Question about The Computers & Internet
I have a gateprotect GPA 600. Which process can I do to reset it to default without having to reinstall the license
How to recover dir-600 dlink router password withoute reset
You need to log into the dlink router and look at the Wireless Security and you will see the password. To get into the router you will need the ip address of the router, the default user id and the password. You manual will give you this info if you do not know it.
Get online and got to www.google.com In the google search box type: "Dlink Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals.
The IP address to put in your browser to get into the router is: 192.168.0.1
The default userid is: admin
There is not default password, so leave it blank.
Jun 05, 2012 | D-Link DIR-600 Router
Dell minin 910 stops reinstallation of os at license agreement screen
It is possible the install process is missing a critical file to complete the windows installation, or the hard drive has issues, something that will require professional intervention.
Mar 27, 2012 | Dell Mini 910 Netbook
How to change password of dlink router 600 without reset
the default dlink password is password or 1234
if that doesn't work then the password has been changed and you will need to reset the router to factory defaults. hold the reset button for 30 seconds while powered on.
Mar 04, 2012 | D-Link DIR-600 Router
Pressing the reset button doesn't reset router (D-link DIR-600) to default settings. Router is connected to a cable box and to my laptop with ethernet cable. Should I disconnect router from cable box?...
try pressing and holding the reset switch for 15 secs. pressing and holding initially restarts the router. pressing and holding it further resets it back to its default settings.
good luck!
Sep 12, 2011 | D-Link DIR-600 Router
How do I reinstall my D.Link DIR 600 Router.. I failed to install disk to get security code, but can't reinstall..
If the default password on the D-Link has been changed then-
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ON untilthe LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 24, 2011 | D-Link Computers & Internet
Forgot my ssid and password
This is from the d-link manual
If you forgot your password, you must reset your router. Unfortunately this process will change all your settings back to the factory defaults.
To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
Jun 19, 2011 | D-Link DIR-600 Router
Is therea way to reset your cell phone without your code number
The default code for CDMA phones is generally last 4 digits of a cell phone number. Please try entering last 4 digits of your cell phone number as a code and see if it works. i don't think you can reset your phone without entering a code.
Mar 02, 2011 | Samsung SCH-u340 Cellular Phone
Want to reset to Factory Default
with HP the recovery console activation should just be F11 without the CTRL.
If your recovery partition does not work, or is corrupt/missing then your best bet is to either order the recovery discs or take it to a local tech that may have access to OEM discs that can be used with the license key on the machine to reinstall the operating system.
May 01, 2009 | HP Pavilion 523n (P9851AR#ABA) PC Desktop
Computers & Internet Logo
53 people viewed this question
Top The Computers & Internet Experts
Ed Watson
Level 1 Expert
Alex Krenvalk
Alex Krenvalk
mukhtar21 shaikh
mukhtar21 shaikh
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
