Question about Kenmore Sewing Machines
Can you still buy the part underthe clutch knob?
The part that covers was broken trying to get it under the wheel.It is a 15814100 kenmore sewing machine,
  • Kenmore Master
  • 11,749 Answers
Check with Sears.
Posted on Apr 25, 2017
I have a Kenmore 158-3500 sewing machine and cannot get the side plate off near the hand wheel I have removed the clutch wheel but the hand wheel and belt seem to keep the plate from coming off.
The machine has two belts, one from the motor to a transfer pulley and the second from that pulley to the handwheel. You have to loosen the motor mount (one large screw/bolt) to release tension on the transfer pulley which in turn releases tension on the handweel belt. You will have to take the belts off the transfer pulley to slide the handwheel off (assuming you have already removed knob in the center of the handwheel)
Don't forget to lubricate the shaft of the transfer pulley while you have the end cover off. If this runs dry you will have a problem.
Good luck
Bob
Jan 22, 2017 | Kenmore Sewing Machines
The clutch will not release in order to fill a bobbin. Past owners have been directed to remove the clutch knob. How do you remove the clutch knob?
Hi Victor, In general all sewing machines have the same basic design. So, if you take hold of the big 'wheel' on the right of the machine with your left hand and take hold of the knob in the centre of the wheel with your right hand you should be able to turn the knob anticlockwise. That's the cluch disengaged. You should now be able to fill a bobbin. Don't forget to engage the clutch before sewing (just reverse the process).
Jul 16, 2015 | Brother Sewing Machines
The clutch on my Kenmore model 1249 wont tighten. Is there any way I can fix it myself?
Oh,Oh, time for a professional overhaul. Sounds like a tooth may be broken or worn. (Plastic probably) not like the old machines with metal teeth.
Jan 01, 2015 | Kenmore Sewing Machines
Clutch knob on kenmore 15814001 sewing machine will not tighten
Have you removed the inner wheel? If so you probably have put clutch spring in backwards. The washer like piece has to bent fingers that appear to fit in the center of the shaft. These should be facing out toward the tightening nut. Turn washer around and voila good to go.
Oct 17, 2014 | Sewing Machines
Model 1400 manual
there should be a small stop screw to prevent the release knob undoing completely. Did you remove the knob and hand wheel?
If so remove it again and ensure the drive belt is fitted on the hand wheel, there is a friction washer that needs to be located in the slots on the shaft before the knob is refitted.
Feb 09, 2014 | Kenmore Sewing Machines
Kenmore sewing machine Model 1602: I was filling a bobbin and when I went back to sewing - the needle won't go up and down. Motor runs when I press on the footpad. It is as if the clutch is stuck as well...
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
Feb 09, 2011 | Kenmore 15516 Mechanical Sewing Machine
I have a kenmore sewing machine model #385.1249180. I cannot disengage the clutch knob from the hand wheel when I spin my bobbins, therefore the needle moves up and down as the bobbins spins thread. Do You...
Usually when you pull the clutch knob out it disengages the sewing machine needle shaft. At least, that is how my 2 Kenmore's work. You can always take your machine into Sears sewing department and ask the sewing machine salespeople for help, they are really helpful in my area and more than happy to help you for free. Good luck
Dec 23, 2010 | Sewing Machines
On my Kenmore 15250 sewing machine to wind the bobbin I need to release the clutch by turning clutch knob towards me, so says the instructions booklet. But the clutch knob does not move apart from the...
On my Kenmore I had to pull the knob out to release the clutch, then push it bak in. I don't know if that is the same for you. You can try it, if it doesn;t move, it was worth a try. You could just take to Sears, sewing machine department and ask the salesperson what to do, they should help you for free, our Sears is pretty good about such matters.
Sep 13, 2010 | Kenmore 15208 Mechanical Sewing Machine
Clutch Release Problem
You will need to remove the clutch release knob and the 3 eared positioner (the clutch) under that knob. Reposition the clutch on the shaft, put the knob back on and see if you can put the screw back in the hole. If it hits something, remove the knob, remove the clutch and turn it 180 degrees. This will reposition the ears. Put the clutch back on the shaft, put the knob back on the shaft and screw the screw into the hole. Test to be sure the knob releases the hand wheel to wind the bobbin.Be sure the thread is under the thread guide when you wind the bobbin and that there is a slight tension on it.
sewman7
Jan 16, 2009 | Brother Sewing Machines
Kenmore sewing machine 15008100 not working
Was all well and working before you did work on the bobbin area ?
Ensure the machine is unplugged & bobbin winder is set OFF as there is a clutch preventing the needle arm to operate when bobbin winding......remove the needle.
If you take the bobbin and hook out, can you manually rotate the handwheel forwards ?
If yes, this suggests they are not inserted quite right, or the timing is out of adjustment.
Can you rotate the handwheel backwards ? On some machines the clutch allows for reverse travel freely, but only around the 15 degrees you mention forward when the top cover is off.....there may be a broken or dislodged spring unit/armature inside top near the handwheel and bobbin winder assembly that is acting as though the top cover is open (a safety feature)....generally towards the rear of machine and acting like a log thrown into a gear.
This may help straight away, or only just start to unravell the cause....
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Mar 16, 2008 | Sewing Machines
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
