Question about Delta Saws
Delta mitrebox model k1346973 belt where can i buy this belt
What size of belt for delta 1 inch belt sander?
you would have to list the specific model number listed on the side of the factory sticker for me to pull it up on their site..or measure from outside of the front wheel to outside of the other wheel on the rear. should give you an accurate belt length.good luck
May 19, 2017 | Delta Tools & Hardware - Others
What is the length of the 1 inch belt on the delta 1 inch belt/5 inch disk
You did not post enough information because there are more than one model anyhow most are 1" x 30" others are 1" x 42"
Dec 16, 2014 | Delta Tools & Hardware - Others
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
I have a Delta 36-979 table saw. In a recent move, it seems I lost the drive belt when I took the motor off for ease of moving. Can I get a replacement at a local auto parts store or do I need to order...
I can't find any specs for this belt, You can buy it online from them the part number is 643928 and the cost is around 7.22, Sorry but this is the only information I can find for you.
Apr 17, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
Delta 12" Variable Speed Drill
try cleaning the pulleys buy a good belt (gates) install belt and make sure you have good belt tension
Feb 06, 2011 | Delta Machinery Delta ShopMaster DP350 12"...
Should I buy an old Delta sanding Center? Is it wise to buy an older Delta sanding center 31-730F Not all parts are still available. They want $250.00 for the sander
If it's the kind with a round disk sander and a wide belt sander, as far as I know belts and disks are still available. There is not much else to wear out. Make sure you test it before purchase.
May 12, 2010 | Delta Machinery Sanders Sanding Center -...
Saws Logo
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
