Question about Midea Refrigerators
Midea HS-241F stopped working. I hear a buzz back by the compressor and then it clicks and stops. Is this a relay that can be fixed easily
  • 290 Answers
SOURCE: Kenmore (253.51399104)side by side making buzzing/humming noise
It will rattle slightly, this is normal. The ones that are burned out will sound like they have gravel in them, you can defininely tell something is wrong.
The problem with diagnosing Kenmore fridges with this problem is that there are different manufacturers. Yours is built by Frigidaire and probably has a Tecumseh compressor. We find more failed compressors with the Tecumsehs than we do with the models that have Embraco compressors. The models with Embraco's generally have more relay failures.
You should not hear the buzz/hum at startup. You will need to replace the compressor, which will be replaced at no charge to you if it is less than 5 yrs old.
If it is older than 5 yrs, you can have it replaced, but it will be almost as expensive as a new fridge. You can buy an aftermarket start device called a 3-in-1. This has a start capacitor built in to give it a little more boost on start up. I don't recommend using them unless it is a short term fix until the compressor can be replaced or if it is out of warranty and there is nothing to lose anyway.
Posted on Dec 06, 2007
SOURCE: Cannot hear callers/callers cannot hear me/buzzing & crackling sound when connected
try pairing the bluetooth device to another phone, i had the same issue, i used a different phone for testing. it works, so i paired it to my phone and it also works
Posted on Dec 31, 2007
  • 116 Answers
SOURCE: Sears Kenmore 53652300, doesn't cool
This usually indicates that the compressor is working too hard and drawing too much current. The click that you hear is a safety shut-off. Possible causes of this are numerous and usually require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a bad start relay.
There is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor.
Posted on Aug 01, 2008
  • 242 Answers
SOURCE: Buzzing noise near compressor on an Amana refer. PARB1917CSO
I can help , It was the relay , they can blow when they experience a hard start , by replacing it and having the same issue this means the compressor is locked up , they sell a booster for this that can sometimes free the compressor up , its called an rco410 , this part will be your only chance to get your compressor going again. let me know if you have any other questions and tell me how it works out.
Posted on Jan 07, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Frigidaire FRS26R4AW5 buzzing sound not cooling
Something has stopped your compressor. The part could be the start relay, start capacitor, overload or the defrost control board. where are the buzzing sounds coming from ? Sea Breeze
Posted on Dec 20, 2009
Loud buzzing
What is the model number of your unit? If you look at the compressor (back of unit big black bulb looking thing) do you see a picture of an indian on it?
If your compressor looks like this (techumseh compressor) then you almost certainly need a new compressor.
Mar 13, 2013 | Refrigerators
Canon 300 HS lens whining sound.
Pull the battery and see if it stops. If it starts again after you put the battery back in, the motor relay is jammed. If the mosquito stops buzzing you are in business...the sequencing was not completing.
Jan 13, 2013 | Canon PowerShot ELPH 300 HS 12.1 MP...
Side by side Kenmore Elite, Mod. 52794100. both sides have stopped coolding/freezing. There is a click, buss, click. Cleaned coils 6 weeks ago. Someone suggested it could be the starter switch?
Is that buzzing/click you hear from the compressor area?
If it is from their, the relay on the compressor has gone out, OR the compressor is locked up.To determine which of those it is the amprage draw using a amp meter clamped to the wire on the overload thermostat where the relay is, must be measured, if 17 or higher amps the compressor has locked up, if its around 5 or so the relay has gone out and replacing both relay and overload will fix it.If the compressor has locked that is a major repair and may cost up to $1200
Aug 23, 2011 | Kenmore Refrigerators
My fridge stopped cooling properly today. For the last two days, I've been hearing a buzzing, about 15 seconds long, every 10 minutes or so. I didn't locate it until my frozen goods started...
A relay starts the compressor with a higher voltage and then quickly kicks out
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
If you still have trouble Go Here:
Thank you for using fixya
Leo Ponder
Aug 16, 2011 | Maytag MSD2756G Side by Side Refrigerator
My fridge has stopped working. Every so often it will give a click but it isn't kicking in. There is also a creamy sticky liquid that seems to have come from the compressor (I think). Can it be...
Compressors can be replaced but they are expensive. Most compressor are in the $200 range; plus a freon charge is $40-50 plus labor. So repairing it could easily be over $500, so is the refrigerator in good enough shape to invest that type of money in it?
Jun 10, 2011 | Refrigerators
I have an amana abb1924des. A few days ago it stopped cooling. It was making click and buzzing sound. I changed the overload relay and capacitor. The refrigerator started working again for a few hours. The...
Hi there
Only bad news I'm afraid, the click and buzzing sound is a seized compressor, you said changed the relay and capacitor, good idea but often a seized compressor will come free if it cools for a while, unfortunately it will normally seize again fairly quickly. A job for the tech guy.
Best wishes
Apr 17, 2011 | Refrigerators
Fridge stopped working after a power outage. When the power came back on everything seemed to work fine but the compressor is not running. If we unplug it and plug it back in the compressor works for...
Yup, I think you are right...
.there are many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Aug 29, 2010 | Jenn-Air JCD2295HES Side by Side...
I own a Whirlpool model WBM35LW refigerator, a buzzing noise lasts for about 10 seconds followed by a click. I replaced the start relay and overload but the buzzing continues, all seems normal including...
This is usually a sound coming from the ice maker solenoid. It will buzz while it is energized and letting water fill the tray up and then you will usually hear a clicking sound when it is cutoff and the water is stopped. Sometimes if the water line on the back of the unit is not secured properly you will hear various sounds as the water is suddenly stopped and the line moves around, like a garden hose does.
Sep 29, 2009 | Refrigerators
Problem has returned to Maytag fridge
I note this is a very old post. The compressor is not starting and what you were hearing was the PTC relay energizing followed by the KilXon thermal overload kicking off the compressor start sequence. What happens is that the PTC relays sometimes get a heated contact. Due to the weakened state of the contact it can cause a buzz. Even with a goo PTC relay you would hear the compressor buzz if it was not starting. In that case the run capacitor may have failed or the compresor rotor is internally locked at which point the start cycle will repeat every 3 to 4 minutes as the thermal overload cycles and the compressor will not start.
Thanks for choosing FixYa
Jun 18, 2008 | Refrigerators
Refrigerators Logo
47 people viewed this question
Top Midea Refrigerators Experts
mike cooper
deton8 von Splosion
Tom Chichester
Are you a Midea Refrigerator Expert? Answer questions, earn points and help others
