Question about Dryers
My Bear Power dryer is not blowing really hard like we are used to. Its only 6 months old. Filter is clean... hose is clear... what could be the problem?
Jimster
  • 240 Answers
SOURCE: HELP, MY GENERAL ELECTRIC DRYER IS BLOWING COLD AIR
More than likely, you have lost the element in your dryer. Sorry to say, but they are not that cheap (WE11X103, Price Retail $89.00), but if you think your handy enough, they do make a restring kit ( WE11X203, which sells for around $40.00). The issue, if you do it yourself, is that you have to re-wire both strings in the element. You would have to be sure that the coils dont touch each other or any part of the element housing, or it will short out. If you feel your up for it, here are the directions for getting into the unit. UNPLUG THE UNIT first off. Open the door, and look at the top of the door housing area for screws that may be securing the top of the unit. If there are screws, remove them, if no screws, put a putty knife between the top and cabinet, approx 1-2 inches from the side and pop the clips holding down the top. Lift and slighty pull top towards you and unhook the top. Spin the unit around, and remove the four screws securing the back access panel and remove the panel. Remove the belt from the idler pully, remembering the way it went for reinstallation. Go back to the front panel, and remove the two screws holding the front panel onto the cabinet. These should be just inside the cabinet around 2" down in the top front corner. Tilt the front panel towards you and lift off the bottom securing brackets. Make sure the loose belt is loose, then remove the drum by firmly pulling forward and lifting slightly. You may have to SLIGHTLY bend the cabinet to allow it to slide forward. You now have access to the element. Look at the two strings for breakage. You may have to gently push on them to find the break. Sometimes (especially with GE's) that one string has completly blew up, if this is the case, be sure to clean out all remaining peices of broke element. If you dont find a broken string, stop, and write me back, we'll check out the other issues it might be without tearing it down again, or wasting unneeded money. Get back to me (gjappliances@gmail.com) with anything else (problems, no string breakage, helping you find parts, etc) that you may need. Thanks and talk to you soon. JIM
Posted on Nov 06, 2007
ttdesignbilt
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
I had the same problem and figured if the lint sensor is clogged, covered or otherwise gummed up with lint, dirt, hair, etc then this will continue to happen regardless of wether the lint trap is clean.
So I took my compressor and blew out the slot where the trap slides into...stuff flew everywhere (so watch your eyes or wear goggles). I then vaccumed it up and did it again... and again and again each time loads of stuff came out. Once nothing blew out I loaded the dryer and have not had the problem since...
This makes sense right? so if you can try this solution.
Posted on Jan 24, 2009
SOURCE: Dryer not working, indicates "lint
This is a common complaint with this dryer.The probe generating this problem,is at fault.It likely has a film on it,from the dryer sheets.Remove the lint screen,and wipe down the probe that sticks into the air box.Should fix the problem,if not ,replace the probe.
Posted on Oct 09, 2009
  • 1383 Answers
SOURCE: keeps blowing the breaker... only 6 months old
This compressor is small however like other brands in this size range draw 13 - 15 amps. Thats quite a bit of power. The compressor has a thermal breaker that will begin to trip if compressor is hot. I am assuming that the breaker that is tripping is the one on the compessor. I have seen many hitachi breakers fail. Easy to replace with generic 20 amp, cost about $10. Before you replace anything, check amp draw with meter, if within specs try to determine what is causing heat.
example:
cycling too many times per hour (check manual for recommended)
low power due to weak circuit or extension cord
using generator for powering compressor (not recommended)
using low quality oil (use synthetic if hot climate)
air leaking from intank checkvalve back to pump
If no reason to overheat then replace breaker on compressor to 20 amp but watch for overheating. Good luck
Posted on Jul 10, 2010
SOURCE: Philips 42fd9954-175 Plasma won't power up
I have this wonderful TV, and it would overheat. Put a small fan benind it blowing air so that it would cool air into the bottom vents and more heat pushed out the top. Worked for a while and then back to 30-60 minute run time then it would die again. I removed the entire back panel (close to 30 screws) and it hasn't failed or overheated again. Problem solved.!
Posted on Aug 01, 2010
I have a Haier HWD1600 washer dryer combo that I am getting an error 2 on. It will not drain the water out and I have not been able to clear it for the past two months
Its a common error,
Error message:Drain error, water can be not drained fully within the required drain time
Reason 1. Pump filter is blocked.
Solution 1. Please open and clean the pump filter. (Filter access door is on the bottom right, at floor level of the washing machine)
Step 1.Push a flat blade screwdriver into the slot on the filter cover and pull it open ,do not use excessive force.(Fig 1).
Step 2.Remove the rubber hose from its clip and stand a suitable container under it, remove the bung to drain the water (Fig 2-3)
Step 3.Replace the bung and fit it back into its clip (Fig 4-5).
Step 4. Unscrew the filter and rinse it under running water, replace it and close the flap(Fig 6-7-8).
Caution:
1. The filter must be in place during operation, ensure it is in place after cleaning to avoid leakage.
2.Place a container under the drain pump filter, to collect any excess water that may come out of the drain pump when the filter is removed.
Reason 2. Drain hose end is higher than 100cm above the floor level.
Solution 2. Please adjust the height of drain hose to 80-100cm above the floor.
Reason 3. Drain hose is blocked or twisted.
Solution 3. Please check and clean the drain hose for blockage.
Reason 4. Drain hose is too long, or water is back filling from waste water pipes.
