Question about Neff Washing Machines
Bought Neff V6540X1GB washer/drier from Wickes as part of kitchen. Need extension legs to get machine to correct height under worktop. Wickes and Neff UK say it should be 5540X1GB but they don't fit.
  • 1462 Answers
SOURCE: neff washer/drier
soap drawer is just a slide fit - give it a good yank. for the dryer, take the top off and there should be a mainifold across the top with stats mounted on it. one or two may be re-settable stats ie have a little button in the middle which press to reset. if this works, cause of stat popping out is usually a lint blockage in the dryer manifold
Posted on Apr 28, 2007
SOURCE: I need a user manual
I need access to the spark plug module for replacement. The plastic stove top seems sealed to the metal housing. How do I gain access? Creda GH 102 series cooktop. Spark Module Replacement.
Posted on Apr 25, 2008
  • 170 Answers
SOURCE: cannot adjust the rear legs
Is it that you cannot reach them? If so, pull the machine out enough to where you can get to those legs from the side and adjust them that way, then push it back in. There's also a 'kick plate' that can be removed allowing you more wiggle room to get back there with a wrench. Good luck!
Posted on Jul 18, 2008
SOURCE: need instructions to use Worktop jig
Screwfix were happy to send me a copy of the instructions for their jig which adapted perfectly.
Posted on Oct 05, 2008
  • 8197 Answers
SOURCE: fitting neff double oven cooker purchased from display at mfi
Go to this site here.
You need to register the oven under My Apliance to get the manual
Good Luck
Please rate FixYa!
Posted on Dec 19, 2008
AEG dishwasher integrated Model newly installed but when I lower the door to load it the dishwasher moves out from under counter and then wont close properly how do I solve this problem?
The built-in dishwashers are almost fixed by screws in top or by side. Carefully read the installation manual where it is explained in detail how to fix the dishwasher under the kitchen worktop. You also need to adjust the height by using the swivel legs that will additionally fix the dishwasher.
Jun 24, 2017 | AEG Dishwashers
Leveling kenmore elite front loader
  • Place the level on the top of the washing machineicon1.png to see if it is level. Make sure you test it side to side and front to back.
    Pull the washing machine away from any walls if you have to make an adjustment to the legs.
  • Lift the washericon1.png and place the wood block underneath the washer. Place the block near the leg that needs to be adjusted, but don't let it obstruct the leg.
  • Loosen the nut that secures the legicon1.png with the wrench.
  • Raise the height of the leg by twisting it to the left, or lower the height by twisting it to the right.
  • Remove the block of wood from under the washer and recheck the machine with the level.
  • Raise or lower the leg if additional adjustments are needed.
  • Tighten the nut on the leg with the wrench when the machine is level.
  • Repeat the process for each leg that needs to be adjusted.
  • Move the washer back into position and check with the level again to make sure the washer remains stable to finish leveling the machine.
    Richard Roth
  • Nov 13, 2012 | Kenmore Elite 45986 Front Load Washer
    Built in washer drier wont start
    What brand and model? Turn off the washer/dryer breaker, wait 15 seconds, then turn on (reset) the breaker.
    Jan 19, 2012 | Neff Washing Machines
    I have a neff S5049X, pump keeps runing on even with door open, trying to remove it from underneath worktop to tilt back. How do I lower the legs to allow clearance between floor and worktop. What is the...
    Sounds like the anti-flood device has kicked in this would suggest that there is either a leak under the machine or if you may have used too much rinse aid and it has frothed up and leaked under the door.
    The screw in the middle is to lower the middle rear leg turn it towards the down or minus sign normally anti-clockwise.
    Hope this helped.
    May 09, 2010 | Neff 24 in. S5409X0 Built-in Dishwasher
    My Neff drier isnt drying my washing it is hot but the
    Is the fan working? this blows air across the element which in turn cools the steam into water then pumps it out via pump,Hope this is of some help
    Apr 13, 2010 | Neff V4380X0 Front Load Washer / Dryer
    Having a new floor in the kitchen and my faithfull
    Buy a machine that will is the first thought , otherwise get the kitchen fitter to raise the worktops above the washer
    You could try taking off the top lid and removing the feet underneath which will give you some room
    Make sure that you place a sheet of plastic over the top of the machine from side to side and tape it in place if you do remove the top
    That is in case you spill anything on the worktop which then drips inside the machine
    Sep 16, 2009 | Zanussi FLE1416W Front Load Washer
    How to adjust the legs
    Remove any plinth in front of the base of the machine. In the middle of the base you should see a black screw head with arrows either side. This screw adjusts the height of the machine at the back - clockwise = up and visa versa. The two feet at the front screw in or out of the base moulding to raise or lower the machine. Check that these have not been secured by screws through the front moulding. If so, slacken or remove. NOTE: make sure if the machine is already installed that you have loosened the screws which secure the machine at the top to the underside of your worktop.
    Mar 01, 2009 | Bosch 24 in. SGV53E03 Built-In Dishwasher
    Granite installation didn't get flush with slide-in range
    suspect your contractor didn't allow for the tiled floor. the range legs are usually adjustable up and down. have you checked this?
    Sep 04, 2008 | Cooktops
    Neff washer/drier
    Apr 28, 2007 | Neff V4380X0 Front Load Washer / Dryer
    Washing Machines Logo
    29 people viewed this question
    Top Neff Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Billy Detlefsen
    Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
