Question about Konica Office Equipment & Supplies
Sir i have konica 1216 but paper j11 error - Konica Office Equipment & Supplies
sir fixalot
  • 146 Answers
SOURCE: Konica minolta 1216
1. A fan irregularity signal, excessive current draw due to binding. Examine M4 for obstructions which may bind the fan. Check the M4 fan lock signal (main CB, CN26-4) in the 47 mode, input code 42. The voltage should be between 0.1 to 0.2V DC. If 5V DC is present, either the fan is binding or the fan is defective. Replace M4 (p/n 25HA80512).
Note: If the fan lock signal is normal, install the version 17.0 EPROM (p/n 101517-17.0) to prevent false F54 errors as outlined in 1015/1212 Technical Bulletin #15.
2. IC7 on the main CB has shorted due to a failed total counter. IC7 shares the 24V DC control signal line with the exposure lamp, separation solenoid (SD1), registration solenoid (SD2), total counter, key counter, and cooling fan (M4). All loads except the total counter operate in diagnostics.
Replace the total counter (p/n 466088201) and the main CB (p/n 25HE-7312).
3. A poor connection between the cooling fan (M4) and the main CB. Reseat CN73 at M4 (cooling fan) and CN26 on the main CB.
Posted on Jan 03, 2008
SOURCE: Konica 1216 Phocopier, big problem!!!
MY COPIER FLASHES P.26 CODE WHAT I DO?
OR ISSUED TO RETIFY IT
Posted on Aug 27, 2008
firecontrol7
  • 6674 Answers
SOURCE: in what meaning of konica 1216 copier mechine
fuser code have to have it reset via service mode. its a legacy konica machine.
Posted on Jul 25, 2009
SOURCE: Konica 1216 copier makes black dark copies
dear sir i have information P 27 on my konica copier. how do i solve the problem..?
Posted on Sep 07, 2009
bolinlamar
  • 157 Answers
SOURCE: kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
Posted on Sep 18, 2009
On Konica 1212 what does J11 mean and F54?
J11 means Jammed on 1st paper feed tray & F54 means your key swith is Open(disconnected).
Dec 05, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
I am having L code errors on our Konica Minolta Biz Hub 363
Sir/Mam,
#10 Transfer roller needs replacing sponge looking roller right side of the of the machine when you open to remove paper jams.
# 9 Developing unit needs replacement that the part that holds the drum and developer/toner. IF YOU YANK THIS UNIT OUT WITHOUT REMOVING THE LITTLE COVER ONE BOLT and DICONNECT THE CONNECTOR. BIG TROUBLE, going to cost a lot to repair.
#8 PAPER DUST REMOVER the device that collect paper dust yes paper does produce DUST. Just before the sponge roller
#6 IS Warning that the developer has not been replace inside the drum cartridge. SEE #9
#4 Drum need to be replaced.
Really have to watch for all of that sir/mam.
Apr 11, 2014 | Konica Minolta "Minolta Bizhub 363 Copier,...
THE MACHINE INDICATE J11 WHAT IS THE PROBLEM
j11 indicates that the paper is not being fed from the paper cassette 2.
This can be caused by incorrectly loaded/thick paper. Cassette not correctly adjusted.
Paper feed rollers need to be cleaned or replaced. Blockage or parts failure.
Mar 24, 2014 | Kyocera Copystar CS-1635 Copier
Konica 1216
replace the developer and the drum and have the tech clean all around the drum area and the sensors
Mar 12, 2014 | Konica Minolta bizhub Office Equipment &...
KONICA 1015 COPIER - CODE J11, BUT THERE IS NO PAPER JAMMING THAT I CAN DETERMINE WHEN OPENED UP
check the sensors, clean it or check the wire connection of the sensors maybe it was eaten by rat.
Mar 25, 2010 | Konica Minolta Office Equipment & Supplies
Kyocera mita j11 error code
Sep 18, 2009 | Kyocera Mita Office Equipment & Supplies
Apr 15, 2008 | Konica Minolta DiALTA CF910 Copier
Apr 15, 2008 | Ricoh Aficio 1013F Copier
24 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Jojo
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
