Question about Hisense Televison & Video
I have a Hisense TV and the closed caption wont turn off. I go to Menu and the closed caption isn't high lighted. What can I do.
  • 93 Answers
SOURCE: Closed Captioning stopped working
if close captioning doesn't work in your television,try to clean the circuit of your remote.Just open it,wipe with the use of cotton and alcohol.I'm sure it will work
Posted on Nov 01, 2007
  • 305 Answers
SOURCE: Closed Captions won't work
make sure your dvd player has the capability to display closed captions, as not all of them do, also if it does have the capabilities, it may need a scart connection.
Posted on Jul 02, 2008
lukster
  • 217 Answers
SOURCE: Can't remove the Closed Caption on my Samsung
try putting it in the air channel mode and then see if you can access through menu
Posted on Jul 20, 2008
On the universal remote hit the menu button then on the TV itself use the vol +/- to select and the channel +/- to move the it up and down. it that simple
Posted on Aug 12, 2008
  • 374 Answers
SOURCE: closed captions will not work thru my tv remote
I hope this was resolved but this is a dish page and I am unable to answer Comcast issues.
Posted on Mar 01, 2010
Can't turn closed caption off on our Samsung Series 7000 LED TV
Make sure it isn't your cable or satellite TV service making the captions, as closed captions on your TV are separate from the ones produced by your service provider. If it isn't your cable/ satellite, open the TV menu and find the Audio/Visual properties section of the menu (audio and visual might be separate sections), and find the closed captions or CC options menu. When you do just change the setting from whatever it is on, to off. If your TV remote is fancier than mine (which it probably is), their could possibly be a closed caption button on the remote for easy access. In this case just push the button and change what you need to.
Jun 07, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
On certain channels the TV has a blackscreen come upwith letters across it???
This is probably the text box function of the closed captioning decoder. Look for the closed caption button on your remote and turn it off. It might be labeled "cc" or "ccd". In some cases you may have to go into the menu to turn it off.
I hope this is helpful to you.
Bobya.
Oct 18, 2010 | Hisense TC14FS68 TV
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
My kv-20520 tv wont turn off closed captoining
Maybe you have to scroll through the Closed Captioning options or your menu for a bit until you find it and maybe you blew your speakers
Jul 23, 2009 | Sony KV-20V80 20" TV
Closed caption
Closed caption wont turn off was solved by Bresnan tech. He told me the only way was to push the power button on my remote & then push the menu button right away & it would bring up a white screen & cc would be on it. I could't get it to work so I pushed the power button on my remote & the menu button on my motorola cable box & up came the screen & closed caption was on it. I disabled it & it took off the closed caption. Hope this helps
Dec 26, 2007 | Protron PLTV-32 Television
Turning off closed captioning
You should be able to turn off caption from remote. Go to menu for this
Dec 12, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
Televison & Video Logo
61 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
