I have two errors one add LTR paper and other add A3
3 Suggested Answers
wheatlandsvc
  • 1110 Answers
SOURCE: printer showing error message ...."printing
This means that your machine has received a print job that is teling it to print on paper that is loaded or supposed to be loaded in the bypass feed tray. You will either need to delete the print job using the operation panel or simple load some letter size paper in the bypass tray over on the right side of the machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Dec 18, 2010
moe_2782
  • 443 Answers
SOURCE: printer error load paper ltr
the papper is not in the printer propperly
Posted on Jun 17, 2013
How to change A4 display to LTR display
Go to Printers and Faxes, right click on the printer icon and select Printer Properties.
then select the paper type as LTR.
If in case you do not get the option, re-install the printer drivers.
Sep 08, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
In printer it showing Tray 1 ADD PAPER but [paper is added to the tray still it is showing that error so what to do ? give me the solution.
1.May be because of paper sensor.try to change it
2.may be you have given wrong paper size.u might have give wrong paper size.for ex for A4 paper u might have given some other size like a3. check this it will work for u
Jan 31, 2011 | Panasonic WORKiO DP-1520P All-In-One Laser...
Printer showing error message ...."printing
WheatlandServices
Dec 18, 2010 | Panasonic Workio DP-3030 Printer
Message Display on LCD of machine it,s load paper LTR
It means that you under printer properties/preferences - custom paper size have ltr size as your default, change it in desired size, eg. A4.
Then turn off and on the copier.
Or check the sensor position on your drawer. blue rail with triangle that must be on A4 or A3 depends on paper that you have in drawer.
Feb 10, 2010 | Canon iR 2022 Printer
H2 error when printing from pdf to A3 in multipurpose tray
H2 error code means that the paper size you are feeding into the machine does not match the paper size programmed into the machine. Minolta's are picky about these 2 size matching. So if you trying to print onto A3 then when you select the multipurpose tray it must read as A3.
Here is the info from the factory service manual:
H2 The length of the paper set does not
match that of the paper actually taken
up and fed in.
• Load paper of the correct size again
according to the set paper size.
• Turn OFF and ON the Power Switch.
• For copier tray: Slide out and in the
paper tray in which the size error has
occurred.
• For Manual Bypass Tray: Place paper
in the Manual Bypass Tray.
• For Multiple Bypass Tray: Unload
paper from the Multiple Bypass Tray,
then reload it back again.
Nov 23, 2009 | Minolta Di152 Laser Printer
Audi a3 2.0 litre fsi cylinderhead problem
Yes according to the dealer they are the same heads..
Sep 07, 2009 | 2006 Audi A3
Error 270940 for Estudio 350
The A3 paper will not pass through the copier when the cassete is full. Copier states "Add Paper". When you push the A3 tray in you can hear a winding sound and then when you startt to copy it asks you to add paper.
Apr 16, 2009 | Toshiba e-Studio 350 Copier
Canon Imagerunner 210S - A3 error
A3 is a metric size paper. The document you are trying to print must have been formated for metric size paper. When you print select "Fit to printer margins" De-select "Choose paper source by PDF page size" and select the proper page size and source.
Jun 09, 2008 | Canon imageRUNNER 210S Copier
Canon iR5000 Tray 3 problem
look behind the tray and see if there is paper stuck behind the tray. Good luck
Dec 18, 2007 | Canon imageRUNNER 5000 Copier
37 people viewed this question
k24674
jasbo
jasbo
