Question about Garden
MAC Allister 484HP 45 cm cutting Hand Propelled Lawnmower: Right wheel level puller is broken and I need a replacement. Can you help?
  • 116 Answers
SOURCE: replacing front wheel bearings on a 1999 honda accord
there is a hub and a bearing assembly...usually you need to press the bearings into that hub...need a press to push out the old and press in the new...i replaced mine last year by going to the junkyard and taking out the hub and bearing assembly and just putting the whole thing into my car...much you learn how it goes together by taking it out in the press if its genuine honda parts from a honda..(you can match the markings) its likely to be a very good part for a long time. Being used isn't always a bad thing as far as honda parts are concerned.This is from my own experience hope this helps you.
Posted on Mar 12, 2009
  • 59 Answers
SOURCE: self propelled Yardman won't engage - cable problem I think???
are you in vero beach if so you can email me and i can fix it
Posted on Jun 26, 2009
  • 216 Answers
SOURCE: I have a Craftsman self-propelled lawnmower that will not start.
first remove air filter and spray starting fluid in the carb? if it starts the fuel is the problem carbs are easily removed and cleaned make sure needel is not stuck? if it dosnt start chexk for spark pull rope hold screwdriver over wire touch it too plug end see if you see spark if not? then you must test zone conrol cable and grounds? did you hit something hard with the blade if so you could have a sheered flywheel key it will trow egine out of time ?
Posted on Aug 27, 2009
  • 834 Answers
SOURCE: I am wanting to replace the rear wheel studs that
You do not remove the wheel hub flange, just follow the procedure that I replied to earlier, and this is the procedure if you do not want to obtain a special tool for pressing the lug studs;
First you will have to pound the broken lug studs out of the wheel hub, then you will need a lug nut and about a half an inch thick of flat washers.
1. Insert the new lug stud through the wheel hub from behind so that the threaded end is facing out towards you and then put some grease on the threads.
2. Then slip the flat washers onto the lug stud followed by the lug nut, and run the lug nut down to take up the slack.
3. Then using a breaker bar tighten the lug nut until it pulls the lug stud through the wheel hub and it is flush with the wheel hub.
Be sure that the amount of flat washers used will make up for any non-threaded part of the lug stud that might stick out past the wheel hub preventing the lug nut from pulling the lug stud all the way through the wheel hub, and basically you do not want the lug nut to run out of threads before it can pull the lug stud flush with the wheel hub.
Posted on Jun 13, 2010
  • 718 Answers
SOURCE: variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Posted on Jul 26, 2010
The right rear wheel intermittently locks up on my lawnmower when going forward stopping forward movement temporarily, until I move it backwards to "unlock" it. Any ideas?
There is an excellent 3 part video that may help you to fix this problem. Please see the 2nd and 3rd videos:
Things you can try:
(1) Remove casing over rear wheel drive assembly and perform a test run to assure all parts are moving as expected
(2) Lubricate the shafts with lightweight motor oil where the shaft penetrates into the gear box of each wheel
(3) Remove each rear wheel, inspect gears for damage and free movement. Grease up each drive gear and the shaft.
(4) Inspect gears on each wheel for damage.
(5) If none of the above fixes the problem, try swapping out the front wheels to the rear wheels provided the front wheels can accommodate the gearing on the rear wheels
(6) If this doesn't work try replacing the small gear assembly on the right rear wheel
These steps are illustrated in the videos.
Good luck and hope this helps.
Oct 11, 2016 | John Deere JA65 Self Propelled Mower
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
what do you mean adjust the blade????? the blades are bolted tightly to the blade boss/spindle. what are you trying to adjust?
Jun 27, 2014 | Briggs & Stratton Briggs Stratton...
How do I get a user manual for a mac allister power washer mhpc 130-p?
Jun 11, 2014 | Televison & Video
Unplug the spark plug.
Try to turn the blade by hand, be sure to use a heavy glove to protect your hand from the sharp edge.
If the blade turns, then move it back and forth to free it up.
If it won't turn, take the spark plug out and try to turn the blade .
If it won't turn, you may need the engine overhauled.
If it will turn, put a level teaspoon of light oil in the spark plug hole, and turn the blade a few times.
Now try the pull rope.
If it works, put a level teaspoon of fresh gasoline in the spark plug hole and install the spark plug.
It should start
Be blessed.
Feb 17, 2013 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Variable speed doesn't work troy bilt self propelled lawnmower
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Brand new lawnmower. Trouble starting and when it does start it has no power. When you move it to cut grass it konks out
Does it have a Tecumseh engine? If so it sounds like a broken or bent flywheel key. It may be a flywheel key on any engine but the Tecumseh seems to break easier. That is not a bad thing because the reason they break is to reduce other, more expensive breakage in the engine. If you need help replacing it, write..Good luck...Lee
Sep 20, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Self propel won't allow the mower to back up freely. works fine moving forward.
either the wire going to the transmission is not tight enough and need adjustment or belt needs replaceing
May 26, 2009 | Mtd 22" White Outdoor Self Propelled High...
JCB LS45 lawnmower - 2 stroke or unleaded petrol??
JCB LS45 specs Manufacturer: JCB
Blade Length in cm: 42 cm
Blade Width in cm: 40 - 44 cm
Cutting Width in cm: 42 cm
Electric Start: with Electric Start
Grass Collection Bin: Back
Horse Power: 3.5 hp
Mowing System: Rotary
Power Supply: Petrol 2 Stroke
Type: Walk behind mower
Apr 04, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
