How do you backspace when in a program like kodi
I installed kodi krypton. Now i cant get out of that settings page and back to my regular screen..
Update your Kodi app and install a good Kodi build. Here are the updated and working best kodi builds you can install. 8 Best Kodi Builds for Best Kodi Setup The Tech Toys
Dec 24, 2017 | Televison & Video
Kodi gone into all apps how do i restore ares wiazard and kodi
Get the new URL for Ares wizard which I am sure does not exist as Ares Wizard has shut down. The next best option is No Limits Wizard, go for it. Or you can install best kodi build 19 Best Kodi Builds To Experience The Colors Of Kodi for smooth streaming.
Sep 22, 2017 | Televison & Video
After installing kodi 16.1 jarvis ..getting message kodi has stopped working !!!
There is a possibility that you have your cache filled up on kodi. You can clear cache on kodi by following the given steps at the end of this post. Secondly you can setup best kodi builds to continue smooth streaming.
Clear Cache on Kodi:
  1. Open Kodi Jarvis > Then click on System menu in front of your screen > Now select File Manager > Double click Add Source option at the bottom.
  2. Once you click on Add Source, a box will soon appear where you need to click on 'None' option and type http://srp.nu/ > Click Done > Type URL Name below 'Super Repo' > Click Done > Then click OK.
  3. Once you are done, go back to Kodi Main Menu by pressing 'Esc' button on your keyboard > Go to System > Then select Add-ons > Then click on Install from Zip File > Super Repo > Then select Jarvis > Click on Repositories > Superrepo > superrepo.repo.0704.zip
  4. Now select Install from Repository > Then Super Repo Repository [Jarvis][v6] > Go to Add-on Repository > Select SuperRepo All Repository [Jarvis][v6] > Hit Install
  5. Go back two steps and click on Install from Repository > SuperRepo All Repository [Jarvis][v6]> Program Add-ons > Merlin Wizard > Install
  6. Open Merlin Wizard, go to Tool Box option > Here you will presented with 3 options i.e. Clear Caches, Delete Packages, and Delete Thumbnails. The space that each of these options consume are also listed below these options.
Sep 07, 2017 | Televison & Video
Kodi on 17.1 keeps stopping in the middle of a movie
First of all you should be using 17.4 and sounds like a buffering problem. There are many tutorials on you yube that can walk you thru. There is also something in ares wizard that after opening program then go to tweaks and follow instrustions there.
Sep 03, 2017 | Televison & Video
I have the h96 pro android box tv its the 7.1 3g 32 its not stable programs say not responding or it freeze or dont download could someone help me
First of all I would load complete kodi wizard from google play store so you can start with erase build. There are a lot of tutorials on kodi on you tube that will help a great deal.Also make sure you have the latest kodi program 17.4 now also on play store. I like to use kodi no limits magic build as I find it the most complete build out there.
Aug 31, 2017 | Televison & Video
I lost my build on kodi 17, I help with retrieving it
In order to backup Kodi build you will need to go for the pre installed backup addon or you can install with the following method:
Select SYSTEM
Select ADD-ONS
Select INSTALL FROM REPOSITORY
Scroll down and select KODI ADD-ON REPOSITORY
Select PROGRAM ADD-ONS
Scroll down and select BACKUP
Select INSTALL
Wait for ADD-ON ENABLED
Once it is done, try to install 19 Best Kodi Builds To Experience The Colors Of Kodi
Aug 14, 2017 | Televison & Video
My box will not stream its less than a year old i think its because it has not been set up for a while thanks
If you are talking about a kodi box then you may need to clear the build and add another build. Try going to google play store and add complete kodi setup wizzard. All the tools to refresh the box are in the program. Check also you-tube for many kodi tutorials on what ever yo need.
Jul 30, 2017 | Televison & Video
Can you explain in simple terms that if I buy a fire stick with kodi, does that means it automatically streams various films and music from Amazon or Netflix foc. Does it needs to be jail broken
Why would you buy kodi installed FireStick when you can do it yourself in a few minutes? I mean, OK, you don't have any problem to spend some additional money in buying Kodi preinstalled Fire Stick but what if you get problems later? It is always better to know how to install Kodi on Firestick as it will help you in future too. How to Install Kodi on FireStick
Jul 03, 2017 | Televison & Video
How to addons to kodi
These days it is harder to find working Kodi Addons than installing them. Check out the link I am adding here to install Kodi Addons for different purposes such as Movies, Anime, Live Sports, Live Tv, and much more. There are total 75 Addons that are working in 2018 (January) 75 Best Kodi Addons 2018 Download for Kodi 17 6 Krypton Updated
Dec 27, 2016 | Computers & Internet
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
