Question about Kenwood Irons
Replacment of electric cord on Kenwood Blue Steam Iron
SOURCE: Attaching a plug in cord to a philips Electric Steam Iron
i need a new wire--mine had a short in it--how do I go about repairing it?
Posted on Jul 16, 2008
SOURCE: Hinari steam vapor iron Model HIN001
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
Posted on Oct 07, 2008
SOURCE: have just bought kenwood steam generator iron but
Press the variable steam control and the power on/off button to stop the light flashing - that worked for mine!
Posted on Sep 30, 2009
Sheikhtijani
  • 1284 Answers
SOURCE: I need to replace the power supply cord on my Rowenta DX8600 iron
Hi, you need not to disturb yourself too much, just take the iron to any electronic repairer or electrician around you and they will replace the cord for you. They have the screw drivers for all types of screws...
Take care
Posted on Mar 24, 2010
heatman101
  • 43501 Answers
SOURCE: Black 7 Decker Steam Express AS250 Iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
Why does the cord to my rowenta iron not fully retract?
pull cord all the way out of the iron, make sure it's flat and not twisted when it gets reeled back in.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Aug 26, 2014 | Rowenta 1500W Steam Iron with Cord Reel...
Iron blows electrics
Check the cord for any kinks or cuts before checking the cord connection to the appliance itself for loose or touching wires. What is decalc the iron ?
Nov 23, 2013 | Tefal Superglide Fv3680g1 Anti-Scale Steam...
My iron keeps going on to standby while using it. Any ideas as to why?
use the following ideas
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
God bless you
May 22, 2013 | Irons
Hi my swan steam gen iron is faulty , when I press the steam button it pours with water from the metal plate part of the iron , any ideas ??? Thanks
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle .
Feb 27, 2013 | Irons
Water distiller keeps shutting off
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat.and replace if necessary.
Test the heating elements and power for blowing fuse.use the DVOM
God bless you. see the diagram 2_6_2013_8_23_01_pm.jpg2_6_2013_8_23_30_pm.jpg
Feb 06, 2013 | Irons
My iron is getting hot but giving no steam can anyone advise
Jan 31, 2013 | Breville Vin227 Extreme Steam Steam...
Troubleshooting of flat iron for clothes
follow the steps and use the common sense. God bless you
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 20, 2012 | Irons
My rowena precision steam iron steam does not work
Solution for me:
I just bought a Rowenta Precision for $5.95 at Goodwill. I brought it home and it didn't work
I read about the cords and weird size screwdriver needed. It sounds like a lot of work. So what I did was push the electrical cord into the iron. it didn't seem to move but must have. The iron works perfectly now. Such a deal!
Mar 05, 2011 | Rowenta Precision DM580 Iron
Steam gauge is broken and iron will not produce steam
http://www.fixitclub.com/Parts_Components/Appliance_Controls.shtml click the link  Maintenance and repair tools you'll need to fix an electric iron include these:
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial soleplate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
  • Metal cooking pot
you will need a speacial tool screw driver  also called as g5 screw driver to open it.available at local repair store. If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
Mar 26, 2009 | Rowenta Irons
Irons Logo
48 people viewed this question
Top Kenwood Irons Experts
Tom Chichester
Bill Boyd
Jay Plesset
Are you a Kenwood Iron Expert? Answer questions, earn points and help others
