Question about Refrigerators
Fan in freezer does not come on - Refrigerators
  • redseal tech May 11, 2010
    is the fridge running otherwise or is it not running at all.
  • Refrigerators Master
  • 4,654 Answers
It is very important that you not run the refrigerator until we can see if the fan motor is defective or if something in the defrost circuit. I do need the model number to help you better. Sea Breeze
Posted on Jul 25, 2009
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
My refrigerator is not getting cold
Is the freezer freezing? Do you hear a fan motor running inside the freezer? If the freezer fan is working and the freezer is still getting cold, do you see allot of frost on the back wall of the freezer?
Freezer not cooling at all - t-stat or compressor would be where to check next
No fan running in freezer and freezer is cold - bad evaporator fan motor.
If fan is running and you have heavy frost on the back wall of freezer - unit is not defrosting. could be defrost timer or defrost t-stat
Mar 12, 2013 | Amana Refrigerators
Freezer works but refirgerator is not cold
when you open the freezer door do you hear the fan blowing?if not you have a bad evap fan motor,if the fan is blowing put your hand on the back inside wall of the freezer,if you feel like snow on the back inside wall you have a defrost problem and have to find what part is bad with a meter,bad defrost thermostat,heater or board or timer,send model number next time,ice builds up on the coil and air can't blow into fridge from freezer,could have a bad damper,also if the freezer is on top you could have a blocked drain in the freezer,the air vents freeze up and the fan can't blow air from freezer into fridge because the air ducts are frooze up,all it does is the freezer gets cold,the evaporator fan blows cold air from freezer into fridge section,so either the fan motor is bad,the fan blade is damaged or something is blocking the air like a bad damper or air ducts are frozen up,send the model number and let me know what you find,do you hear the fan,any ice on back freezer wall or anything else you see and i'll try to help you out.
Jun 02, 2012 | Refrigerators
REFRIGERATOR FREEZER IS MAKING A NOISE
Noise inside the Freezer
If your freezer is making a squealing or a little chirping sound, your condenser or evaporator fan is the cause. Open up the freezer door, and the noise usually gets louder. The location of the fan depends on your model freezer. Usually, the fan is located on the rear wall of the freezer. The fan can lose lubrication or become rusty over time. You cannot repair the fan. You must purchase a new one.
Have a nice day : )
Sep 05, 2011 | Refrigerators
Trouble with model LFC25760ST inside display refrig registering Err and freezer FF and things are not cold
That is a freezer fan motor error, the freezer fan is no longer running. Check the freezer fan for a loose connection, if everything checks out ok there you probably need to replace freezer fan.
Oct 07, 2010 | LG Refrigerators
My LG ice maker fan is making a really loud noise right after the water stops going in
Hello, Self-defrosting refrigerators use a circulating fan to move air through the freezer and refrigerator compartment. This fan runs when ever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall,near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, half way up or near the top.
Overtime the fan may become noisy, usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise,just open the freezer door and push in any fan/light switches, if the noise is louder when the door is open, the evaporator fan motor is the cause. You can lubricate or repair this motor. You must replace it.
There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor(if self-defrosting), or the defrost timer (if self-defrosting).
Thanks
Jun 17, 2010 | LG LSC26905TT Side by Side Refrigerator
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Dec 22, 2008 | Frigidaire FRT18FS6C Top Freezer...
Freezer fan
actually, freezer fan has to come on otherwise how is the fridge supposed to cool.(fridge draws off from the freezer compartment). check if there is power to the fan. if freezer is nice and cold and fan does not run(assuming there is no power to the fan at that time, then you would need to check your freezer thermistors after that, your board. all this is assuming you dont have a blockage or shortage of gas in the sustem.
Sep 20, 2007 | Kenmore 72293 - Stainless Steel Top...
FAN MOTOR NOT OPERATIG
1. remove everything from freezer. 2. unplug freezer. 3. remove screws from back of freezer wall. 4.remove evaporator fan. (you will see it at the top of the freezer wall) 5.install new one.
Mar 12, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
