Question about Magnavox Televison & Video
Hi I have the Magnavox ZV457MG9A. Can I copy a VCR tape to a DVD on this machine
SOURCE: I can't play any VCR tapes or DVD's in my Magnavox. Shows E1
Hi All, I realize this post may be a bit late for some but I just bought this unit myself on 12-22-08. After reading the pdf manual I downloaded from an earlier post the description of "E1" and "E2" is on page 20 and more details are on pages 35 & 36.
"E1" is the display indicator the unit is looking for a External input signal or Line Mode. "E1" External input on the rear, "E2" External input on the front. No signal present so the unit shuts off.
I suggest changing/setting your record channel or source before starting any record mode steps. Hope this helps.
Sybrsound
Posted on Dec 23, 2008
  • 3 Answers
SOURCE: VHS won't play, sounds like tape will load then power shuts off.
This is similar or identical to another post, but here is an answer...
Hi, I have a solution you can try.
I had exaclty the same problem. When I tried to play a tape it would load (However, I recall I had to push hard to get the tape to be accepted, which is part of the problem) but would shut off after about 12 seconds, then when I powered back up the tape would eject. Finally I took the unit completely apart and attempted to use it with the covers off. Lo and behold, I found I could play a DVD on the unit without the unit powering off, but only if the room lights were on! If I tried to play a tape it would shut down the unit. So that led me to diagnosing the infrared loading and reel sensor circuits.
Background on that is there is an infrared LED that shines up through a plastic light pipe lens. The light from that LED (you can't see it) should shine on two photodiodes that are on either side of the tap mechanism, plus down through a gear with holes in it on to the reel sensor. When there is no tape inserted the two photodiodes will be illuminated and have about 0.2 volts across them. When a tape is installed the light will be blocked and the voltage goes up to above 2.5 volts across the diodes. You have to check this with the room lights dim as the diodes will respond to that light. When you block the light on either side of the plastic light pipe with your finger (with the unit disassembled) you should see the load motor engage, and it will back off when you take your finder away. For some reason in my unit the light from the LED was insufficient to turn on one of the diodes, and also to pulse the reel sensor when the gear turned. That could be due to component aging, or even if the light pipe started to cloud due to age, I don't know. However I was able to get the thing working...
In short I got the unit working by adding 3 resistors.
To do this you'll have to remove all the covers and remove the main PCB from the bottom chassis, unplug the power supply from the PCB, and the two ribbons going to the DVD unit. But you won't have to take off the VCR assembly, which is a pain. You just need some basic soldering skills, and remember where all those screws go...
First, I adjusted the voltage across the right-hand side load sensor diode to get the diode to switch on and off. I recall that I added 1meg across the diode. So the voltage then went from about 0.5v up to 2.8v from light to dark condition.
Second, I increased the current to the IR LED. I added a 330ohm resistor across the feeder to the LED. I recall that was R511 and was originally 220ohms. That was not quite sufficient to get the reel sensor working reliably. I didn't want to stress the LED by putting too much more current through it so looked for another idea.
Third I added 56k across the reel sensor diode to bring the voltage across it down so it would switch on and off as the reel sensor gear turned.
I now have a tape playing continuously in the unit and it seems ok for the time being. Hope that might work for you too.
Craig Townsend
Posted on May 26, 2009
SOURCE: VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Posted on Jun 05, 2009
SOURCE: I just bought a Magnavox ZV450MW8A DVD/VCR
Yes, you can, I have this unit and have actually copied a dvd to a vhs and then copied back to a dvd as I wanted a dvd copy to give a friend. The directions in the book are really quite simple. They tell you how to set the vhs to the spot where you want to start copying, etc.
I have not yet tried copying my family vhs tapes, but don't see a problem, just a big project. Good luck.
Posted on Jun 15, 2009
  • 476 Answers
SOURCE: i lost the manual to the magnavox dvd/vcr dual
The easiest way to hook up the combo is to use the cable in and out to tv connectors located in the rear. for this connection you will hgave to set the TV to Channel 3 or 4. You can usually download an owners manual from magnavox.com, you will need a model number.
Posted on Mar 19, 2010
I just bought a magnavox DV225MG9 A player . The salesman said it could copy vhs tapes to dvd. how do I do this with this machine?
If this is the correct model number, magnavox DV225MG9, above, this unit is only a DVD player not a DVD recorder. It won't dub DVDs to VHS either.
I wish that I could be more help.
Jun 30, 2010 | GoVideo Go Video DVD/VCR Combo
Need to know if I can record from dvd to vcr on a magnavox ZV420MWB vcr/dvd combo
Magnavox ZV420MWB VCR/DVD Combo
The answer is YES YOU CAN! Take advantage of one-touch recording from videotapes to DVD+/-R and RW discs or from DVDs to VHS tapes. A variety of different inputs also let you record from compatible camcorders, external TV tuners or cable boxes.
CONSUMER ALERT: This model does not have a built-in tuner for recording TV programs and will not record copy-protected tapes or discs. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission's digital television website at: www.dtv.gov.
Feb 15, 2010 | Philips Magnavox DVD/VCR Dual Player
I record a DVD from VCR tape and try to play on another device
In my research, I learned about finalizing the DVD, which was a new concept to me. I looked that process up in the manual and it did the trick.
Nov 16, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I just bought a Magnavox ZV450MW8A DVD/VCR Recorder. It has recording capabilities on both the DVD and VCR components but can you tell me if I can use it to record FROM the VCR directly onto the DVD? This...
Jun 13, 2009 | Philips Magnavox DVD/VCR Dual Player
When I try dubbing from VCR to DVD the machine will only record about half of the VHS to the DVD. I get the following message...Recording Error - this program is not allowed to be recorded. The cause...
The DVD AGG (automatic gain control) is somehow being fooled into thinking the non-commercial tape has macrovision (copy protection). Is this a relatively inexpensive machine?
Mar 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Copying VHS tape to DVD
Hi.
I'm sorry, but according to zenith xbv323 VCR/DVD combo user's manual page 24 you can ONLY copy DVD to VCR and not the other way
Feb 26, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox zv420mw8
Are you trying to copy a DVD to DVD. Because I think if you are then it won't work. It might copy it to VHS VIDEO. But that wouldn't be worth it as you would lose quality. Try finding DVD CLONE for your PC.( It might be a free download) Look for it on the net. It will copy dvd to dvd and it's less complicated. I hope this helps.
Jul 28, 2008 | Philips Magnavox DVD/VCR Dual Player
MAGNAVOX DVD/VCR RECORDER
I have been using my machine with no problems, until recently. The machine will not stay on more than a few minutes when I try to use it, either watch a tape or tape a show. It starts, then just shuts down. When the machine is turned back on it ejects the tape????
Can you help, please.
Thanks
Sharon
Jul 07, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Televison & Video Logo
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
