Question about Kipor Electrical Supplies
What is error 27 kipor kde480ss3 - Kipor Electrical Supplies
2 Suggested Answers
  • 163 Answers
SOURCE: "Error code 27" coming on the generator control panel. KDE480SS3 GENERATOR
http://www.briggsandstratton.com/lam/es/support/faqs/home-standby-generator-fault-codes
This should help you
Sir Dana Taylor
IQ397
Posted on Apr 24, 2017
How to reset Kipor KDE6700TA P06 emergency stop code.
Error P-06 is the failure of the emergency stopping button. Replace the emergency stopping button or if possible check for repair.then by pushing rest/clear button reset the alarm and start the engine. https://assets-cf.criticalpowersupplies.co.uk/.../Kaipor_KDE12STA3_Silent_Generator.
Oct 27, 2017 | Kipor Electrical Supplies
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
How do I fix overtemp error on my kipor generator
Not knowing exactly which model you are running, I would check the usual areas: -
  • Check the coolant level in the radiator and expansion tank. Don't just add water, mix the correct ratio of water to coolant for your climate.
  • Check the oil levels as the oil also plays a part in cooling an engine.
  • Check that nothing is obstructing the radiator grille.
  • Check there is good ventilation space around the gennie - that is, its not stuck in a corner or up against a wall..
  • Check the hoses are not blocked - when you remove them to check them, top up the fluid levels again after you reconnect them.
Hope this gives you something to work on.
Mar 30, 2015 | Kipor Electrical Supplies
Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
Feb 19, 2009 | Kipor Electrical Supplies
Electrical Supplies Logo
27 people viewed this question
Top Kipor Electrical Supplies Experts
Vernon Taylor
jhnolson
mark52001p
Level 1 Expert
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
