Question about Ricoh Office Equipment & Supplies
SOURCE: Ricoh FT2260 Copier
There are basically two types of error codes:
These type of errors are often caused by the following conditions:
The VirtualReScan error codes displayed below are accompanied by descriptions and troubleshooting suggestions.
Let me know if u got help?
Posted on Nov 30, 2007
SOURCE: Error message of Sc 725 Ricoh copier
Description:
Finisher stack feed-out motor error
Symptom:
The stack feed-out belt HP sensor does not activate within a certain time after
the stack feed-out motor turned on.
Possible Cause:
Stack feed-out HP sensor defective
Stack feed-out motor overload
Stack feed-out motor defective
Posted on Aug 25, 2009
SOURCE: Ricoh Aficio MP 161 is printing slanted duplex copies
Hello sir; There have two way to resolve this problem, 1st, loose the cover hinge push cover all the way to front then tighten it. then go to 2nd step open the top cover, at the left side of the white padding there have to lockes (up & down) open it out look inside there have a reverse roller, clean it with alcohal, hat should take care the problem.
Posted on Jan 27, 2010
SOURCE: ricoh aficio 1045 jams on duplexing
there could be multiple reasons for it to be jaming on duplex, just depends where in duplex it jams. most common for the age of the copier rubber rollers in duplex getting dirty or hard. like swan34 said try some type of rubber cleaner.
Posted on Mar 21, 2010
SOURCE: Ricoh Aficio 2022 jams duplexing only
You can't get that unit as one whole part, you would have to order each part separately. Also, if the paper is warped or curling, replacing that interchange unit won't change anything.
Try fanning the paper and flipping it over, or use a new **** of paper and see if that makes a difference.
Posted on Jun 05, 2010
Apr 07, 2016 | Ricoh Aficio Office Equipment & Supplies
Dec 16, 2014 | Ricoh Aficio 1515MF All-In-One Laser...
Aug 26, 2014 | Ricoh Aficio SP C820DN Laser Printer
Mar 25, 2014 | Ricoh Office Equipment & Supplies
Mar 10, 2014 | Ricoh Aficio MP 2000 Black and White...
Mar 25, 2013 | Ricoh Toner for Aficio MPC2800, MPC3300,...
The exit sensor and
the duplex sensor
detect a paper jam 3
times in succession
Paper jams can occur for the following
reasons.
???? Dampness
???? Paper curl
???? Incorrect paper setting in the paper
tray
???? Stripper pawls coming apart
Apr 22, 2011 | Ricoh Aficio MP 1600L Black and White...
Apr 08, 2010 | Ricoh Aficio MP 161SPF Color Copier
Feb 07, 2010 | Ricoh Aficio 1035 Copier
Dec 11, 2008 | Ricoh Aficio AP3800C Laser Printer
Apr 19, 2018 | Ricoh Office Equipment & Supplies
37 people viewed this question
