Question about Coby TVDVD1350 13 in. TV/DVD Combo
Spindle Motor The Radio Doctor says it needs a Spindle Motor but he cant find any for this model do u know where i can order one from off the net help me please
  • not creative Apr 23, 2008
    Is your DVD player not working? Does the spindle motor work the DVD player?
No the dvd player is not working without the spindle motor
Posted on Sep 26, 2008
Missing driver for PCI Serial controller device: PCI\VEN_12B9&DEV_1008&SUBSYS_00A212B9&REV_01
Try Device Doctor portable: http://www.devicedoctor.com/device-doctor-builds.php
or
SlimDrivers Free version: http://www.driverupdate.net/download.php
Mar 22, 2011 | Computers & Internet
HI, I NEED TO REPLACE THE PLASTIC DRIVE SPINDLE ON THE BOTTOM OF MOTOR HEAD UNIT, THE STAINLESS SHAFT WITH THE BLADE STRIPPED THE PLASTIC INTERAL OF THIS PRESS ON SPINDLE. THANKS
It sounds like you're talking about the coupler on the stirrer motor.
On some models, it available separately, but on some, you have to order a new stirrer motor.
You can find links to helpful exploded view diagrams and part ordering help here.
We're happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
I recommend that you bookmark that link to your favorites.
Aug 18, 2010 | Microwave Ovens
I need to replace a deck pulley spindle assembly for blade
if you have a owners manual it will tell you but if not go to your computer punchin make model and a choice of sites will come up also sears parts direct will help u on the phone or enter your modle make and a parts list will come up good luck hope this helps.
May 19, 2017 | Mtd Garden
NAD 501 CD player reading error
There are a few ways to determine a lazy spindle motor.
  • listen to it. If it sounds like a diesel engine, with regular knocking sounds, bearings are failing... new motor
  • sit the unit on its side, see if it then reads...if bearings are worn, this reduces "slop"in the motor that can contribute jitter to the RF waveform. If it plays then,new motor
  • put a drop of oil into the top bearing of the motor. If it starts to read and run ok, then the bearing may be tight, and need lube, or the oil is acting as a hydraulic bearing. It will not fix the problem if it is a worn bearing. ...new motor.
  • if it spins up slow, and with screeching noise, the bearings are tight. see below for a solution.
Some other solutions.,
  • disconnect the connections to the motor remove a top mounting screw from the motor, and use a straw to flood the motor with crc 2-26, and spin up for 5 minutes one direction at 12 volts, then the other direction. Cleans the armature and brushes.
I always use a steel ruler to measure the height of the platter to the deck of the transport. then set the spindle height for the new motor up to the same as I measured. Happy to answer and questions that you may have. I have repaired literally hundreds of cd players over the years... including many NADs Cant recall just what the 501 has. But spindle motors cause a lot of problems with cd players.
regards robotek
Apr 27, 2010 | Audio Players & Recorders
The turntable no longer turns
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can find helpful exploded view diagrams and order parts for most major brands by entering your full model number from the tag on the oven here.
If you don't find what need there, you can probably order parts from Encompass here or you can call them toll-free at 866-779-5835.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 26, 2009 | GE JES1851 Microwave Oven
My microwave is not turning.The part hold the tray is broken. Not sure the name of the parts.
If the microwave is still heating, but not turning, the part you are talking about is the carousel motor. The carousel itself, is the small ring that the tray sits on.
If the motor is not turning, it can easily be replaced. You will need to remove the bottom panel (under the microwave) to access the motor and connecting wires. The spindle is the shaft that attaches to the carousel motor and is where the center part of the glass tray sits. The spindle simply lifts off the motor shaft.
Since you posted no brand name or model number, I have no idea how to identify a part number for you, or where to order from. If you still need assistance, please let me know. Post back with your information so that I may be able to assist you better. I hope this helps.
Jul 02, 2009 | GE JVM1650 1000 Watts Microwave Oven
Bose delco cd radio for 97 pontiac
I don't know your experise when it comes to repair. This problem is normally a bad laser or spindle motor. You can clean the laser and spray a Cleaner/Lubricant into the openings on the bottom of the spindle motor. This is a common problem I see with this stereo when it comes to repair.
Nov 15, 2008 | Car Audio & Video
Panasonic RV32 DVD player has an H07 error
This code means that the spindle motor did not come up to speed and the only way to fix it is to first find out if its the driver servo circuit thats bad or the spindle motor itself is defective. If you know how to trouble shoot a motor speed control servo sure you can fix it, But theres no easy wand waving fix for this unit. Sorry.
u may try new spindle motor
Nov 12, 2008 | Televison & Video
Order number
Hey frikitona,
I am assuming you are inquiring about a BestBuy.com order. To get an update on your order status you would need to log into BestBuy.com, or call 1-888 Best Buy™ and ask for BestBuy.com support. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 27, 2008 | Cameras
Cd player cant read disc
Check that the disk is still spinning. If not then suspect the spindle motor
Mar 23, 2007 | Sony CFD-S350 Radio/Cassette/CD Boombox
Coby TVDVD1350 13 in. TV/DVD Combo Logo
44 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
