Question about Oster Microwave Ovens
Oster microwave shows pf and doesn't want to come back on, even after pushing clear. Slammed the door a few times and it came back on. Loose connection somewhere? Keeps happening.
hotuna
  • 288 Answers
SOURCE: oven turns itself on
THE DOOR HAS A SAFETY SWITCH THAT SHUTS THE UNIT OFF WHEN THE DOOR IS OPENED KEEPING YOU FROM GETTING "ZAPPED WITH RADIATION" ACTUALLY ITS JUST RADIO WAVES, ANYWAY THE JIGGLING OF THE HANDLE TO START IT IS WHATS HAPPENING THERE. IT COMING ON IS JUST A SHORT IN THE SWITCH THAT MAY BE FROM AN ALREADY SET TIME, OR ITS JUST MAKING CONTACT WHERE ITS NOT SUPPOSED TO. ANYWAY YOU NEED A NEW DOOR SWITCH.
Posted on Dec 03, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave keeps shutting off
The magnetron is overheating, tripping the thermostat, which shuts off all power until it cools down.
This is usually caused by a blocked air vent, failed internal cooling fan, or failing magnetron.
If it's out of warranty, I'm sure you'll find it's uneconomical to repair, even if you could get parts for this brand.
Good luck.
Posted on Dec 30, 2009
witserv
  • 144 Answers
SOURCE: My microwave shows PF on the screen and none of
PF = Power failure. Try and push the clear or cancel button (or start, or clock etc) You may have missed one. If that doesn't work try and unplug it for 10 seconds or so and retry.
Posted on Sep 14, 2010
  • 473 Answers
SOURCE: Panasonic Counter top Microwave model
Issue with your Main Panel Power Fail to innitiate ..Du to Component mal-functioning inside the unit ...Possibility Magnetron defect, Or main Transformer Over heat, Also check for safety swich on the door for bad connection...
Posted on Sep 30, 2010
mastermaid
  • 502 Answers
SOURCE: My Oster microwave model OM1201EOVG
find the user manual here:
manualfox.com/link/oster.htm
Posted on Nov 22, 2010
Model:OGD21102 MICROWAVE IS NOT ALLOWWING ME TO COOK MY FOOD. The microwave says Food and that is it. Will not heat, I can push a time and it says Food. What should I do.
if opening and closing the door fails to clear the fault , then your door switch's have a fault in them , this is not too uncommon on microwaves , as most of them have three separate door switches ,(its a safety thing ) as the last thing in the world you'd want to happen is running it with the door open . make sure the door seals properly and there's nothing down in the cracks (even the hinge side) that keeping it from closing properly , I once had a pealing factory label do this , so it doesn't take much to trip the door switch
Feb 09, 2016 | Oster OGD21102 Black Countertop Microwave...
Is light supposed to come on when door is opened?
Yes the light comes on when the door is opened and when the microwave is active! The PF code indicates a Power Failure, press clear or cancel to reset or unplug for a few minutes and re plug!
Nov 08, 2014 | Microwave Ovens
Oster microwave starts when door is closed but no buttons pressed
This is usually caused by a door switch that has come loose or out of adjustment.
Jul 19, 2014 | Oster 0.7 Cu. Ft. Countertop Microwave -...
My Oster microwave (model #OGG21401) doesn't heat. When operating the light will turn on and the carousel will turn but food will not get hot. Can you provide a solution to my problem? Thank you.
Check the door safety interlock switches for proper operation. #1 trouble with microwaves that operate in all respects but no heat.
Thanks for your question @ FixYa.com
Sep 16, 2011 | Oster 0.7 Cu. Ft. Compact Microwave
My microwave shows PF on the screen and none of the buttons are working, not even the timer button. How to solve this problem ?
Sep 14, 2010 | Microwave Ovens
Good luck.
Dec 26, 2009 | Oster Microwave Ovens
Oster Nicrowave Model 0TM1101GBS: The timer works, but will not cook, I think it is the Child Lock
If the Child Lock is on, the microwave cannot be programmed.
What does the owner's manual say those flashing icons are?
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Sep 19, 2008 | Oster 0.7 Cu. Ft. Compact Microwave
Microwave stops after about 2 seconds, also have to reset the clock each time
Sadly, we hear of this over and over.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit. The parts kit is similar to this one.
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
They may even send you a replacement magnetron. GE Customer Service is here.
Good luck.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 21, 2008 | Microwave Ovens
Microwave Ovens Logo
27 people viewed this question
Top Oster Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
ray gallant
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
