Question about Canon Office Equipment & Supplies
My canon ir 2520 has a insert the drum error - Canon Office Equipment & Supplies
  • Canon Master
  • 521 Answers
Hi. remove the drum unit from the machine and verify the contact in the back side of the unit . maybe is dirty . if problem persist you need to try another drum . if problem peristaltic after that maybe there is damage in the hvt electronic board
Posted on May 01, 2017
  • 1297 Answers
SOURCE: Canon IR 2830 how do I install drum assy?
A.Removing thr drum unit.
Opem the front cover,shift down the developing assembly lockimg lever to unlock the developing assy.Slide out the left cover,holding the grips,pull out the drum unit.When removing the drum unit be sure to hold the two grips and take care not to scratch or soil it.
B.Cleaning the photosensitive drum.
If the surface of OPC drum is soiled wipe it with a flannel cloth coated with toner.Do not use paper,lintfree or otherwise.
Posted on Nov 22, 2009
  • 1219 Answers
SOURCE: Solution for canon ir 2520 error code E000020
E020 0000
The path between the sub hopper and the developing
assembly is clogged with toner.
1.Check the rotation of hopper motor gear. (If rotating, false
detection by the sensor is doubted. Feed the toner to the
developing unit in service mode: CLEAR>ENGIN>TNRINST.)
2.Replace the Developing Assembly Toner Sensor (TS1).
3.Replace the Sub Hopper Toner Sensor (TS2).
4.Replace the DC Controller PCB (PCB4).
* 28 * or MENU and #
Posted on Jul 01, 2010
  • 7733 Answers
SOURCE: I want to install a
go to Canon U.S.A. : Support & Drivers : Consumer & Home Office
Posted on Oct 23, 2010
  • 140 Answers
SOURCE: canon iR 2520 toner install problem.
u can go in service mode by pressing additional function + 2+8 then go in clear by pressing scrolling, then go in engine. after press ok in tnrinst. machine will process for 2 minutes. for toner installation.
Posted on May 09, 2011
SOURCE: what it a finisher for
help me please , i fixed finisher ir2520 finished and i open power
finisher is runing left to righ,panel show aready about 2 secon
it show e000716, how can sobe.
Posted on Jul 20, 2012
Want to clear error code on ir 2520
Go through the following to clear the error: CLEAR > ENGIN > ERRCLR; and then turn OFF and then ON the power.
Best regards,
Nov 29, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
What dose code 0002 means in canon ir 2520
that error means there is over temperature detection . you need to clear that error from service mode
May 04, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
How can i fix the error code e000002 shown on my canon ir 2520 photocopier
Unplug the printer let it sit for one minute than power it back up. If the error doesn't clear repost.
Mar 05, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
Conon ir 2520 erore code e000750
E000 errors are usually a bad fuser (also called fixing assembly by canon) You should buy FM4-3367-000 (for US/ Canada / Mexico 110V version.
Sep 11, 2014 | Canon imageRUNNER 2520 Laser Multifunction...
Error Code E000197
check the flat cable of dc controller to main drive pcb
Jan 13, 2014 | Canon imageRUNNER 2525 AllInOne Laser...
Solution to errorE000003 0f ir 2520
Press the additionel function button & press 2&8 buttons at once and again press additionel function .select COPIER and FUNCTION and CLEAR and ERROR andpress OK button.
Feb 26, 2013 | Office Equipment & Supplies
My canon image runner 2520 has been duly bought and well powered, but it brings error code e000020 and it does not print or scan,i need immediate help.
the problem is when i have replaced the drum of my canon ir 2520,appeared for me two big black lines and then appeared that code :e000196.thankssssssss.
Jul 20, 2011 | Office Equipment & Supplies
324 people viewed this question
old marine
old marine
