Question about Thermador Ovens
Thermador smw272 oven does not heat. the op panel works, light and fan comes on but element does not heat. Element is 22 ohms.
2 Suggested Answers
  • 310 Answers
SOURCE: thermador smw272 oven does not heat. the op panel
Likely to be the Hi Limit Switch or the relay/power board.
Best Regards,
Posted on Jun 19, 2010
Broiler element doesn't heat
Oven Won Turn on
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Feb 09, 2014 | Thermador SEC301 Electric Single Oven
Burnt wire at spade connector
If you are unable to catch the wire through the front of the oven where the terminals go through then you will have to pull the oven from the wall and remove the rear panel. Of course make sure the power is off before attempting the repair.
Nov 17, 2013 | Thermador SMW272 Electric Double Oven
Thermador Built in oven scd302 not heating upper oven, lower oven fine. Heating element not glowing red as the oven below it does.
Problem is usually either temperature probe or heating element.
Grab a multimeter and set it on impedance (Ohms).
Remove first temperature probe and then heating element.
If either probe or element is reading open (ohms infinity), then replace the part.
If both probe and elements are not open, then the problem is either wiring or oven electronic control. The most common fault resulting in no heat is the temperature sensor located inside the oven cavity.
May 31, 2011 | Thermador SECD302BPSS Electric Double Oven
Best Regards,
Jun 19, 2010 | Thermador C302U Electric Double Oven
Teperature i snot rising above 100, why?
Assuming your Thermador is electric, and it is only warming up a little, this is usually one of three things:
1. Heating element - with oven power disconnected, check that the elements resistance is in spec. Usually around 20 ohms.
2. Thermistor - this senses the temperature of the oven. Again, check the resistance. Depending on your model, it should be around 1050ohms at room temperature.
3. Electronic Control Board. These can be rebuilt quickly and reliably at Some are still available to buy online.
Hope that helps
May 21, 2010 | Thermador SMW272 Electric Double Oven
Bake element does not heat up but broiler does. Do
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
Apr 06, 2010 | Thermador SMW272 Electric Double Oven
Heating element will not heat
With all that you said, I would suspect an open or faulty element. It is pretty much the most obvious solution.
If you have any electronically ability and you are going to open the oven, use an ohm or resistance meter, check the amount of ohms and use the upper element as a reference for the correct reading.
The element will either read open or good. You can use a light tester also and if the light lights between the two connectors of the elements, then it is ok and look elsewhere.
Mar 01, 2009 | Ovens
Oven will not heat - Thermador SMW272 Electric Oven
since you said the broiler does work , take the wires off the broiler element and put on the bake . then when you put on the broiler the bake should work . the light bulb principle, just remember to wrap all loose wire with electrical tape and disconnect from wall while working.
Dec 12, 2008 | Thermador SMW272 Electric Double Oven
Ovens Logo
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
