Question about Pool & Spa
Our pool is locked in the Spa setting. We cannot change it to the pool setting manually or with the remote?
  • David Spradling
    David Spradling Nov 10, 2017
    is unit on auto or service
    Top Expert:
  • Pool & Spa Master
  • 7,361 Answers
If cannot change in sevice bad PCB board
Posted on Dec 30, 2017
  • 171 Answers
SOURCE: Spa Pools, setting up spa pool with chemicals etc
Hi curlyall,
I'm Harvey the Master Plumber.
Your problem is: You have just brought a secound hand spa, you are woundering what sort of chemicals etc are required, there are no instuctions with it
If your spa is the type that you fill once, then you must treat it just like a swiming pool. Go to the local pool supplies store. They will be happy to set you up. Don't forget PH testing kit! Test it every day. And I prefer non chlorine chemicals. It's also helpfull to have a small submersible pump in case you need to replace the water sometime. Happy soaking!
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 06, 2008
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
  • 125 Answers
SOURCE: Jandy Aqualink RS4 controller won't turn lights on/off
AquaLink Trouble shooting guide
  • 125 Answers
SOURCE: We just moved into our home and there is no manual
Here is a link for the Manual and trouble shooting guide. Aqualink
Posted on Mar 04, 2009
  • 832 Answers
SOURCE: Compool 3600 Spa side remote
Do not reset while the motor is running. Reset the CP 3600 when the power is on but with the motor off. OK.
Posted on Nov 25, 2009
My jandy control panel is locked. how do I get it unlocked
About 4,480 results (0.49 seconds) Search Results
    [PDF]AquaLink RS All Button and OneTouch ... - Jandy
    Jandy Valve Actuator . .... If power is then interrupted, the controller will lock up. ...process, which can display its current status on the indoor control panel. Use the following steps to get to this "diagnostics" information: ...... lect Device to unlock.
    [PDF]Jandy Legacy WLRZ Control Quick Start Guide
    The Legacy WLRZ will heat the pool or spa only when the filtration system is running and the ... DISPLAY LIGHT: Controller lights can be set ON, OFF, or to ... Make sure the control is in the ON mode ... To unlock, press and hold the up and.
    Clock" Mode; Locking/unlocking The Keypad; Remote ... > ... > LJ > Installation and operation manual
    Jandy LJ Manual Online: Clock'' Mode, Locking/unlocking The Keypad, Remote Control Operation, ... display of the controller will show the time set for the.
    Jandy AQUALINK RS TELELINK KIT Locked - Questions ... > ... > Jandy > Jandy AQUALINK RS TELELINK KIT
Feb 03, 2016 | Jandy Pool & Spa
How to set raypak heater to remote
hold down mode button or scroll to remote make sure wire from control system is connected to pool spa com if pool only only need pool and com
Sep 29, 2014 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Panel is changing from pool to spa (including valve changes, etc) spontaneously
go into control system and disconnect spa side remote they start to ghost when they get older or a cut line. mostly a knicked wire when built if it goes away run a new spa side remote
Jul 22, 2014 | Hayward Pool & Spa
I have an Aqualink RS that will not turn the pool's filter pump on either by remote or in service mode
check your jandy valves make sure they are fully open or closed they can lock your system if they are not in full closed or open mode second option is to try to turn jandy valves manually to if they are in spa mode manaully change then to pool mode or if they are in pool mode change them to spa manually on the jandy valve there is a 3 way switch this is where you can turn them manually wt we want is to send the signal back to the main control outside that the valves are in ready mode look in the main control open the door and see if there is a red light that indicates another problem if you can send me where the red light is what the red light label says it will help if you send me the aqualink model #
Oct 06, 2013 | Standard Power Center for Aqualink Rs
Cant change pool heater temperature
see if set on remote if not bad display board or hold up and down at same time for 7 seconds maybe locked
May 21, 2013 | Hayward Pool & Spa
Ho do I turn on the backlighting on my Jandy Handheld remote?
It's under Equipment, System Settings. When I first got mine, it kept losing its configuration and wouldn't connect regularly to the base unit. I had to change the wireless channel it fixed both. My pool builder was useless. "KB Custom Pools" Austin, TX
Aug 22, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Pump and spa light come on when not set and spa drains
disconnect spa side remote if it still does it replace remote if not reset board
Oct 28, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
RPS Code
remote pool and spa if no control take off tstat remote and put on manual
Mar 05, 2011 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Brand spankin' new Master temp 400 NG,won't heat past 77° spa is set at 101°,pool at 88°, does heater pool/spa temps have to be manually set to max(104 i assume) for intellie touch to...
if the intellitouch is properly wired to the heater, it should all be automatic and you should be able to control it all from the remote.
there should be three wires connected to the circuit board behind the manual control on the heater (labeled "POOL", "SPA", "Common"). Those are the wires that the intellitouch uses to communicate with the heater.
You can download manuals from the Pentair website.
Aug 24, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Minimax pool heater cuts out at 91 degrees when remotely set for
Turn the temp set knobs on the front of the heater all the way up do both pool & spa temp.
If that doesn't help flip the selector switch on the front of the heater the pool temp. This switch doesn't control what heats up Pool or spa it just selects the heater on and which thermistat to use
May 23, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Pool & Spa Logo
115 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
