Printing error message appears,then noticed pending comand.Given cancell comand ,deleating message appears, but not getting deleted after long time also.what to do?
SOURCE: printing status frozen and won't delete or print
Have you tried unpluging your printer from the computer as well as unpluging the printer from the electrical? If that doesn't work you should start from scratch... that is remove the printer from the computer memory, delete it, turn off the computer, turn on the computer and go through the installation process as if you just purchased the printer. Barring any mechanical problems as in jams or the such, the printer should return to operational status.
Posted on Oct 07, 2008
SOURCE: PC Print Pending Message Won't Go Away
Have you tried to delete the print job from the computer? After that is done reset the printer by turning it off (30 sec) then on again. If that doesn't work take the paper out and start cleaning your printer with canned air, Q-tips and a cap full of water.
Posted on Jan 05, 2009
  • 15 Answers
SOURCE: Having problems deleting pending documents
Assuming you have a modern windows pc, You will need to manually stop the print service. Do this by running the command "net stop spooler" from the "run" line. Then go to "C:\WINDOWS\System32\spool\PRINTERS" and delete all the files from there. After these files are gone, start the spooler service again by running "net start spooler". You should be all set after that.
Posted on Jun 09, 2009
  • 8404 Answers
SOURCE: How do I cancel print job. I get message access
OPen the printer program, select the jobs and select cancel.
go to the control panel to find the printer program
Posted on Dec 20, 2009
funkyagain
  • 24 Answers
SOURCE: says pc print pending how to cancel the pending
There should be a cancel job **** or a "cancel" button on the printer. Just click that a couple times to remove it.
You can also go into control panel - Printers and Faxes - select the specific printer - manually delete your last print job.
Hope this helps!
Posted on Apr 30, 2010
How do i get my printer from offline mode back to online mode
  • Make sure that the printer is powered on.
  • Pull up 'My Computer' then click on 'Control Panel'. From the Control Panel, click on 'Printers and Faxes'. You will then see a list of Printers connected to the PC.
  • Delete pending print jobs to make sure that the correct document will be printed later and for you not to waste paper. Double click on the printer that you want to use, and a window will appear showing you a list of pending print jobs. Simply click on 'Cancel All Documents' from the 'Printer Menu'.
  • After you have deleted all pending print jobs, right click again on the printer icon and choose 'Use Printer Online'.
  • Try printing a test file, if it doesn't work the first time, reboot the PC.
***If you need any technical help on printer then you can reach at here
Jan 02, 2013 | Office Equipment & Supplies
Document will not print; status reads deleating-printing; printer appears to be frozen; does not print any other items...
Kill the job on computer that sent the print job. If the job fails to clear you can stop and start the print spooler
Right click My Computer > Manage > Services.
Right click Print Spooler > Stop then Start. That should clear the job.
Same principle pertains to a network printer, but needs to be done print server.
Sep 24, 2012 | Lexmark International Lexmark 8300 Series
Says pc print pending how to cancel the pending
Hope this helps!
Apr 30, 2010 | Xerox Phaser 3200MFP/N Laser Printer
Jun 09, 2009 | Office Equipment & Supplies
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
49.3046 Error To Continue Turn then On
Disconnect cables (except power) and try turn it on. If message dissapears be sure that you delete all pending files to print in your computer (specially large pdf).
Apr 03, 2009 | HP DeskJet 5550 InkJet Printer
2 document pending for print.i coud not print now.
hmm simply just click printer icon and cancel all the docs for printing then again give the print command and your papers will print
Mar 28, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printer will not print
See that there are no pending files to print in printers memory.
To see that selct Start ---->Settings ----> printers and faxes
Make your printer the default printer and double click on the icon.
On that screen all pending jobs will appear. Turn OFF the printer and cancel all pending jobs.
When all jobs are deleted close the window and turn on printer and resume printing.
Dec 17, 2008 | Lexmark Office Equipment & Supplies
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
Will not print
Go to print. Prinrt comand comes up just fine. Press ok and nothing. Document pending is all I get. Printer seems to be ready but goes into power save waiting for next comand,
Jan 12, 2008 | Lexmark X83 All-In-One InkJet Printer
k24674
jasbo
jasbo
