I have dany hdtv800 device i wanna reset it because display on screen is not showing only audio coming give me some solution how can i fix it.
How to reset dany hd 550 device on dell lcd
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Aug 31, 2014 | Televison & Video
Why won't my volume wont work on pavilion dv7
Step 1: Using the Troubleshooting tool in Windows 8 The Troubleshooting tool in Windows 8 can automatically fix common problems with your computer, such as audio recording. Although it may not fix every problem, it is useful to run the Troubleshooting tool first before you manually correct problems.
To open the Troubleshooting tool:
  1. At the Start screen, type find and fix audio to open the Search charm. Figure 1: Find and fix audio search
    c04030165.jpgShow all ' Hide all [img id="doc_plus_doc_sc_6.1" src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/hpweb_1-2_plus.gif" alt="show" >
    Update the audio driver from the HP Web site
    [/a] hpweb_1-2_plus.gif
    Update the audio driver using Device Manager in Windows 8
    Step 4: Checking Device Manager to troubleshoot audio problems (Windows 8)
    If you cannot hear sound, check Device Manager to determine the state of the sound hardware.
    1. At the Start screen, type device manager to open the Search charm. Select Device Manager in the Search results. Figure 13: Device Manager
      [img border="0" src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/95/c04030167.jpg" alt="Device Manager on the Search screen" title="Device Manager on the Search screen">
    2. Double-click Sound, video and game controllers .
    3. Do the following, depending on what displays:
Jul 14, 2014 | HP Pavilion dv9000z Notebook
Sound is not working for Dany u1050 usb tv device in using win8
Download and install a Windows 8 compatible driver from the URL below.
www.dodownload.net/drivers/dany-u-1000-1050-2000-usb-tv-drivers.html
Jan 25, 2014 | Computers & Internet
I forgot the password of dany hdtv-600 tv device please tell what to do?
thanks
yes Default password 0000 works i used it and resolved the issue
Feb 20, 2012 | Televison & Video
I have an emachines D620 and the display is coming up with the wrong resolution when I reboot... actually it starts out fine then about twenty seconds after the reboot finishes the display resolution...
Hi henry,
you may wanna try to uninstall and reinstall the display driver on your device manager ( start>(you can see start search type there device then device manager will show on top of the start menu>look on the display driver>right click on the driver then choose uninstall and restart your system.set up your screen resolution again
hope it helps :D
Apr 05, 2011 | Dell Computers & Internet
My sandisk sansa e260 mp3 player wont trun on it goes to the start up screen and thin keeps repeting that screen how can i fix this does any1 know?
Hi, the Sansa E260 is a portable MP3 player released by SanDisk in 2004. Several problems may cause the E260 to not function as intended from time to time. Common problems that occur are the device freezing, album art not appearing on the screen when a song is playing, pictures not filling the screen size and missing information on the separate tracks. You can troubleshoot the device and fix many of these common problems without the need of a service technician.
Reset
1. The Sansa E260 may freeze or function in other unexpected ways from time to time. This generally occurs when the unit's software has developed an error. Reset the device to clear the error and return the device to normal working operation. A unit reset is similar to rebooting your computer. You won't lose any data stored on your device.
To reset the E260, press and hold the "Power/Menu" button for about 15 seconds. The device will be forced to power down, during which the error will be cleared. You can restart the E260 as normal once the reset is complete.
Album Art Does Not Display
2. The E260 supports viewing album art on the display screen during the playing of a song. You may find that your album art is not showing up on the display when music is playing on the device. To fix this, make sure the associated album art file is in the same folder as the song being played. You will need to connect the E260 into your computer to move the album art files into the music folder.
Photos Aren't Full-Screen
3. Photos displayed on the E260 will not show up as full-screen shots if they are not cropped to the correct dimensions. The E260 software does not support stretching pictures to fit the full screen. To ensure your photographs will display on the full screen, crop the images to 128x64 in photo-editing software prior to transferring the image on the E260.
Unknown Artist or Album
4. The E260 displays information about each song using the ID3 tags associated with each track. ID3 tags hold information such as the artist name, album name, track number, year it was released and other information. If the E260 shows an artist or album as unknown, the information in the ID3 tag was not filled in. You can insert information into the ID3 tags from your computer.
To change the ID3 information, right-click on the music file and choose "Properties." Click on the "Summary" tab and choose "Advanced." The ID3 fields will display in the window. Insert any of the missing information and click "OK." When you upload the song onto your E260, the newly inserted information will show up in the display.
Hope it helped...
Feb 23, 2011 | SanDisk Sansa e260 MP3 Player
I have mp3 of dany .when i connect to computer .computer show detection but in device manager show mp3 usb driver not found
H, try and re-install the drivers again and try it. If it does not work, then the drivers is corrupt, you will need to download new drivers.
Take care.
May 18, 2010 | Audio Players & Recorders
Nokia inside screen broke
Most probably your display will be damaged.There is no other solution other than replacing it.A genuine display will cost around 1/5 of your phone's price (recommended)or you can buy a fake one with half the price of original.
Sep 15, 2009 | Nokia 5300 Grey Cellular Phone
NO GUI displayed
I had a similar problem with my Denon 3808 after it had the protection circuit tripped. First all I would get is a blue screen with sound, then after powering the unit off I got the display back, but all of the on screen GUI menus were gone. I could tell that the menu button worked because display located physically on the recever worked. I reset/rebooted the system (follow the directions in manual) and everything came back. Be aware by resetting the system any customization you have done will be lost. Hope that helps
May 30, 2009 | Denon AVR 3808Ci Receiver
HTC screen will not show
Have you tried just pulling the battery out for a few seconds, and replacing it. Letting it reboot and start again. You do wanna do this at least three-four times a week.
If the powercycle doesn't do thte trick, you'll wanna do the hard/master reset. As per www.htcwiki.com
Hard/Master Reset for a HTC Pocket PC: Warning: Performing a Hard/Master Reset will remove all of your data (settings, files, 3rd party applciations, etc.) from your device and will only reload the Windows Mobile Software and components. The method for Hard Resetting/performing a Master Reset on HTC devices can vary by model. Below are the instructions for the most common method. If these steps do not work for you, consult your user manual or contact your wireless carrier for additional assistance.
  • With the device powered on, press and hold the Left and Right Soft Keys.
  • Whilst holding the Left and Right Soft Keys, perfrom a Soft Reset on the device by inserting the stylus into the reset hole.
Feb 03, 2009 | HTC PPC-6800 Smartphone
Computers & Internet Logo
David Payne
David Payne
