Question about Blomberg Washing Machines
My Blomberg dishwasher is stuck on the end of the drain cycle when it has about 40 minutes to go. It drains the water out but then resets and adds up with more water.
I cleaned the filters and restarted the cycle but still have the same result.
  • 126 Answers
SOURCE: dishwasher not draining
if its new call your dealer its a warranty call
Posted on Dec 22, 2007
  • 2651 Answers
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
  • 1019 Answers
the first things to look for, are the simplist faults.
1:) Check that the Outlet Hose-Pipe Isn,t Blocked-Kinked Or Bent.
2:) Check that the Pump, is not clogged/Blocked or not-functioning.
Hope this helps you start, your fault-finding successfully.
Mike @ Compurepair.
Posted on Aug 02, 2008
  • 17 Answers
So it sounds to me like it is your "pump" I work for an appliance parts dealer and it looks to me like the pump you need is originally part# 99002750 but then it changes to #6-917641....It runs about $57.00 and you can find this product at
Hope this helps!
Posted on Feb 16, 2009
  • 7 Answers
SOURCE: Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Posted on Jul 29, 2009
My dishwasher suddenly won't wash hot on either the normal auto setting nor the eco one.
Do you find water left in the dishwasher bottom at cycle end???? It sound like your drain line is partially or completely blocked or possibly a bad drain pump depending on model. If it can't drain completely it can't refill with hot water. That will also explain an increase in the cycle time. Some dishwasher add time because it is trying to heat the water up. Its a loosing battle if the water isn't partially hot to begin with.
Apr 03, 2015 | Dishwashers
How to reset Blomberg DWT23100W computer?
Remove lower dish basket and inspect where water drains looking for clogged inlet
Jun 02, 2014 | Dishwashers
Kenmore he2 plus washerwashing machine turns on but cycle does not engage
The error F21 is a long drain error and usually the drain pump is not working or the filter is clogged. Remove the lower kick plate and clean the filter. Post back your results.
Jun 28, 2013 | Washing Machines
My Blomberg dishwasher wont stop drain cycle
A common cause of this condition results from water in the base pan. This may result from a leak in the dishwasher or the drain hose (to the sink drain) backing up. First check the base pan (the very bottom assembly that all other components are mounted within) for any moisture - this can be difficult as there are only narrow openings between the tank and the base pan; a mirror can help or you might have to pull the unit out from the cabinet to access the sides. If there is moisture in the pan this problem must be corrected as the unit is just trying to protect against water damage from a leak. If the base pan assembly is dry, look at the float assembly (behind the water fill valve) as insects or rodents can sometimes interfere with the proper operation of this sensor. That causes the control to think there is a water leak. When this fault occurs everything is turned off and the drain pump runs continuously to eliminate any water from inside the dishwasher.
Apr 06, 2013 | Blomberg DWT14210
Blomberg DWT34240 error code IF. What does that mean?
Hi, same dishwasher here, same error code. Did you or anyone find out more about this?
Jan 04, 2012 | Blomberg DWT34200 DWT34210 DWT34220...
My Blomberg dishwasher will not stop draining once all the water is out. It is at the beginning of the cycle and it's like its stuck and won't move on to the next part of the cycle to bring water...
Doug Smith\'s solution of Oct. 20, 2008 worked for my Blomberg Dwt57500ss model.
Removed small filter basket by pinching 2 tabs inward at the top of the basket. Turned larger basket counter-clockwise by hand and lifted out stainless steel screen. Used wet/dry vac to suck all the water out. The anti-flood switch reset itself. Turn power back on to unit, and pressed start. Then pressed program I wanted to use and reset button to start machine. Worked immediately and started washing dishes.
Sep 05, 2011 | Blomberg Dishwashers
Sebo Vacuum runs intermittently and keeps cutting out and restarting
There could be numerous reasons for this. What I would try in this order to help troubleshoot is this:
1. If you wiggle the power cord near where it inserts into the vacuum cleaner itself, does the vacuum turn on and off constantly? If so, you have a damaged cord or loose connections that need to be fixed.
2. Has the bag been emptied, and if the vacuum has a filter element, has this been cleaned? Vacuums may cutout if they get too hot. A vacuum can overheat if either the bag is full, the filter is blocked, or there are other obstructions to airflow, which cause the motor to work harder and draw more voltage, resulting in more heat. It may have a thermal cutoff which is tripping constantly. Solution is to ensure bag is not full, or less than 3/4 full, any air filters are cleaned and check for any other obstructions in the air flow paths.
3. Ensure the power supply is adequate for the vacuum. Try running it without long extension cords if you have been using those.
4. Check and clean the switch. Sticky or dust contacts on switches can cause variable cycling (cutting out and restarting).
Hope that helps!
Mar 11, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
Our Blomberg DW-35100 is not draining. We did have a service person in who fixed the problem temporarily. He took the bottom plate off the tub and told us water was present there which raised some float,...
If your Blomberg dishwasher will not drain, it might be the same problem that I had. The filter is a bad design and it lets a lot of debris through. The hose from the dishwasher to the main drain is very small and it gets plugged. Under the sink, loosen the clamps around the hose going into the main drain and take off the dishwasher hose. I use a screwdriver to push the debris through the small hose (that is attached to the big main drain hose) into the big one where it will be carried away. Then I turn on the dishwasher, hold the start button of the dishwasher for three seconds and shut the door. It drains like magic. The first time I did this, it took two hours to figure it out and now I can do it in three minutes. I am going to write to Blomberg now and see about this terrible filter system!
Feb 12, 2011 | Blomberg 35100 24 in Builtin Dishwasher
Washing Machines Logo
42 people viewed this question
Top Blomberg Washing Machines Experts
Level 1 Expert
Eric Taylor
Are you a Blomberg Washing Machine Expert? Answer questions, earn points and help others
