Question about Oreck Vacuums
Part number for an Oreck Axis fan housing
I think it's the same part for an XL-21 vacuum but I'm not 100% sure.
Agent Don
  • 310 Answers
SOURCE: Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
Posted on Apr 09, 2008
reddevil6
  • 1673 Answers
SOURCE: replace belt on my oreck xl
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
Posted on May 09, 2008
  • 5 Answers
SOURCE: My upright Oreck Vacuume XL 2
the main tube is clogged.
unplug it, open bag area, remove bag look for clog.
if clear, take off lower coller, pull up tube, remove blockage, either in tube or fan area.
if clear, look in bottom by intake area for blockage.
fan can not run backwards.
good luck.
Posted on Oct 15, 2008
  • 20 Answers
SOURCE: Oreck xl 9100 how to replace the fan
I just replaced the fan (plastic) on an XL9100. I assume you got the bottom plate off (5 screws).
Undo the single screw holding the suction housing in place.
Remove the two screws holding the motor in place and gently lift the assemble up, being careful not to stress the wires. The motor and fan assembly should now be exposed. If the nut holdling fan in place is removed, the whole fan should slide right off. If it does not, try a little WD-40 on the shaft and wiggle and move from side to side. (I slipped a small drill bit between the motor fan (motor cooling fan) to prevent the shaft from turning when you remove the nut.) Be sure you turn the nut counter-clockwise to remove it.
You should now have the fan off. Reverse the procedure to place the new fan - following the directions carefully as some assemblies need a washer and "feathered" washer on the top.
Assuming everything went well, it should work.
My 9100 sucked a magnetic bearing and trashed the metal fan to where suction was weak. The new fan works great.
Cheers
Posted on Mar 27, 2009
  • 121 Answers
SOURCE: Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Posted on Oct 16, 2009
Testimonial: "Quick answer and the same thing I found out after I posted from an Oreck repair site. Thanks."
Why is my oreck xl 21 hard to push on carpet?
sometimes the little rubber wheels in front wear out of round and bind. Try those first (if they're the tiny ones you must buy a pack of 20 from oreck directly) and Orecks are known for being hard to push when bag begins to fill up.
May 03, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Oreck xl 21 fan housing has new design. willit stillfit my older vac
It should. You can call Oreck and talk with them and give them the serial number off your vacuum and they can look it up and tell you for sure if it will fit or not.
Feb 18, 2013 | Oreck Great XL21 XL 21 8 Pound Upright...
How do I take oreck apart?
5 screws on bottom plate. Then couple to hold fan housing and motor. Not a bad job just takes a little juggling finesse.
Jan 20, 2013 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck XL 21 stopped self perpelling, what so I need to replace or fix?
There is a small drive belt that turns the wheal that may need replacing open the drive belt compartment and replace like the brush belt. Turn the vacuum upside down to take out the screws it helps keep things in place.
Dec 26, 2012 | Oreck XL Ultra Bagged Upright Vacuum
Oreck owners manual model xl 21-600ECB
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave', for today.
I suggest that you click on the following link and download your Oreck Product User Guide:
CLICK HERE
All the best
Ben
http://www.oreck.com/Owners-Guides
Oct 03, 2011 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck XL vacuum does not have enough suction to pick up dirt. Any suggestions to remedy this problem? The belt is strong, the bag is not full, and there do not seem to be any obstructions.
Turn the machine on and be sure the bag expands quickly and fully like a balloon. If the bag does not fill with air, or is soft, there is probably an obstruction inside the handle tube or fan housing. Disassemble the handle to check for blockage, or remove the bottom plate to check the inlet to the motor fan.
Jan 19, 2011 | Oreck XL Ultra Bagged Upright Vacuum
good luck.
Jun 07, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Vacuums Logo
26 people viewed this question
Top Oreck Vacuums Experts
Gerry Harvey
Gerry Harvey
john h
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
