Question about Lands Phones
How can i delete the sp-phone to catch programmed outside line ?
When I press the sp-phone it does not open the speaker phone, it is catching programmed outside line instead. how can I make the sp-phone to open the speaker without catching a line?
  • 192 Answers
SOURCE: Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
  • Thread the needle.
  • Turn the handwheel by hand.
  • Watch the hook as it approaches the needle from right to left.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
Posted on Nov 14, 2007
  • 33 Answers
SOURCE: I cannot get the needle to catch the bobbin thread
sounds like your keeping the upper thread too tight when you drop your needle down to catch the bobbin or the bobbin thread that you left hang out is too short, let me know if it works amy
Posted on Sep 04, 2008
  • 255 Answers
SOURCE: 2005 Jeep Grand Cheerokee Sunroof Leak
have the sunroof gasket replaced
or buy one online cheap at sunroof doctor.com
hope2help shack
Posted on Apr 19, 2009
  • 18 Answers
SOURCE: Want to pick up phone and get an outside line
Yes, put your lines in a line pool, then have your phone automaticly go to Line Pool: <Whatever Pool # you picked, 1 thru 3>
Posted on Oct 01, 2009
narayanan112
  • 554 Answers
SOURCE: phone memory low delete some
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Posted on Jan 08, 2011
CO problems
Check your Phone if connected to Jack 01 to do programming below:
on KX-T7730 phone Press Program *# (enter Password) default is 1234
Press 400 SP-Phone(CO NO.? will be displayed) Press *(Mixed or Connect will be displayed), Press AUTO ANS/MUTE untill (NOT Connect will be displayed) Press AUTO/STORE. Press HOLD(SYS PGM will be displayed) Press 400 (CO Connection will be displayed) Press SP- Phone(CO NO.?) Press SP-Phone (Not Connect will be displayed) Press AUTO ANS/Mute until (Connect will be displayed)Press AUTO/STORE PRESS PROGRAM to return to NORMAL Display.
For the incoming Calls PRESS Program *#1234 (ENter Sys PGM will be displayed) PRESS 408(Day IN CO will be displayed) Press SP Phone (CO No? will be displayed) Press SP Phone (CO1:#01:DISABLED if this is displayed PRESS AUTO ANS/MUte the Enabled will be displayed) Press AUTO/STORE. Press Program to return to normal display. In this Manner All Calls will ring to extension which is connected to Jack 01. you dont need to press the button anytime there is an incoming call.
Dec 04, 2013 | Panasonic KX-T7730 Corded Phone
Line connection
try this;
press sp-phone enter *71029, then enter the outside number, then #, you will hear a tone that means call forwarding is activated.
to cancel press sp-phone *7100# or simply dial 790 for extension data clear
Aug 07, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    How do I program a phone number to the one touch buttons on a Panasonic KX-T7730 phone?
    It depends on what you get when you dial "9" on the intercom. If you get an outside line, then the 12 right side buttons on your phone can be programmed for one touch dialing like this:
    On an idle phone, press PROGRAM a button and dial 9 plus the number and STORE. You can program more than one button by just pressing button numbers and STORE. Exit programming by picking up the handset and dropping it back down.
    If you want a specific line, you may be able to dial the specific 8x code to access a line directly, or you can go into system programming and delete the open lines in program 400. Disabling would be the best, because if your 8x line is busy, you can't make the call with the auto dial button.
    Carl
    Mar 08, 2011 | Panasonic KX-T7730 Corded Phone
    I removed door panel to install speakers now the door wont close
    You need to make sure the panel is on perfect. If it is a little off, it will catch the ends. Is the inner panel catching the door? If you added bigger speakers, it may catch on the inner part of the door, closet to the speakers.
    Feb 18, 2011 | 2002 Dodge Durango
    KX-T7730 - Used to have 3 incoming/outgoing lines. Have cut this down to 2(lines 1 and 3). Outgoing calls are automatically selected by line 3, 2, 1. When calling out the second person can't get an outside...
    If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
    From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
    1. Press PROGRAM * # followed by the system password ( default is 1234).
    2. Now press 400 and then SP-PHONE. Enter the line number you wish to change. ( In your case 2)
    3. Press AUTO ANS / MUTE to change between Connect and Not Connect.
    4. Press AUTO DIAL / STORE to save your changes.
    5. Press PROGRAM to exit program mode and you are done.
    Mar 17, 2010 | Panasonic KX-T7730 Corded Phone
    I have a kx-ta624..one of my extensions was programmed to co1 and now I want to program it to co3... how do I do this?
    It's been a few years since I programmed a 624, but here goes.
    IIRC the 624 selects lines in 1,2,3 order vs. the 824's 321. Dial "9" from the intercom and you can verify this.
    The system has 3 modes of operation when it comes to outside line access, No preference (gives you intercom dial tone) Idle line preference (gives you the same as if you dialed "9", and specific line preference.
    From the phone, do not pick up the handset but press PROGRAM or use the set switch to program, dial 1 1 for none, 1 2 for idle, or 1 3 x for a specific line. Any of those commands would be followed by STORE.
    Put the system back in SET or press the PROGRAM button to exit.
    With any line preferenc, you have to press Intercom to dial internally or page. If your specific line is busy, you won't get anything when you pick up the phone or press SP PHONE. It also disables Last Number redial if the line is busy.
    Did I mention that I don't use it :-) Of course, I don't use the 624 either.
    Carl
    Jul 16, 2009 | Panasonic Lands Phones
    Programming Page Button
    You could look in the station user's guide and program paging. This may work, or not, if you're paging internal and outside do this:
    From your phone press Feature 00 the button and then Intercom *70.
    If you don't want all the idle phones in group 1, but just the outside speaker, press 70 alone.
    I'm not positive, but you may have to delete the button in centralized programming if it is already assigned a "CO" line.
    Centralized programming is done from extension 10 or 11 and involves the system manual and knowing where the overlay buttons are.
    Post back if you need a basic Partner ACS manual or try www.avaya.com for system manuals.
    Carl
    Feb 20, 2009 | Avaya Corded Phone avaparp18d
    Fax-like noise when answering catch a call!
    If you have a catch a call max, this happens because the catch a call is too sensitive to the phone company's signal, you can lower the sensitivty of the catch a call by dialing ###3. You can get the catch a call max manual here
    Feb 18, 2009 | Catch A Call Catch-A-Call Internet/Phone...
    My Mazda
    hi see how difficult it is to get the rear panels are to remove from inside the car and get into the boot that way once in its just a case of unbolting the boot catch then sort the boot lock out a matter of interest this is not a old car can you here the boot catch operate when you press the button if so get somebody to pull the boot up while you press the button if not it may be a fused line in this case it is worth checking all the fuses are ok best of luck let me know how you go on yates210456
    Oct 02, 2008 | 2004 Mazda 6
    Lands Phones Logo
    Top Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a Lands Phone Expert? Answer questions, earn points and help others
