My meter does not work despite entering !000 and attempting to reccharge on several occasions
I have a Health O Meter HDM560. I need to reset the #1 and #2 users and start over, can you help me there is nothing in the manual about it I can find.
Current Instruction Manual for the HDM560 can be found here:
http://www.healthometer.com/Manuals/MANUALS/HDM560-05_43_41816518.PDF
For resetting it would be similar to the initial setting process. FOLLOW these steps:
Lift display cover. Push "SET" button at bottom of pad. User "1" and "2" will appear.
User "1" will start blinking. Press the "USER" button to choose user "1" or "2". Once selected, press "SET" button to lock in information.
Both "HEIGHT" and "AGE" will appear on the screen. The "HEIGHT" will start blinking. Press the "UP" or "DOWN" arrows to find the correct height.
After entering height, press the "AGE" button. Use the "UP" and "DOWN" arrows to enter correct age and press "SET".
Both "MALE" and "FEMALE" images will be displayed. Press the "GENDER" button until the correct MALE/FEMALE image blinks and then press "SET". This will lock in the information.
Your correct information including User, Height, Age, and Gender will be displayed. Now you are ready to calculate weight.
Tap your person "USER" number (1 or 2) in center of scale with your toe. Your personal profile will appear. Wait until "000" appears. Stand on scale so bare feet are positioned over silver pad surface. "000" will blink your weight for approximately 3 seconds. "BF" will flash and body fat percentage will appear. The scale will turn off automatically in a few seconds.
May 21, 2011 | Health-O-Meter Health & Beauty
Convert 8000 square Feet in Metric
One foot is exactly 0.3048 meters, so 8000 square feet is 8000*.3048^2 square meters.
Pressing 8 0 0 0 * . 3 0 4 8 ^ 2 ENTER will give you about 743.
May 11, 2011 | Texas Instruments TI-83 Plus Calculator
Hello, despite my HP2840 Q3960A black cartridge is new, he tells me to replace it counts as printed pages at 5% coverage but at 100%. After several attempts to remove the chip and its re-enter again gives...
There may be a defect in the toner cartridge causing the odd behavior. You can try resetting the printer settings to factory default or upgrading the firmware. You can reset the settings through the printer's menu. The link below should allow you to download the latest firmware and it should provide instructions for performing the update.
HP Color LaserJet 2840 All in One Printer
Jul 16, 2010 | HP LaserJet 2840 Printer
Tomtom one 130 stopped working and will not turn on despite repeated attempts to charge and reset unit
Mine is only working by pressing ON/OFF button more than 15 seg. Sometimes I need to repeat this procedure several times to get it working. Antonio Cesar
Dec 19, 2009 | Tomtom ONE 130S Car GPS Receiver
98 Accord V6 EX CD/Radio no sound despite correct code accepted
check the wirings of your speakers and then check the settings on your radio.
Jun 09, 2009 | 1993 Honda Accord
De Dietrich DMP502E1 oven not switching off
There is not a lot of information regarding this oven, but you may want to contact these guys. If you send them the control boards and a wiring diagram they can fix almost anything and give a great warranty: www.fixyourboard.com
Apr 15, 2009 | De Dietrich UMP404 Powerclean Stainless...
QS6000 Plus with USB programing question
The document below programs the QS6500 Plus Scanner
R44-2805A Rev C
Available from
http://www.scanning.datalogic.com/sitefiles/manuals.aspx
Jan 27, 2009 | PSC QS6000 Plus Handheld
I nedd unlock t-mobil motorola sidekick slide
If you do not have a Sidekick data plan
The only way to bypass a three-digit privacy code without a data plan is to attempt to enter all 1000 possible combinations between 000 and 999. This may take roughly an hour, at several guesses per minute.
After re-discovering the Privacy Lock number, safely record it for future reference.
Dec 09, 2008 | T-Mobile Sidekick
k24674
jasbo
jasbo
