Question about The Home Security
TypeDC6-UK-WH UNIT ONLY WORKED FOR ONE WEEK.Then failed push button lights up, bell unit rings when the little button on top is pressed but no wireless connector between bell unit and the hand switch.
  • 242 Answers
SOURCE: WIRELESS BUTTON
Somewhere on the laptop should be a button to switch wifi on and off. Most time near the volume controls...
Have you put that one on?
Posted on Mar 27, 2008
skrbin
  • 121 Answers
SOURCE: samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Posted on Feb 16, 2009
ButtFuzz
  • 463 Answers
SOURCE: dings sometimes with out pushing the button ??
I believe there are either dip switches (or old-fashioned "jumpers" in both the button (the 'transmitter') and the dinger (the receiver). See if this is the case, and that the dip switches (or jumpers) are in the same position in both units. Then, simply switch one of the dip switches (or jumpers) to another 'position' in both the button and the dinger. There ya go...
Posted on Mar 05, 2009
SOURCE: wireless button on packard bell easynote MV35-202?
Fn / F1 or some models are Fn / F2
Posted on Oct 06, 2009
  • 7 Answers
SOURCE: Sub-Zero 690 Side by Side Refrigerator light switch intermittent
This is a common problem - replace the left light switch with Sub Zero Part # 3060140.
Posted on Dec 11, 2009
How to change chime on a blyss DC3-UK-WH
I couldn't find the manual instructions for your Blyss MP3 wireless door bell... I asked your question on the UK Amazon store that sells that unit, but who knows when or if anyone will answer it
Blyss Wirefree battery door bell with additional plug in bell
I found a similar manufacturer's MP3 wireless door bell.. you might find some idea from that if it might be similar or the same ??
http://www.deurbel-zaak.nl/Files/2/24000/24385/Attachments/Product/j0vB6W640153772PG8ZrR6gr9Xr1363i.pdf
Besides that, you have listed this question in the wrong category. The below linked section may have others that are more qualified that might be able to answer your question who are more familiar with your product:
Questions Answers for pair blyss wireless doorbell
>> If this was helpful in any way, please let me know so that I will continue helping others, by Clicking on the Helpful button below. Thank you :)
Dec 04, 2015 | Cell Phones
Stop beeping hour?
According to the directions: Press B - bottom left button,to go into Alarm Mode. Press D - upper right button - to activate the alarm and press again to activate the Chime, which shows on bottom left as a bell. To activate these press D. To DEACTIVATE them press D again. Press B 3 times to return to Time Telling Mode. It took a few tries, but D and B are the keys to stopping that annoying chime!
Oct 18, 2013 | Armitron All Sport Digital watch
Siemens jsjs-208 door bell
Mine keeps doing it. Taking a battery out to force reset on the ringer but mine seems to need this every few weeks. Tried new batteries but still problems.
Mar 19, 2013 | Bell Sports Wireless Door Bell with...
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
I have a desa DD100S wireless door chime but for some unknown reason the bell push is not working, I have tried replacing the battery but still unable to ring chime. The actual base unit is fine and...
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
Mar 09, 2011 | Desa International White Wireless Plug In...
Hello! i've purchased one of your door chimes
Each push button should have jumpers in the back of them. By the description you say its the wireless but your text describes wires. If it is the wireless there should be jumpers, little black blocks that make an electrical connection, inside the push buttons and the receiver. Be sure you read the manual about which ones go where for your dual operation.
Jun 24, 2010 | Heath Zenith SL-6136-WH Basic Solutions...
I have a byron SX85R plug in wireless door bell, i need to change the frequency/ or code, keep false alarming, cant find the instructions , also with the alarm, is a batterie alarm no. SX81R, which came...
From User Guide: Interference from a similar unit operating nearby: a) simply remove the batteries from the push button and door chime units and rest for 10 seconds, this will erase memory b) Insert the batteries into the push button and door chime units, the door chime unit will give 2-beeps to indicate that it is ready for the new registration code. Press the Push Button once, it will generate a new operation code randomly and send a wireless ignal to the door chime unit and it will sound to indicate that new operation code is registered and memorised.
(Note with this unit SX85R the door chime is mains powered, not battery powered, but above instructions are the same)
Oct 10, 2009 | Bell Cocoon Child Carrier
Button Press (Not Remote) Normal Door Bell Makes Slight Buzz Only
The electromagnet that causes the bell clapper to move when the circuit is closed by pushing the button is failing. Replace the bell unit.
Jul 07, 2009 | Desa International White Wireless Plug In...
Oven won't work!
timer must be set to any time of day for ovens to work, niormally you need to press either 2 or 3 buttons together to set time, if this fails you need to bypass the timer ele ctrically
Jan 08, 2008 | Belling 644 Electric Kitchen Range
Home Security Logo
Top The Home Security Experts
vince
Lawrence Oravetz
Are you a The Home Security Expert? Answer questions, earn points and help others