Solution 4. Remove any extension to the original drain hose.
Ensure the highest part of the drain hose is nearest the washing machine.Check the waste water pipes in the building are clear of any obstructions and flow freely.
Nov 08, 2015 | Haier Washing Machines
Whirlpool dryer Cabrio 6 months old. message on screen is "AF" what does that mean?
Code AF means the air flow is blocked.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 07, 2011 | Dryers
My BOSCH dryer #WTE86300US keeps stopping in mid cycle and gives the signal F3 which says to check condensation outlet and I have cleaned all the parts and cleaned hose but it will still beep after a few...
I have owned the same dryer for about a year and just started having this F03 problem. The condensation drain hose is the soft flexible rubber hose coming out of the back of the dryer and it drains into the same drain as a washer. It's easy to pull the hose off its connector at the back of the dryer and just blow hard into it to make sure there's no lint clogging the hose and reconnect it to the dryer. Next open the panel on the left of the dryer and thoroughly rinse (water only, no soap) clean the two parts behind the door (first is plastic and behind that is the condensation filter which probably is loaded with lint). Sometimes the lint in the condensation filter channels (those that run from front to back) can be quite stuck. Use a long pipe cleaner to get in there or a garden hose with a spray nozzle. Shake the excess water out of the condensation filter and dry off the outsides of two parts. Clean all the lint out the compartment where the parts go. There is one more crucial step not mentioned in the manual. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver or a blunt table knife under the panel and gently pop it open. Under the panel is a small chamber that you can't see very well where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Use paper towel to get it all out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place as well as the condensation filter and the plastic part. Take out the lint filter (within the dryer drum compartment) and wash it with soap and water. Use an old toothbrush or something to clean the screens thoroughly. Rinse well and dry it completely. Clean all the lint out of the empty compartment. Put all three parts back into the dryer. Clean all lint off the door. Using paper towel moistened with white vinegar clean the two metal sensors in drum compartment on the front wall and lower left. Run the dryer empty but with heat on for a few minutes to make sure all the water is drained out. Now try drying a load. I think it's a good idea to rinse clean the condensation filter at least once a month since it collects a lot of lint. Hope this works for you.
Sep 22, 2010 | Bosch WTE86300 Electric Dryer
My dryer has a build up of water and give an F03 error. What can do to fix it?
Aug 08, 2010 | Bosch WTE86300 Electric Dryer
I recently had an ventless Bosch dryer installed (WTE8600US) and I keep receiving this message F:03 which the manual says "check hose for condensation outlet". any advice?
For the F:03 problem on the Bosch Axxis (WTE86300US) do all the things mentioned in Solution #1 above. Sometimes the lint in the condensation filter channels (those that run from front to back)can be quite stuck. Use a pipe cleaner to get in there or a garden hose with a spray nozzle. However there is one more crucial step not mentioned in the manual or in Solution #1. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver and gently pop it open. Under the panel is a small chamber where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place. This should fix your problem.
Dec 13, 2009 | Bosch Dryers
I have a Legacy gas dryer. I find lint all throughout the laundry room. Always clean front filter befor use and also cleaned discharge hose.
It sounds like the exhaust tube is leaking somewhere inside the dryer.
If you've checked the discharge hose and wherever it connects to, on both ends, while it's running, then the leak must be inside the dryer, which can be a fire hazard.
It's not too hard (if you have the room) to take the back off of the dryer and look at the ducting. Be extra careful not to put your tools or hands near the electrical connections.
Once you've found the leak, separated pipes, etc., if it is inside, you can seal it with metal flashing tape - the very shiny "chrome" looking tape. Don't use cloth duct tape if you want the fix to last more than 6 months.
Jun 09, 2009 | Maytag Dryers
No air pressure to **** up dirt
First test suction on unit without the hose, is there suction? If yes, attach hose and test. If no go to the door to outside, attach hose to the top of unit where it blows (under handle on top), put hose out door and turn on. The stuff clogging the hose should blow out the end.
If it wasn't the hose check the wand, and then the power nozzle and using the above to clear obstruction.
FQ Master
Your Authorized Filter Queen Service & Supplies
888-637-4692 in Iowa
May 31, 2009 | Filter Queen Majestic Canister Vacuum
Lint bypassing lint filter and water in vent transition hose
your hose is to long you should vent it stright out wall if you can't you can buy a small inside vent kit it take so long to dry becuase it's not exsusted proper
Jan 27, 2009 | Maytag Neptune MDE6800A Electric Dryer
Lint filter sensor cuts off machine within 5-10 minutes.
It sounds like you might think you are sending this to Siemans? You aren't, Fixya is a self help website, people just like you helping others. Some of us are Experts on various subjects, like dryers.
Dryers need airflow and this lint filter just works out that either the temperature is getting too hot, or there is not enough airflow.
Trouble spots are usually the following;
Exhaust hoses too long.
Sharp bends on hoses.
Birds nests in hoses. Happened to me twice!
Wet lint build up as the hot wet air hits the first bend.
Plastic concertina hoses are really bad for air flow. Use the aluminium ones that are almost smooth.
Or my guess in your case, is vent flaps that are not opening fully or blocked. The whole external assembly with flaps and tube should be changed about every 5 years
Apr 24, 2017 | Siemens WTXD5300US Electric Dryer
Hello, getting an error of F:03 on my WTE86300US Bosch Condensation Dryer. Do you know what the issue is?
Aug 06, 2008 | Dryers
Dryers Logo
24 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
