Question about Ovens
Hello I have a uc30bn2yu60001 with a f5 code what is this code
My whirlpool oven is showing an E1 F5 code. It did it once but I can't clear it now.
E1 f5 code oven - YouTube
? 1:51
https://www.youtube.com/watch?v=5F1vwVpmG9U
Dec 28, 2014 - Uploaded by Jay Dornbos
Door locked then threw the code so now the door is locked and will not open. ...Whirlpool Oven - has E1 F5 ...
Nov 23, 2016 | Whirlpool Ovens
Ge oven jkp27 code f5
Hello Donald,
The F5 error code means that the control board has detecteda error within it self and theirfore the control(also called clock or EOC) needs to be replaced. The F5 error code can be cleared by pushing the cancel/off button and if it returns a short time later their is defiently a malfunction inside of the clock and it would need to be replaced.
GENE
Sep 28, 2011 | GE JKP27 Electric Double Oven
Tried to Auto Clean. Got error message: Door -F-5. It started to warm up but would not lock. What to do? Manual not to be found in house. Oven is about 13-15 years old. First problem I have had.
The F5 error code means that the control board has detected a error within itself and the control board needs to be replaced. The F5 error code can be cleared by pushing the cancel/off button but if the error code returns the control board would indeed need to be replaced.
FYI when ordering the control board it also may be called the clock or eoc
GENE
Sep 23, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
What is F5 Frigidaire oven unit, it's beeping and
The F5 ERROR code means that the self check that the control (also called clock)board runs to check itself has failed and the control has detected a problem within itself and the control must be repalced.
Gene
Aug 10, 2011 | Frigidaire Ovens
Getting error code EO - F5. What's the fix???
Hello & Welcome to FixYa
Error code F5-E0 is a door latch failure and is displayed due to malfunction of door latch-switch assembly. First try to check the door latch switch, if fine then recommended repair is replacement of door latch-switch mechanism. Please get back to me if you have any other questions.
Kevin
Mar 07, 2011 | Whirlpool RBS275PD Electric Single Oven
Oven door won't lock & begin cleaning process. Error code F 5 E 1
Hello there:
normally on these ovens this code that you have can also have a couple of different codes that goes with it but they are all the same meaning
F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective so what you will need to do is to replace this switch
here is the info
Item #
589837 Price
$162.60 In Stock?
Aug 16, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Tappan range error codr f5
Hello,error code f5 means temp too hot Replace oven temperature sensor
Thanks
May 26, 2010 | Tappan 30IN ELEC IGNa Oven
Error code F3 and F5
Hello there:
Here is the code for these 2 codes hope they are very helpful for you
F3
Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
Feb 04, 2010 | Maytag CWG3100A Gas Single Oven
F5 error on a Kenmore Gas Oven
f5 is a door lock code there is a problem with your door latch. its should lock the door at a crtain temperature and its not.
Mar 31, 2007 | Kenmore 30169 Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
