Question about Hisense Televison & Video
Hi I have Hisense TV and I can't turn off the closed caption. It isn't high lighted in the menue area. What do I do
  • 93 Answers
SOURCE: Closed Captioning stopped working
if close captioning doesn't work in your television,try to clean the circuit of your remote.Just open it,wipe with the use of cotton and alcohol.I'm sure it will work
Posted on Nov 01, 2007
  • 305 Answers
SOURCE: Closed Captions won't work
make sure your dvd player has the capability to display closed captions, as not all of them do, also if it does have the capabilities, it may need a scart connection.
Posted on Jul 02, 2008
lukster
  • 217 Answers
SOURCE: Can't remove the Closed Caption on my Samsung
try putting it in the air channel mode and then see if you can access through menu
Posted on Jul 20, 2008
On the universal remote hit the menu button then on the TV itself use the vol +/- to select and the channel +/- to move the it up and down. it that simple
Posted on Aug 12, 2008
  • 374 Answers
SOURCE: closed captions will not work thru my tv remote
I hope this was resolved but this is a dish page and I am unable to answer Comcast issues.
Posted on Mar 01, 2010
Sharp Aquos LCD TV 52"
Does your cable company support CC?
Apr 08, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a Sony KV-27ts27 television that I bought secondhand, without a remote. I need to know how to turn on closed captions. When I had cable service with AT&T Uverse, the closed captions were working but...
Here is a link to the manual. It appears to me your set does not support closed captioning. It is too old. It mentions channel captioning, but that is for a channel identifier for reference. http://diplo-best.com/314.php?k=ac30c98e172782467c3895e8cba613ad&ID=87078&q=SONY KV-27TS27
Oct 31, 2013 | Televison & Video
Can't turn closed caption off on our Samsung Series 7000 LED TV
Make sure it isn't your cable or satellite TV service making the captions, as closed captions on your TV are separate from the ones produced by your service provider. If it isn't your cable/ satellite, open the TV menu and find the Audio/Visual properties section of the menu (audio and visual might be separate sections), and find the closed captions or CC options menu. When you do just change the setting from whatever it is on, to off. If your TV remote is fancier than mine (which it probably is), their could possibly be a closed caption button on the remote for easy access. In this case just push the button and change what you need to.
Jun 07, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
On certain channels the TV has a blackscreen come upwith letters across it???
This is probably the text box function of the closed captioning decoder. Look for the closed caption button on your remote and turn it off. It might be labeled "cc" or "ccd". In some cases you may have to go into the menu to turn it off.
I hope this is helpful to you.
Bobya.
Oct 18, 2010 | Hisense TC14FS68 TV
How do i turn off the subtitles on my toshiba 36hf72 tv, without the remote
The subtitles in dubbed videos VCD/DVD the process to follow are :-
The closed caption feature has two options:
• Captions—An on-screen display of the dialogue, narration, and
sound effects of TV programs and videos that are closed
captioned (usually marked as “CC” in TV listings).
• Text—An on-screen display of information not related to the
current program, such as weather or stock data (when provided
by individual stations).
To view captions or text:
1. Tune the TV to the desired program.
2. Press MENU, and then press x or • until the CUSTOM menu
appears.
3. Press z or y to highlight CC.
4. Press x or • to highlight the desired closed caption mode, as
follows:
• To view captions, highlight C1, C2, C3, or C4 (C1 displays
translation of the primary language in your area).
Note: If the program or video you selected is not closed captioned,
no captions will display on the screen.
• To view text, highlight T1, T2, T3, or T4.
Note: If text is not available in your area, a black rectangle may appear on your screen. If this happens, turn the Closed Caption feature OFF.
To turn off the Closed Caption feature:
Highlight OFF in step 4.
Note:
A closed caption signal may not display in the
following situations:
• when a videotape has been dubbed
• when the signal reception is weak
• when the signal reception is nonstandard
PS: If you do not want to set these function & their commands can be entered via the buttons on the TV set. Using the remote is much easier to operate............ sodeep
Oct 08, 2009 | Toshiba 36HF72 36" TV
Closed caption / universal remote
Couple things to try:
On the remote - Press "Clear" button
May have to turn off CC in the TV menus. Try Menu on the remote and look for closed caption there.
If remote doesn't work, can try with buttons on TV itself to get into menu and turn it off.
Here's a link to the manual for that remote:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=innovage&dv=universalremote&md=jumboremote&kw=&st=&ar=&dt=&so=&pg=1&file=others/innovage/jumbo-manual.zip
Mar 28, 2009 | One For All URC-4330 Remote Control
Turning off closed captioning
You should be able to turn off caption from remote. Go to menu for this
Dec 12, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
