUTTON
    BUTTON A IS TWO DOWN FROM THIS
    May 08, 2010 | 2001 Saab 9-3
    There is no code search button. how do i program it?
  • Step 2 Press and release the component button on your remote that corresponds to the component you want the remote to operate (TV, VCR, etc.). The illuminated ON-OFF button will turn on and remain on.
  • Step 3 Press both the component and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on.
  • Step 4 Release both buttons after the ON-OFF button turns back on. The button should remain illuminated.
  • Step 5 Press and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until the component turns off.
  • Step 6 Press and release the REVERSE button when the component turns off, then wait to see if the component turns on again.
  • Step 7 Press and release the STOP button to save the new code.
  • I found this on the internet. hope it helps.
    rhais
    Jun 12, 2009 | RCA Universal Remote 3 Device Remote...
    Need codes to control symphonic 27" tv using rca universal remote control type rcr312w
    1. These instructions come from the RCA website. The crucial step is to keep pressing the reverse button.
    2. Turn on the component (the tv, dvd, etc).
    3. Hold the TV (or DVD) button and the on/off button at the same time. It will stay lit.
    4. Press the play button every five seconds until the component turns off.
      • Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
    5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
    6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
      • If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
    7. To save the new code, press and release the STOP button.
    8. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
    Tips
    • Turn on TV
    • Hold in the TV button and the ON/OFF button until the ON/OFF button stays lit
    • Press the PLAY button every 5 seconds until the device turns off
    • Press the REVERSE button every 2 seconds until the device turns on
    • Press the STOP button to lock in the code...the remote should work now.
    • Important to press reverse button every 2 seconds, not just once.
    Good Luck!!
    Aug 18, 2008 | Televison & Video
    Im using the rca rcr312w universal remote control. i need the code to program a durabrand dvd-1002 dvd player. thanks
    Aug 17, 2008 | RCA RCR311B Remote Control
    Remote code for my ge universal remote
    This is the quickest and easiest way to program your remote: To program a component using the Automatic Code Search method, perform the following steps: 1. Turn on the component you want the remote control to operate. 2. Press and release the component button that corresponds to the component you want the remote control to operate. info.gif The illuminated ON-OFF button turns on and remains on.
    aud_remote_on-off.gif 3. Press and hold both the component and ON-OFF buttons. info.gif The illuminated ON-OFF button turns off. 4. After the illuminated ON-OFF button turns back on, release both buttons. info.gif The illuminated ON-OFF button remains on. If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained. 5. Press and release the PLAY button. aud_remote_play.gif 6. If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off. info.gif Each time the PLAY button is pressed, the illuminated ON-OFF button blinks ten times while a block of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited. 7. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again. info.gif If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks. aud_remote_reverse.gif info.gif If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again. 8. To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button. aud_remote_stop.gif info.gif If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s functions.
    Copy of manual below as well
    http://support.rcaaccessories.com/doc/Device_Documents/manuals/RCR450_manual.pdf?deviceDocId=216&docid=959&docid=983&navtypeid=6&pagetypeid=7&prevPageIndex=31&selectedmodel=RCR450&selectedFamily=generic&nvty=m
    Oct 26, 2007 | RCA RCR450 Remote Control
    RCA universal remote
    This is the eastest way to program your remote. To program a component using the Automatic Code Search method, perform the following steps: 1. Turn on the component you want the remote control to operate. 2. Press and release the component button that corresponds to the component you want the remote control to operate. info.gif The illuminated ON-OFF button turns on and remains on.
    Aug 28, 2007 | RCA RCR450 Remote Control
    Televison & Video Logo
    37 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
