What would cause it to go blank?...it is connected properly
What would cause the audio/trip computer to quit, while driving down the road?
this sounds like a loose connection to these controls, have you had any work done on your vehicle recently? If you have this may have caused a connection to become loose , whilst the work was carried out, if not then i would check the connections to the various components and make sure they are pushed together properly, this will involve removing the lower dash panel , you have'nt mention vehicle so this is a general way to proceed, trace the wire looms back from the component and check each connection as you find them , hope this helps
May 06, 2017 | 2005 Cadillac CTS
Beeps continuously
This is almost ALWAYS caused by a poor power connection. Check, lubricate and clean/inspect your power cables. I have seen poor solder connections or corrosion prevent the ST 2000+ from getting the horsepower it needs to operate properly.
Hope this helps.
-Steve
Apr 23, 2014 | Raymarine ST2000 Tiller Pilot A12005
If i select source to pc display will become blank and power indicator blinking.
• You can check if the product is working properly using the Self-Diagnosis function.
• If a blank screen is displayed and the Power LED blinks even if the product and the PC are properly connected, perform
the self-diagnosis function according to the procedures below.
1. Turn the product and the PC off.
2. Separate the signal cable from the product .
3. Turn the product on.
4. If the product is working properly, the message appears.
In this case, if a blank screen is displayed again, make sure that there is no problem with the PC and the connection. The
product is working properly.
Is a blank screen displayed and does the power LED blink at
a 1 second interval?
1. This occurs when the power saving function is running.
If you click the mouse or press any key, the screen will be
turned on.
2. This occurs when two monitors are connected,
is and Magictune is running. In this
case, characters on the Magictune OSD may appear
corrupted. To run the Magictune, the must
be set to . Please restart your PC, set the
to and run the Magictune.
Jul 07, 2011 | Samsung BX2231 21 inch Monitor
When I turn on my Cornea MP503 monitor on it has a message in a blue box saying Power Saving Mode and then goes blank and light flashes orange-green over and over.
Check the VGA/ DVI cable connection from your Monitor to PC, this also could be caused by VGA card on you PC that doesn't work properly, unfirmed connected to its slot etc, check also for unfirmed connected memory card/ RAM.
Dec 13, 2010 | Cornea MP 503 15 in. Flat Panel LCD...
My lite-on combo sohc -4832k driver is supposed to be a DVD writer as well but every thim i try to put a blank dvd r into the drive to burn a movie i made it just ejects it and says to put in a blank on....
make sure the drive is getting enough power
one bad/faulty lead can cause a computer lots of problems
make sure all leads that connect to the dvd drive are seated properly including the electrical lead or just replace them there probably old/faulty
hope this helps
Nov 09, 2010 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
Computer powers on, no beep, monitor is blank
open the tower, on the mother board you will find the RAM card approx 6 inches long, take out the card and restart the comp, you should get the beeping sound and the mother board is fine, if no beep that indicates the motherboard has gone bad.
place the ram card properly into the same slot and then restart the computer. NOTE while putting your hand into the comp components always make sure that the pwr cord is pulled out or else you will get shock.
also check the cord at the back of the harddrive should be fixed properly. take it out and refix it at both ends . probable cause is there is some loose connection of the cord or the RAM.
May 10, 2010 | Computers & Internet
Monitor totally blank
You have a power supply issue. Something is causing teh supply breaker to trip. You will need to find a local repair shop to pin point the issues.
Oct 03, 2009 | HP w1907 LCD Monitor
Blank monitor upon turning on PC
Well.... The motherboard could be dead... or check the power supply unit. Check the memory chips, see if the capacitors around the processor looks blown up (then motherboard is kaput) or make sure the monitor is properly connected to the motherboard monitor port... It could be numerous reasons ... See if the processor cooler fan is running and check if the processor's cooling paste is OK which would cause the processor to run TOO HOT and would prevent the PC to start-up etc etc....
Jul 20, 2009 | AMD M863G (M863G15CV22ARV000) Motherboard
Problem vith lap-top
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
29
Aug 19, 2008 | Computers & Internet
Blank white monitor
mostly the problem is cause by loose flex cable only connected to your lcd panel board. check if it mounted properly, otherwise the lcd panel board may be defective.
Aug 16, 2008 | Sony Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
