Integrated webcam problem
I have an integrated webcam on my laptop but every time I turn it on and move the screen on the laptop up or down I get a message (in ArcSoft Webcam) saying the connection to my camera was lost. It then gives me the option to select another device but this just changes the display resolution and I cannot see an image (although the webcam light stays on). At the same time a windows message pops up saying this USB device can perform faster if you connect to a high-speed USB 2.0 port. The only way to get the webcam to display an image again is to re-start the laptop. Any ideas how I fix this?
  • 1 more comment
  • bigabc Jul 25, 2009
    Yes it seems to be fine, but you only have to adjust the screen a tiny bit and the camera cuts out. Sometimes if you move it really slowly it cuts out and then comes back on again
  • bigabc Jul 31, 2009
    Thanks, if it's definitely a hardware problem I guess it's best to send it back to Sony as it's still under warranty. Thanks for the advice
  • tommya300
    tommya300 May 11, 2010
    If you do not move the screen does the unit work ok?
  • 724 Answers
If it works fine when the hardware is not being moved that is a sign of a loose connection not a software problem. Mechanically the ribbon cable can have a fracture in the conductor or where it connects is not exactly seated. or the strain relief is just a little tight when the sceen is moved it pulls a little just enought to make or break a connection ever so slightly. My old Micronta has a flawed lcd there is a line that shows up travelling fron top to bottom in the viewing. I twist the sceen in a opposit direction and is changes and sometimes straightens out. Here there is manny comnnections that sit in an array patern that intersect inside the screen and this connection is more difficult to fine so I live with it. it is old and slow and needs a battery but I tried disassebling it to see if I can fix the connection and got to a point that I may destroy it all . The camera may have a the same type of problem so it is up to you to go to this point or luckly find the problem. Now knowing this you can shut that camera off and attach an over the counted 19 dollar camera that you will have to haul around or adj thwe screen and then boot the computer. But for sure it is hardware not software
Posted on Jul 25, 2009
    Sergeant:
    Novelist:
  • 192 Answers
Check on the manufacturer's website to see if there is any updates to the software for the camera. Also, update the actual drivers for the camera. Outside of that, if you still get the same error than that means that the camera is faulty. I'd just disable it and use a USB web camera.
  • dbucyk Jul 26, 2009
    It's a minor fix. There seems to be a fragmented wire in the wire going through the hinges that controls the web camera. When then install the camera, it is about the size of a pencil eraser. It has a long wire that connects to the laptop by travelling down the screen, in through the hinges, and connects to the motherboard.
    If you want to, you can actually replace it yourself. Contact the manufacturer and ask if they can send one out to you. If they send you one, then here's what you do.
    1. On the laptop screen there should be 4 screws hidden by pieces of rubber. Remove them.
    2. On the laptop, remove the laptop keyboard by looking for little slots underneath the plastic housing. Depending on the type of laptop, you'll have to search for them. Pry up the plastic to remove the casing above the keyboard. Use a very small flat head screwdriver.
    3. Usually a laptop keyboard is held in place by a few screws. Undo those.
    4. There is a ribbon cable connecting the keyboard, remove it by unlocking the ribbon cable.
    5. Once you have done that, then you can use the flat head screwdriver and slowly pry the screen casing apart. You don't have to take anything else apart.
    6. You will see the laptop web cam with a wire connecting to the motherboard. Follow it, and remove the wire. If a replacement is one it's way from the manufacturer, just connect it to the laptop and do the reverse method of putting the laptop together.
    If this does not expose the webcam, but it should, then you'll have to remove the bottom screws in the laptop to separate the laptop and gain access. If you have any concerns, just send a reply to me.
How to turn on internal camera in Linux Mint?
Hello, Mint is built from Ubuntu and Debian, so if you are having a hard time finding a fix, usually it can be found at askubuntu.com. For instructions on turning on an integrated webcam, please see this page: How to turn on the integrated webcam
Hope this helps
Aug 27, 2014 | HP Paviliondv4-1199es Lcd Screen 14.1 Wxga...
How do I turn on the integrated webcam?
you either have it disabled in the control panel or the driver files are corrupted. You might have loaded some software which accesses the camera and uninstalled it or its installation failed, taking down the driver wth it. find camera driver and load it. look for it in control panel or device control.
Dec 23, 2012 | HP Computers & Internet
Integrated webcam not turned on
First, you should check your Windows device manager to see if the drivers for that piece of hardware are working properly. Now if that's all cleared up, I know that on my laptop, the integrated webcam only turns on when there's a piece of software asking it to run. Try finding your manufacture's webcam software. For me, it's Toshiba Webcam Software. Run the program and see if the webcam turns on. I hope this helps!
Aug 27, 2011 | Computers & Internet
I have an integrated webcam and when I go to YouCam it tells me that I need to turn on my integrated webcam and I have tried so many things and I still do not know how to turn it on. There is a like a...
Sorry to disappoint you but two things, the plastic screen you are referring to is simply a piece of plastic where the webcam would be, if you have the model that has the integrated webcam. This model does not have an integrated webcam, the sister model does. Here are the specs of your model!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02542735&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=4308201
May 31, 2011 | Compaq Presario CQ56-115DX Laptop
Dell Studio 1537 (Vista) Integrated Webcam no longer working??
The issue could be due to a loose connection of the camera above the lcd panel. Try uninstalling the drivers and shutting down the computer. Once done gently press the area around the webcam. Power on th computer. See if you get any new hardware and if it installs. If no. check in device manager. If you still have a bang on the webcam uninstall all usb root hubs and restart the computer. If still no joy power off the computer. You need to hold down the Fn button (Located next to the CTRL button on the left hand corner) and then power on the system. This will take the system to the diagnostics mode. After running the tests run a custo tests on the webcam.
Jun 15, 2009 | Dell Studio 1537 Laptop
Integrated webcam not working
open settings for webcam/video device/ choose integrated/hope it helps.
May 21, 2009 | Dell Computers & Internet
Using integrated webcam for emachines d520
I have a D520 notebook through emachines and I cannot find how to access the web cam
Feb 08, 2009 | Acer Computers & Internet
Medion Akoya P6612 Notebook Cyberlink YouCam
I have just bought the same Laptop, when windows Vista is started the webcam doesn't work. By pressing the keys FN + F9 the webcam will be activated (you have to do this every time you start your laptop)
Nov 17, 2008 | Computers & Internet
Unable to turn on Integrated Webcam on HP laptop
do not no how to turn on my webcam. hp g61 laptop
Oct 27, 2007 | Watches
Computers & Internet Logo
1,859 people viewed this question
David Payne
David Payne
