Question about Air Tools & Compressors
Continuous air coming out of the exhaust cap. nailer won't fire
    Top Expert:
  • 12,902 Answers
Trigger sticking /stuck open ---trigger valve blown out ---gasket or seal damage at ram rod
Posted on Apr 25, 2017
LOOKING FOR SEAL REPALCEMENT AT TOP OF PISTON
Search Results
    [PDF]How to Repair you Nailer - Master Tool Repair
    www.mastertoolrepair.com/.../How%20to%20Repair%20you%20Nailer....
    Air leak through the top head exhaust port. • Nothing ... head valve or the seal located on the top of the cylinder (the part the driver ... Look to see if the piston top of the driver is aligned in the ... Solution: Remove and replace trigger valve (if.Missing: question
    Rebuild a Framing Nailer ' The Family Handyman
    www.familyhandyman.com/tools/air-tools/rebuild-a...nailer/view-all
    Keep your framing nailer in top working condition and save time and money with a ...O-rings that cause air leaks, a trigger valve that won't fire, or a leaking cylinder seal ...then replace the rings one at a time, matching each one to its replacement. Install the new bumpers, piston seals and piston stops and reinstall the cap.
    FASCO - Frequently Asked Questions - fasco tool finder
    www.fasco-tools.com/en/faq-manuals.html
    Search Tools by Application ... My Fasco pneumatic nailer/stapler leaks air from the
Feb 09, 2016 | Air Tools & Compressors
Air blowing out exhaust nonstop gun won't shoot
Replace the O rings... sounds like its one in the firing valve ( rear cap of the gun behind the cylinder )
Nov 19, 2012 | Tradesman Air Tools & Compressors
Porter cable FR350 round head nailer type 2 fires when it is connected to air hose and won't fire afterward
Various nailers will fire on their own when connected to air if the orings have become hard or worn and internal trigger valve parts worn-out (mostly Dewalt and P/C). You could buy an oring kit or purchase trigger valve seperately. Replacing trigger valve and lubing the headvalve with white grease will most likely solve the problem. After repairing the gun, be sure to remove the nails from the mag after each use to prevent possible discharge of nail. Good luck
Oct 21, 2012 | Air Tools & Compressors
Porter cable 350mag framer pin wont go back in and air coming out of the exhaust...It is brand new I used it on a deck today and this happened!!!
FIRING VALVE IS STUCK IN OPEN POSITION, FIRING VALVE IS IN THE CAP OF THE TOOL. REMOVE IT AND OIL THE ORINGS. ALSO COULD BE DEFECTIVE TRIGGER KEEPING FIRING VALVE OPEN
Sep 02, 2012 | Porter Cable COIL350 3 12" Magnesium...
Paslode nail gun ,fan won't shut off
replace circuit mold assembly or spark unit its probably the spark unit
Jul 08, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Leaking air out the exhaust even after rebuild kit
I would suggest checking the cylinder seal and the firing valve for the problem. Also when you take the cap back off check for cut o rings in the cap assembly.
Apr 13, 2011 | Stanley Bostitch F21PL Nailer
As soon as air hose is connected the firing rod extends, stayes extended, and air continues to come out the vent holes at the top of the gun. this problem started after i replaced all the o-rings and...
check for a stuck firing valve or pinched o ring in the cap area, usually this is caused by the trigger valve but look in the cap, Did you lube all the o rings before installing??
Sep 30, 2010 | Dewalt Round Head Framing Nailer D51845
Broke seals under cap, air bleeds continuously.
if you want to save some money and are handy with tools...I have fixed air nailers by buying a sheet of gasket material of similar thickness and making my own gasket out of it with a utility knife.
Jun 20, 2010 | Grip Rite GripRite GRTFN250 16 Gauge 1 2...
Brad nailer not firing properly
need to rebuild. the kits are about $15
Jan 15, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Paslode framing nailer/15 years old approx. air blowing by on top of end cap exhaust does not fire
Needs a new set of O rings in the head. Probable needs the trigger set also, and a good cleaning while you have it apart
Jul 21, 2009 | Tools & Hardware - Others
Air Tools & Compressors Logo
290 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
