Question about Building Materials
Light stays on.door will not open with remote or wall switch.
SOURCE: Lift-Master garage door opener Model 1045-6 1/3 hp
There is a thermal cut out in the motor, usually the motor must cool before the opener will operate again. If the opener only operates 3 times it must be heating up too quickly.
First you opener is only made to do your job for you, which is opening and closing the door. If the door does not operate properly manually the opener will not operate properly.
When the door is disconnected from the opener it should lift easilly, it should basically stay at whatever point you let go of it (midway and fully open) and it should close without slamming down. It does not matter what size the door is!!! If it does not something is wrong with your springs and the door can be VERY DANGEROUS!!
With that being said it sounds more like a static lock-up possibly a loose ground or even a circuit problem in the home.
Bryan
Posted on Jun 28, 2008
  • 7 Answers
SOURCE: sears garage door opener problems
check the motor reset or power connected to the motor and check the chain or screw to see if it is in a bind.
Posted on Sep 25, 2008
SOURCE: flashing green light on Sears garage door wall opener HBW0777 1/2
Same problem - The flashing wall button indicates the remotes are locked out. I fixed mine by pushing the green button on the back of the opener. I did nothing else , just left the LED time out.
Posted on Dec 13, 2008
  • 905 Answers
SOURCE: Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Posted on Dec 29, 2008
ktkodama
  • 37 Answers
SOURCE: Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
Posted on Dec 30, 2008
The light on the Garage door blinks but doesn't stay on.
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
http://www.linearcorp.com/pdf/manuals/LCO75.pdf
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
Dec 02, 2013 | liftmaster Garage Door 1/2 Hp
Hi, I have an older garage door opener, Genie
If the opener doesn't work with the button on the wall the opener is defective, either the receiver board or the motor drive circuit or the motor itself.
May 03, 2017 | Transmitter Solutions Building Materials
The door will open just fine, when closeing the door (by the wall switch) it will not close unless you hold the buttom down. The sensors at the bottom of the door has a green light on one side nad the...
Your door switch is bad. You can get one at home depot, it's nothing more than a door bell button. Your lights are correct and I bet if you try to close with your remote it works. That also will verify it's a bad button.
Mar 01, 2011 | liftmaster Chamberlain Garage Door Opener...
The green light on the wall switch is blinking constantly yet it works to open/close the door. The remote does not work. Any suggestions?
Press and hold the lock button on the wall control for 3 seconds. The light will stop blinking and your remotes will work.
May 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Overhead light stays on all the time on craftsman garage door opener
Hello. If the light stays on all the time check these:
A. The light time delay on the opener will keep the light on for approximately 4-1/2 minutes after the system has be activated, then will turn the light off automatically.
B. If the opener has a worklight switch (which is supplied only with a four-function wall console), slide the switch to "OFF" position.
C. If the opener has a pedestrian switch (which is supplied only with a four-function wall console), the light will stay on for 4-1/2 minutes after the pedestrian door has been opened.
Mar 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a door with two buttons and remote but only
On the wall control with the flashing light press and hold the button with the lock icon for 3 seconds and release.
Jan 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote and my keypad remote both stopped working as of today
CHECK TO SEE IF THE LED ON THE WALL BUTTON IS BLINKING - IF IT IS SOMEONE HAS PUSHED THE VACATION LOCK BUTTON.
PRESS THE LOCK BUTTON TO MAKE THE LED STAY CONSTANT AND IT IS FIXED.
HOPE THIS HELPS
Nov 17, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage door will open with remotes, but not with the wall switch
Sure sounds like the wall control is bad. Very common problem.
Jun 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
43 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
